cylinder case
Like Tree6Likes
  • 1 Post By monty86
  • 3 Post By Artur.Ant
  • 1 Post By B_R_Khan
  • 1 Post By moonv
Old   April 18, 2014, 05:01
Default cylinder case
monty86 is on a distinguished road
Dear all,
I am facing problem while going through the tutorials. i am new user of OpenFoam. in cylinder case when i put Allrun command to run the problem i am getting following error in paraFoam window.
p, li { white-space: pre-wrap; } RROR: In /home/opencfd/OpenFOAM/OpenFOAM-2.3.0/applications/utilities/postProcessing/graphics/PV4Readers/PV4FoamReader/PV4FoamReader/vtkPV4FoamReader.cxx, line 216
vtkPV4FoamReader (0xb07cb78): could not find valid OpenFOAM mesh
ERROR: In /home/opencfd/OpenFOAM/ParaView-4.1.0/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 754
vtkPVCompositeDataPipeline (0xb075dc8): Algorithm vtkPV4FoamReader(0xb07cb78) returned failure for request: vtkInformation (0xb088870)
Debug: Off
Modified Time: 91093
Reference Count: 1
Registered Events: (none)
Request: REQUEST_INFORMATION
ALGORITHM_AFTER_FORWARD: 1
FORWARD_DIRECTION: 0
ERROR: In /home/opencfd/OpenFOAM/OpenFOAM-2.3.0/applications/utilities/postProcessing/graphics/PV4Readers/PV4FoamReader/PV4FoamReader/vtkPV4FoamReader.cxx, line 216
Debug: Off
Reference Count: 1
& when i am adding command of blockMesh i am getting following error message
--> FOAM FATAL IO ERROR:
This code should not be executed by someone with administrator rights due to security reasons.
(it writes a shared library which then gets loaded using dlopen)
file: /root/OpenFOAM/tutorials/basic/potentialFoam/cylinder/constant/polyMesh/blockMeshDict from line 17 to line 17.
From function functionEntries::codeStream::execute(..)
in file db/dynamicLibrary/dynamicCode/dynamicCode.C at line 68.
FOAM exiting
Please help me out to understand what is the problem
ghastbug likes this.
monty86 is offline   Reply With Quote
Old   April 19, 2014, 08:53
Nima Samkhaniani
nimasam is on a distinguished road
well;
means there is no mesh created
FOAM exiting
this tutorials uses a dynamic code (codeStream), means a part of blockMesh will be compiled and created in runTime, so to use code stream you should enable allow System Operations. read this thread.
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   April 21, 2014, 06:40
Dear Nima,
As per your suggestion i activate the allow system operation by replacing 0 with 1 but still getting the same error. am i missing something in this or have to replace with other number?
Old   April 21, 2014, 07:44
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
the error is self-explanatory
And it says that you should not run simulation using root account. Make OpenFOAM accessible to users and run the case from user account.
alexeym is offline   Reply With Quote
Old   April 22, 2014, 06:50
Dear alexey,
Now i got it, I installed OpenFoam as a sole root login. without root login i am not able to run any case. Is there any way how i can add another user account & run OpenFoam without root login? I dont want to do again Open foam installation procedure. This may be silly question but i am stuck on it.
Old   April 22, 2014, 07:13
Alexey Matveichev
as I don't know what Linux distribution you're using, my hits will be rather generic. In general it's simpler to install OpenFOAM system-wide using package manager (this way all permissions will be set correct and OF will be usable by all users of the system) but since you've decided to build it, here is the way to transfer it from root account to use account (by convention # will be shell prompt of root account, $ will be shell prompt of user):
1. Create ordinary user
# useradd -m ofuser
# passwd ofuser
these two commands will create ordinary user account and set its password. -m switch will instruct useradd utility to create home folder, usually it is /home/ofuser.
2. Copy (or move, in this case use mv instead of cp -r) OpenFOAM folder from root home to new user home
# cp -r /root/OpenFOAM /home/ofuser/
3. Fix ownership of the installation
# cd /home/ofuser
# chown -R ofuser OpenFOAM
Now you can login as ofuser and try running tutorials
$ cd
$ source OpenFOAM/etc/bashrc
$ tut
$ cd basic/potentialFoam/cylinder
$ ./Allrun
Though your way of naming OpenFOAM folder seems rather strange to me, as usually it is installed into $HOME/OpenFOAM/OpenFOAM-<OF version>.
Old   June 21, 2015, 17:07
vito
vitocorleone is on a distinguished road
Hello Alexym,
I have the same error as mentioned above
I am using openFOam on windows, I made the programme accessible to guest and tried using the blockMesh command in the guest account for the cylinder case but I get the same error. Kindly Help.
vitocorleone is offline   Reply With Quote
Old   August 23, 2018, 04:58
Arthur
Artur.Ant is on a distinguished road
Hello
I also had this problem installing openFoam on Windows.
