mapFields in OpenFOAM for Overset Cases with Moving Boundaries
Old   October 4, 2023, 06:09
Default mapFields in OpenFOAM for Overset Cases with Moving Boundaries
Mehdi Badri
Mehdi80 is on a distinguished road
Hello everyone,
I've been working on an overset simulation in OpenFOAM-2112 where I'm trying to use the mapFields function object to initialize a fine-mesh case with a coarse-mesh solution. I can successfully map all variables, and the initial case appears to be okay. However, the new case diverges from the first time step (the adjustable time step quickly approaches zero).
Here's a brief overview of my setup:
- I'm using mapFields to handle data transfer between two grids.
- To simplify the case, I am using two similar meshes (with the same resolution)
- The simulation involves moving boundaries
- I also manually copied the pointDisplacement directory
I've checked my boundary conditions, mesh quality, and solver settings, but I'm still encountering this divergence issue. Has anyone else faced a similar problem when using mapFields in OpenFOAM for overset cases with moving boundaries?
I would greatly appreciate any insights, tips, or suggestions to help me resolve this issue and ensure a stable simulation.
Mehdi80 is offline   Reply With Quote
initialization, mapfields, moving boundaries, openfoam, overset
OpenFOAM 4.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 2 October 6, 2017 05:40
UNIGE February 13th-17th - 2107. OpenFOAM advaced training days joegi.geo OpenFOAM Announcements from Other Sources 0 October 1, 2016 19:20
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin cfd.direct OpenFOAM Announcements from Other Sources 0 September 21, 2016 11:50
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
