DriftFluxFoam working principles
Old   September 20, 2023, 12:38
Default DriftFluxFoam working principles
Turhan
Turhan is on a distinguished road
Hello all,
I am trying to create a sand water slurry with driftfluxfoam.
My goal is to determine the values for the bingham plastic.
The variables that I want to determine are in the transportProperties file and they are called: the coeff, exponent, BinghamCoeff, BinhamExponent, BinghamOffset and muMax.
I tried looking for the bingham plastic formulas online. However those papers do not use terms such as coeff, exponent and the like. Nor am I able to find a formula that shows similarities to the code written in BinghamPlastic.C
Could someone explain the formula that uses the coefficients and exponents that I fill in at transportProperties, and how I could determine them for my case?
Thank you in advance.
Turhan is offline   Reply With Quote
bingham, bingham fluid, bingham plastic flow, driftfluxfoam
TUI - Strange behavior related to the working directory Dav[ID] FLUENT 5 September 6, 2022 14:45
Porous media coefficients and working fluid Dronzer FLUENT 1 June 30, 2020 22:23
findCell() in parallel: not working if location is outside the domain TobiWol OpenFOAM 0 January 10, 2018 14:33
Processor 0 not working vishwesh OpenFOAM Running, Solving & CFD 0 November 17, 2017 03:35
DPM parallel is not working but serial is working johnwinter FLUENT 1 March 27, 2012 02:01
