Openfoam 10/11 - Non-Newtonian Fluid setup
Old   February 12, 2024, 11:20
Default Openfoam 10/11 - Non-Newtonian Fluid setup
Nidal
Nidalsb is on a distinguished road
Hi everyone,
I am struggling to setup a non-newtonian fluid within multiphaseInterFoam. It was straightforward before Openfoam 10 was released, were it was setup within transportProperties.
This new method where the non-newtonian model is setup within momentum transport is too confusing.
Can someone please help me figure it out. I found a tutorial implementing a non-newtonian fluid within pimpleFoam. But that also makes no sense as the viscosity model is set to "constant"
Here is what I have, it managed to run but I am not sure if the crossPowerLaw is applied.
MomentumTransport:
simulationType laminar;
laminar
    model               generalisedNewtonian;
    viscosityModel      CrossPowerLaw;
    CrossPowerLawCoeffs
        nu0         [0 2 -1 0 0 0 0]  1-05;
        nuInf       [0 2 -1 0 0 0 0]  1E-12;
        m           [0 0 1 0 0 0 0]   1.00E-03;
        n           [0 0 0 0 0 0 0]   0.7;
physicalProperties (Non-newtonian Fluid):
viscosityModel  constant;
rho           1000;
m             1.00E-03;
n             0.7;
nu            1E-05;
nuInf         1E-12;
I manage to run the simulation just fine with the following output, but I do not get any output from openfoam to show me the non-newtonian viscosity so I am not sure if that is even implemented:
PIMPLE: Operating solver in transient mode with 6 outer correctors
Reading field p_rgh
Reading field U
Selecting viscosity model Newtonian
Selecting viscosity model constant
Selecting turbulence model type laminar
Selecting laminar stress model generalisedNewtonian
Selecting generalised Newtonian model CrossPowerLaw
Reading g
Reading hRef
Calculating field g.h
No MRF models present
No fvModels present
No fvConstraints present
I would appreciate any help, thank you!
Nidalsb is offline   Reply With Quote
multiphaseinterfoam, non-newtonian, openfoam10
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 03:18
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 13:36
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
