rhoPimpleFoam Excessive Courant Numbers and Small Time Steps |
January 17, 2024, 05:03 |
Lakshmi siva kumar
Rep Power: 2 |
Dear CFD-Online community,
I hope this message finds you well. I am currently working on a transient heat transfer simulation using OpenFOAM. The simulation involves a transonic flow over an airfoil, and I am facing challenges related to excessive Courant numbers leading to extremely small time steps. I have attempted the following troubleshooting steps: 1. Adjusted numerical parameters in the fvSchemes and fvSolution files. 2. Checked and modified boundary conditions where necessary. 3. Reviewed and adjusted relaxation factors in the fvSolution file. 4. Verified mesh quality and refined where needed. Despite these efforts, the simulation's deltaT has reached an extremely small value (e.g., 2.7686277e-47), causing the simulation to stop. The Courant Number mean is within acceptable limits, but the pressure and time step issues persist. I would greatly appreciate any guidance or insights from the community on how to address these challenges. Specifically, any suggestions regarding adjusting numerical parameters, modifying boundary conditions, or optimizing the simulation setup would be immensely helpful. Thank you in advance for your time and expertise. Best regards, MLSK |
January 18, 2024, 14:47 |
Troy Snyder
Rep Power: 18 |
My first suggestion would be to run the transonic flow case as steady-state first if possible. What in the model setup necessitates a transient analysis?
February 7, 2024, 00:24 |
Lakshmi siva kumar
Rep Power: 2 |
I want to validate Rhopimplefoam in openfoam in transonic case and chose to run simulation of RAE2822 at M=0.7.., Re= 6.5 mil , whose experimnetal data is avalilable on NASA website. inital mesh didn't give matching rsults and saw wave fluctuations in upper surface of airfoil. so i made finer mesh to improve y+ but this simualtion is not going any furhter as delta T is very low.
The initial transient part of the solution takes too long to fade | Ashkan Kashani | CFX | 3 | January 28, 2023 18:52 |
Very low Courant numbers for multiple AMI | usr0830 | OpenFOAM Running, Solving & CFD | 4 | July 24, 2021 08:03 |
Compressible flows with larger Courant numbers | Tobi | OpenFOAM Running, Solving & CFD | 5 | February 26, 2021 15:20 |
pimpleFoam, rhoPimpleFoam unstable at small Courant numbers (time-steps) | peob | OpenFOAM Running, Solving & CFD | 18 | November 13, 2020 13:56 |
InterFoam negative alpha | karasa03 | OpenFOAM | 7 | December 12, 2013 03:41 |
