December 24, 2023, 02:38 |
Direction of g in interFOAM
Anurag
Rep Power: 3 |
Hi all,
I could see that the direction of g in interFOAM, angledDuct and waterChannel tutorials are different. One is in y and in waterChannel is in z direction. Why this discrepancy? Gravity should always act in the y direction right? Or does it depend on something else? I plan to create mesh in ansys and then convert. Thanks. |
December 24, 2023, 11:27 |
Yann
Rep Power: 26 |
It depends on the coordinate system you are using, it could be anything. I didn't check the tutorials you mention but probably the geometries and coordinate system are oriented differently. Regards, Yann |
December 24, 2023, 17:03 |
Anurag
Rep Power: 3 |
Hi Yann, yes. For my case I use ansys for creating geometry and mesh. SO I have used g like used in ansys coordinates. I hope it is fine.
How to perform surface averaging in one direction | chandra shekhar pant | OpenFOAM Running, Solving & CFD | 5 | July 24, 2020 22:20 |
fvOptions-velocity generates against direction of momentum. | mrishi | OpenFOAM Running, Solving & CFD | 2 | September 25, 2019 15:15 |
solved: contact angle correction in interFoam | rcastilla | OpenFOAM Bugs | 24 | March 2, 2016 13:43 |
ERROR: Flow direction on the boundaries must not be tangential to the boundary. | turbomax | CFX | 2 | August 6, 2015 11:05 |
[ICEM] Changing edge direction | la7low | ANSYS Meshing & Geometry | 2 | June 7, 2010 13:26 |
