transitioning from cyclicAMI to cyclicGgi [v2312 ESI -> Extend 5.0] |
February 12, 2024, 03:41 |
Franco
Rep Power: 6 |
I had a functional case in OF ESIv2312 and I want to run it in the Extend version. The case uses non-conformal cyclic BC to create a periodic geometry (tube) between the inlet and the outlet.
my complete original (ESI) createPatchDict and the Extended versions: createPatchDictESI.txt createPatchDictExtend.txt Last edited by otaolafr; February 12, 2024 at 06:58. |
cyclicami, cyclicggi, esi openfoam, foam-extend 5.0 |
Using createPatch and cyclicAMI in FOAM Extend to create periodicbox | manuc | OpenFOAM Running, Solving & CFD | 1 | April 12, 2022 11:36 |
cyclicAMI - kOmegaSST - divergence issue | cyln | OpenFOAM Running, Solving & CFD | 1 | October 5, 2018 10:06 |
inlet pressure is higher than outlet pressure for fan | sivakumar | OpenFOAM Pre-Processing | 16 | December 30, 2017 14:16 |