I solved it doing these steps:
1)go to ... src/OpenFOAM/db/dynamicLibrary/dynamiCode folder
2)open dynamicCode.C file
3)comment the part of the error like this:
/* if (isAdministrator())
FatalIOErrorInFunction(dict)
<< "This code should not be executed by someone with administrator"
<< " rights due to security reasons." << nl
<< "(it writes a shared library which then gets loaded "
<< "using dlopen)"
<< exit(FatalIOError);
4)go back to ...src/OpenFOAM folder
5)compile openFOAM with command:
wclean libso && wmake libso 2>&1 | tee log.wmake
6)if you don't have 'make' install it
for more information visit this link: https://www.computerhope.com/unix/umake.htm
7)if you don't have 'zlib1g-dev' library install it.
Hope this will help someone.
Artur
Danubi, allanZHONG and AnzarMark1 like this.
Artur.Ant is offline   Reply With Quote
Old   July 31, 2019, 14:57
OOS
oobiols is on a distinguished road
I just wanted to let you know that this just saved my life, thank you so much!
This worked for me in a RHEL centOS 7.6 system, using the v6 openfoam image for docker.
oobiols is offline   Reply With Quote
Old   March 5, 2020, 08:37
A. Min
alimea is on a distinguished road
Originally Posted by alexeym View Post
# useradd -m ofuser
# passwd ofuser
# cd /home/ofuser
$ cd
$ tut
$ ./Allrun
Dear alexeym,
I wanted to do what you mentioned, but I faced with these problems:
1- When I wanted to create a new user, it gave me "permission denied" error! So, I log in with admin using "sudo -s". (Did I do right? or I didn't have to log in with admin?)
2- I did not have "OpenFOAM" folder as you did, so I copied openFOAM-7 folder. (Did I do right? or I had to find the same folder?)
3- The openFoam folder is copied in /opt/home/ofuser address, not in main home! What did I have to go?
4- Again, the "# chown -R ofuser OpenFOAM" command did not work, as I have no OenFOAM.
At last, I couldn't use the openFoam on my home folder!
Regards,
Ali
alimea is offline   Reply With Quote
Old   July 1, 2020, 12:50
Default Needs to be a way to do this without creating a user
  #11
LeeRuns is on a distinguished road
Originally Posted by alimea View Post
Dear alexeym,
Regards,
Ali
For anyone running docker containers with automated applications we skip the whole user permissions, meaning you have permissions to do all of this if you have permissions to run the app. It make4s everything clearer. So is there a way to do the dynamic calculation without having to create a user?
LeeRuns is offline   Reply With Quote
Old   February 2, 2021, 12:54
Bushra Rasheed
B_R_Khan is on a distinguished road
Originally Posted by Artur.Ant View Post
Hello
<< "using dlopen)"
Artur
Followed your steps but stuck at 5th step. How do I compile in OpenFOAM folder?
Thanks
NiruBhai likes this.
B_R_Khan is offline   Reply With Quote
Old   June 12, 2021, 07:29
Default overinterdymfoam two rotor error in openfoam.com msys2 windows v1906
  #13
Saurabh
Saurabh__ is on a distinguished road
after giving command ./Allrun
Pstream initialized with:
floatTransfer : 0
nProcsSimpleSum : 0
commsType : nonBlocking
polling iterations : 0
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Overriding DebugSwitches according to controlDict
overset 0;
dynamicOversetFvMesh 0;
cellVolumeWeight 0;
Create mesh for time = 0
Selecting dynamicFvMesh dynamicOversetFvMesh
Selecting motion solver: multiSolidBodyMotionSolver
Selecting solid-body motion function rotatingMotion
Applying solid body motion rotatingMotion to 2512 points of cellZone movingZone1
Applying solid body motion rotatingMotion to 2516 points of cellZone movingZone2
PIMPLE: no residual control data found. Calculations will employ 2 corrector loops
Reading field p_rgh
Reading field U
Creating cellMask field to block out hole cells
Creating interpolatedCells field
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
RAS
RASModel kEpsilon;
turbulence on;
printCoeffs on;
Cmu 0.09;
C1 1.44;
C2 1.92;
C3 0;
sigmak 1;
sigmaEps 1.3;
Reading g
Reading hRef
Calculating field g.h
No MRF models present
No finite volume options present
DICPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
Reading/calculating face velocity Uf
Courant Number mean: 0 max: 0
Starting time loop
This code should not be executed by someone with administrator rights for security reasons.
It generates a shared library which is loaded using dlopen
file: J:/CFD/openem/msys64/home/ofuser/twoSimpleRotors/system/controlDict.functions.alphaVol
From function static void Foam::dynamicCode::checkSecurity(const char*, const Foam::dictionary&)
in file db/dynamicLibrary/dynamicCode/dynamicCode.C at line 78.
