October 28, 2023, 23:59 |
OpenFOAM_interfoam_hole at top
Anurag
Rep Power: 3 |
Hi All, I am using the interFoam multiphase solver for air-water flow inside a pipe. Everything is running fine but when I am trying to introduce a hole at the top of the 3d pipe for some air to come in it is producing a floating point error after some time. Actually I wanted to introduce a hole at the top of the pipe and designated it as outlet(similar BCs as the real outlet at the end of the pipe). My BCs are: inlet-vel intlet pure water, walls-no slip, real outlet-pressureinletoutletvelocity and a small circular section on top of pipe on the walls(I created this mesh (and named selections) in ansys and converted it to Openfoam format) which I gave the same BCs as real outlet as I wanted it to behave as the actual outlet. I just want some air to come in from the top of the pipe in addition to from the actual outlet at the end. Can someone please give me suggestions why its producing an error??
Many Thanks. |
[blockMesh] Floating Top Boundary | Lets Talk CFD | OpenFOAM Meshing & Mesh Conversion | 0 | October 7, 2020 09:21 |
bubbleColumn change Inlet position to top does't work with compressible flow | masimasiqi | OpenFOAM Running, Solving & CFD | 0 | May 23, 2019 06:58 |
Appropriate boundary conditions for top atmosphere | sturgeon | OpenFOAM Running, Solving & CFD | 7 | October 3, 2017 09:07 |
turbineSiting tutorial: slip condition at top boundary gives unexpected result | letzel | OpenFOAM | 0 | June 6, 2014 05:25 |
about the top of the mixing tank | boh_tea | FLUENT | 7 | August 21, 2010 03:58 |
