v10 pimpleFOAM: Rotational cyclicAMI boundary conditions face Weight going to 0 |
January 23, 2024, 11:16 |
Niall O'Neill
Rep Power: 3 |
Hi everyone,
So I am using v10 to simulate a wind turbine case. I have chosen to model half the domain just to save running time (I really need to do this if possible due to available resources) Initially, I used MRF which ended up working for me, but I now need to use rigid body motion (so that I can use libAcoustics). I am using the SA turbulence model My issue is that I am having serious difficulty in just getting a simulation going with the rigid body motion and periodic faces. It will run for like 3 time steps, but then crash on the 3rd time step. The following is an excerpt from running pimpleFOAM (third time step): Code:
Courant Number mean: 0.011671816 max: 1.5599877 Time = 0.0015s PIMPLE: Iteration 1 AMI: Creating addressing and weights between 102419 source faces and 101922 target faces AMI: Patch source sum(weights) min/max/average = 0.38156299, 1.0000005, 0.99971194 AMI: Patch target sum(weights) min/max/average = 0.69604475, 1.000114, 0.99999508 AMI: Creating addressing and weights between 47454 source faces and 47454 target faces AMI: Patch source sum(weights) min/max/average = 0, 1.0137377, 0.99686404 AMI: Patch target sum(weights) min/max/average = 0, 1.0142746, 0.99638231 ................ ................... ............... #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) at ??:? #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/pimpleFoam" #5 ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/pimpleFoam" #6 ? in "/lib/x86_64-linux-gnu/libc.so.6" #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #8 ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/pimpleFoam" Floating point exception (core dumped) Note that the second set of AMI faces, where the 0 weight issue arises is actually the cyclicAMI faces that separate the rotating and non rotating region. These 2 faces are the exact same. Later I have described the sequence that I used to create these. As you will see below, when I used moveMesh, the periodic faces also moved with the mesh. Does this indicate that they are not set correctly? I know that with MRF there is a "nonRotatingPatches" option, but it doesn't seem to be a thing in the dynamicMeshDict What I have tried already: - I have simplified my case down to just a cylinder in place of a blade to rule out any meshing issues with the blade - I have generated a 360 degree model with rigid body motion (which appears to be moving fine after running for a while) - Then I went back to the half domain, with periodic faces, and I have used the moveMesh command, which runs ok (but the entire region including the periodic faces are moving with the rest of the cell zone. (See in the image below) - I have tried to use cyclicPeriodicAMI, but It does not appear to be implemented in OF10, then I tried cyclicSlip, but was getting incomprehensible error messages So I am sort of stuck as to where to go from here, and I would appreciate any experience anyone has with this sort of thing. Furthermore, I haven't actually been able to find a single example of a tutorial or case on github that uses both cyclic rotational conditions and dynamic Meshing. Below I have included - fvSolution, fvSchemes, controlDict boundary File, boundary conditions, image of a few time steps into moveMesh command (with the top face of the domain removed), SHM dict and checkMesh output, dynamicMeshDict The sequence I use to create the mesh is: blockMesh surfaceFeatures decomposePar mpirun -np 4 snappyHexMesh -parallel -overwrite > log.shm reconstructParMesh -constant checkMesh -writeSets vtk > log.checkmesh createBaffles -overwrite splitBaffles -overwrite Thanks again, and if anyone wants more information and thinks they could help me, I can upload my entire case to github if needed. Thanks fvSolution Code:
solvers { p { solver PCG; preconditioner DIC; tolerance 1e-07; relTol 0; maxIter 50; } pFinal { solver PCG; preconditioner DIC; tolerance 1e-07; relTol 0; maxIter 50; } "pcorr.*" { solver PCG; preconditioner DIC; tolerance 1e-06; relTol 0; minIter 3; } U { solver PBiCGStab; preconditioner DILU; tolerance 1e-07; relTol 0; maxIter 10; } UFinal { solver PBiCGStab; preconditioner DILU; tolerance 1e-07; relTol 0; maxIter 0; } k { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0; } epsilon { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0; } nuTilda { solver PBiCG; preconditioner DILU; tolerance 1e-20; relTol 0; maxIter 5; } nuTildaFinal { solver PBiCG; preconditioner DILU; tolerance 1e-20; relTol 0; maxIter 5; } yPsi { solver PCG; preconditioner DIC; tolerance 1e-06; relTol 0; minIter 2; } } PIMPLE { //If enable you will need to add UFinal momentumPredictor yes; consistent yes; //If you set nOuterCorrectors to 1 is equivalent to piso nOuterCorrectors 3; // for best results, set outer correctors to at least 5 for moving bodies (wolf Dynamics) nCorrectors 3; // 4 or more for highly transient flows or strongly coupled problems (WD) nNonOrthogonalCorrectors 2; // at least 1, increase value for bad quality meshes //pRefCell 0; //pRefValue 0; correctPhi yes; checkMeshCourantNo yes; } relaxationFactors { fields { ".*" 0.9; //p 0.3; } equations { ".*" 0.9; //U 0.7; //k 0.7; //omega 0.7; } } // ************************************************************************* // Code:
ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) Gauss linear; div(phi,k) Gauss linear; div(phi,epsilon) Gauss linear; div(phi,nuTilda) Gauss linear; div((nuEff*dev(grad(U).T()))) Gauss linear; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear limited 0.5;; /* laplacian(nu,U) Gauss linear corrected; laplacian(rAU,pcorr) Gauss linear corrected; laplacian(rAUf,pcorr) Gauss linear corrected; laplacian(rAU,p) Gauss linear corrected; laplacian(nuEff,U) Gauss linear limited 0.5; laplacian((1|A(U)),p) Gauss linear limited 0.5; laplacian(DkEff,k) Gauss linear limited 0.5; laplacian(DepsilonEff,epsilon) Gauss linear limited 0.5; laplacian(DREff,R) Gauss linear limited 0.5; laplacian(DnuTildaEff,nuTilda) Gauss linear limited 0.5; laplacian(yPsi) Gauss linear limited 0.5; laplacian((1|((1|(1|A(U)))-H(1))),p) Gauss linear limited 0.5; laplacian((1|max(((1|(1|A(U)))-H(1)),(0.1|(1|A(U))))),p) Gauss linear limited 0.5; */ } interpolationSchemes { default linear; } snGradSchemes { default limited 0.5; } fluxRequired { default no; pcorr; p; } wallDist { method Poisson; } // ************************************************************************* // Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application pimpleFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 1003; deltaT 0.0005; writeControl runTime; writeInterval 0.01; purgeWrite 0; writeFormat binary; writePrecision 8; writeCompression uncompressed; timeFormat general; timePrecision 6; //runTimeModifiable yes; //adjustTimeStep yes; //maxCo 5; //unstable for 5> Can run up to 15 //(max courant number) //maxDeltaT 0.01; // ************************************************************************* // functions { /* */ }; checkMesh Code:
Create time --> FOAM Warning : From function static Foam::instantList Foam::timeSelector::select0(Foam::Time&, const Foam::argList&) in file db/Time/timeSelector.C at line 269 No time specified or available, selecting 'constant' Create polyMesh for time = constant Reconstructing and writing vtk representation of all faceSets and cellSets. Time = 0s Mesh stats points: 1281656 faces: 3306166 internal faces: 3066597 cells: 1012712 faces per cell: 6.2927693 boundary patches: 6 point zones: 0 face zones: 1 cell zones: 1 Overall number of cells of each type: hexahedra: 899961 prisms: 10677 wedges: 0 pyramids: 0 tet wedges: 11 tetrahedra: 0 polyhedra: 102063 Breakdown of polyhedra by number of faces: faces number of cells 4 81 5 73 6 8183 7 235 8 43 9 84928 12 8122 15 396 18 2 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology outercyl 22402 23515 ok (non-closed singly connected) inlet 3575 4084 ok (non-closed singly connected) outlet 3529 4056 ok (non-closed singly connected) leftperiodic 102419 103147 ok (non-closed singly connected) rightperiodic 101922 102647 ok (non-closed singly connected) blade 5722 5762 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-16.549999 -16.859896 -4.8514801e-05) (17.15 25.150302 16.849342) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (5.2536918e-16 -1.0812025e-16 5.2740338e-13) OK. Max cell openness = 3.7686215e-16 OK. Max aspect ratio = 10.863457 OK. Minimum face area = 5.622304e-06. Maximum face area = 0.55301834. Face area magnitudes OK. Min volume = 1.7716102e-06. Max volume = 0.37326841. Total volume = 18720.801. Cell volumes OK. Mesh non-orthogonality Max: 71.724563 average: 9.9607327 *Number of severely non-orthogonal (> 70 degrees) faces: 1. Non-orthogonality check OK. <<Writing 1 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 1.9453286 OK. Coupled point location match (average 0) OK. Mesh OK. End Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class volScalarField; object nuSgs; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 1.5e-3; boundaryField { AMI1 { type cyclicAMI; // value $internalField; } AMI2 { type cyclicAMI; // value $internalField; } blade { type nutUSpaldingWallFunction; value $internalField; } outercyl { type slip; } ///* "(leftperiodic|rightperiodic)" { type cyclicAMI; } // */ inlet { type calculated; value $internalField; } outlet { type calculated; value $internalField; } } // ************************************************************************* // p Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 7 0); boundaryField { AMI1 { type cyclicAMI; // value $internalField; } AMI2 { type cyclicAMI; // value $internalField; } blade { type movingWallVelocity; value uniform (0 0 0); } outercyl { type slip; } ///* "(leftperiodic|rightperiodic)" { type cyclicAMI; } //*/ inlet { type fixedValue; value $internalField; } outlet { type zeroGradient; } } Code:
mover { type motionSolver; libs ("libfvMeshMovers.so" "librigidBodyMeshMotion.so"); motionSolver solidBody; cellZone cell_inner_volume; solidBodyMotionFunction rotatingMotion; nonRotatingPatches (leftperiodic rightperiodic); origin (0.3 0 0); axis (0 1 0); omega constant -7.54; } Code:
FoamFile { format ascii; class dictionary; object createBafflesDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Whether to convert internal faces only (so leave boundary faces intact). // This is only relevant if your face selection type can pick up boundary // faces. internalFacesOnly true; // Baffles to create. baffles { rotating { //- Use predefined faceZone to select faces and orientation. type faceZone; zoneName face_inner_volume; //zoneName cell_inner_volume; //zoneName inner_volume; patches { master { //- Master side patch name AMI1; type cyclicAMI; matchTolerance 0.5;// 0.0001 neighbourPatch AMI2; //transform noOrdering; //v2112 < transform none; //v10 } slave { //- Slave side patch name AMI2; type cyclicAMI; matchTolerance 0.5; neighbourPatch AMI1; //transform noOrdering; //v2112 < transform none; //v10 } } } } |
January 23, 2024, 11:57 |
Saeed Jamshidi
Rep Power: 7 |
Dear nialloneill,
Have you tried a simple case ever? I mean without a motion (stationary case)? However, I friendly recommend you to start with the available tutorials and get inspiration from them. Here is similar tutorial that you can have a look at it: Code:
\\wsl$\Ubuntu-18.04\home\saeedfoam\OpenFOAM-v2112\tutorials\incompressible\pimpleFoam\RAS\wingMotion |
January 23, 2024, 17:53 |
#3 | |
Niall O'Neill
Rep Power: 3 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