If v2020 used then an error is no make found then I have used a later version then above error is pop-up.
please help why this error is persists
Saurabh__ is offline   Reply With Quote
Old   October 31, 2021, 22:56
NiruBhai is on a distinguished road
Originally Posted by vitocorleone View Post
Hello Alexym,
Right-clicking on the main OpenFOAM folder, going to properties, changing the security settings and allowing full control to all users should work as it did for me
NiruBhai is offline   Reply With Quote
Old   February 14, 2022, 08:46
Default wmake
  #15
ghastbug is on a distinguished road
Khan,
As far as I understand, you have to run the make files in OpenFOAM\v2106\msys64\home\ofuser\OpenFOAM\OpenFOA M-v2106\src\OpenFOAM. So first you tell shell to go there (you use cd), and then you input the command (wclean libso && wmake libso 2>&1 | tee log.wmake).
I did that, and I got this error though:
alessandro.sarti@28APO4951 MSYS ~/OpenFOAM/OpenFOAM-v2106/src/OpenFOAM
$ wclean libso && wmake libso 2>&1 | tee log.wmake
wclean libso
wmake libso (OpenFOAM)
/home/ofuser/OpenFOAM/OpenFOAM-v2106/wmake/rules/General/general:34: /home/ofuser/OpenFOAM/OpenFOAM-v2106/wmake/rules/win64Mingw/general: No such file or directory
make: *** No hay ninguna regla para construir el objetivo '/home/ofuser/OpenFOAM/OpenFOAM-v2106/wmake/rules/win64Mingw/general'.  Alto.
/home/ofuser/OpenFOAM/OpenFOAM-v2106/build/win64MingwDPInt32Opt/src/OpenFOAM/options:6: *** falta un separador.  Alto.
wmake error: file '/home/ofuser/OpenFOAM/OpenFOAM-v2106/build/win64MingwDPInt32Opt/src/OpenFOAM/sourceFiles' could not be created in /home/ofuser/OpenFOAM/OpenFOAM-v2106/src/OpenFOAM
Looks like openFOAM's wmake folder does not have rules for win64Mingw. Sooo, maybe we have to switch to Linux.
Actually, I don't even know C, but it looks like shell first opens rules/General/general, and then, it sees there that it has to switch to win64mingw/general, which does not exist. So maybe there is a way to edit general/general so it doesn't refer to the win64mingw rules that don't exist, or we can make a rule file in win64mingw
ghastbug is offline   Reply With Quote
Old   February 16, 2023, 05:20
Default user with similar error
  #16
simon
moonv is on a distinguished road
Hey!
I am just starting out with openfoam (on windows) and I have the same issue. I wanted to edited the dynamicCode.C like mentioned above, but when I search for the directory "dynamicCode" I just find a folder under etc/codeTemplates and it doesnt have a dynamicCode.C file.
Running the blockMesh command throws the admin error, and also says -->
From static void Foam::dynamicCode::checkSecurity(const char*, const Foam::dictionary&)
in file db/dynamicLibrary/dynamicCode/dynamicCode.C at line 72.
Based on this it seems the file dynamicCode.C should be found when searching the folders but no...
I tried a cd $FOAM_SRC command but it also just says No such file or directory.
Help a lost soul out pls.
MKdoubleB likes this.
moonv is offline   Reply With Quote
Old   July 29, 2023, 13:43
Markus Bähner
MKdoubleB will become famous soon enough
Originally Posted by moonv View Post
Hey!
i have the exact same problem. Is this due to a newer version of OpenFOAM?
MKdoubleB is offline   Reply With Quote
Old   December 20, 2023, 07:01
JC
CMP23 is on a distinguished road
I had the same issue is referred here:
"--> FOAM FATAL IO ERROR: (openfoam-2306)
It generates a shared library which is loaded using dlopen."
I'm using OpenFoam 2306 with ubuntu WSL. I tried coment some of the code like is sugested on this forum, however, then i wasn't able to use the libraries due to :"error while loading shared libraries: libOpenFOAM.so: cannot open shared object file: No such file or directory" erro.
I have also tried to implement a new user like its suggested, however the command "chown -R ofuser OpenFOAM" shown the follow error message:"chown: cannot access 'OpenFOAM': No such file or directory".
Can you give me some tips.
Best regards.
CMP23 is offline   Reply With Quote
2D flow around a circular cylinder case with interFoam solver shuoxue OpenFOAM Running, Solving & CFD 2 January 14, 2020 13:23
MRFSimpleFoam wind turbine case diverges ysh1227 OpenFOAM Running, Solving & CFD 2 May 7, 2015 10:13
flow around a circular cylinder with velocity inlet and outflow outlet shuoxue OpenFOAM 1 March 3, 2014 10:42
Error for an oscillating cylinder case (oscillatingFixedValue) aut_iut OpenFOAM Bugs 0 April 30, 2010 06:19
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 18:40
