February 2, 2024, 05:10 |
OF11 MRF problems
Giles Richardson
Rep Power: 13 |
I am running an MRF propeller demo case at quite low rpm (600rpm) in simpleFoam.
It works fine in OF10 but doesn't work in OF11. Its a continuous mesh, so not using NCC or AMI. I'm just specifying the rotation on an MRF zone (defined using cylinder within SHM). https://drive.google.com/file/d/1h4l...ew?usp=sharing https://drive.google.com/file/d/1KnB...ew?usp=sharing |
February 5, 2024, 06:06 |
Giles Richardson
Rep Power: 13 |
Well thanks to a testcase (from Pedro) I realised what the problem was.
You need to have this BC in the "U" file. I never heard of this one before, but in OF11 this is the BC needed to get MRF to work. Thanks Pedro! type MRFnoSlip; value uniform (0 0 0); Here is a nice image the surface velocity: https://drive.google.com/file/d/1AGY...ew?usp=sharing |
mrf simplefoam |
MRF for transient , is it possible? | roshanak878 | Main CFD Forum | 2 | July 6, 2022 12:52 |
simpleFoam: Influence of MRF region dimensions on simulation results | Krao | OpenFOAM Running, Solving & CFD | 4 | March 29, 2022 21:33 |
[snappyHexMesh] cannot find MRF cellZone | Ahyar | OpenFOAM Meshing & Mesh Conversion | 2 | November 2, 2021 02:28 |
Modeling Wheel Rotation using MRF | Lukas7117 | FLUENT | 0 | December 1, 2020 10:19 |
Modeling Wheel Rotation using MRF | Lukas7117 | Main CFD Forum | 0 | December 1, 2020 10:03 |
