March 13, 2024, 05:00 |
weird axis velocity/pressure
Luke Hirl
Rep Power: 2 |
I am trying to validate an EHD Solver based on Interfoam I created.
For that I want to simulate the deformation of a droplet which is stressed by an electric field. However the simulation is resulting in what is best described as a weird standing wave between the droplet and electrodes, which points perpendicular to the axis and radial direction. This velocity switches from negative to positive everry cell along the axis. The pressure is below 0 in these "standing waves" While I first thought it might be a result of the added Maxwell term to the Velocity equation, there is no correlation to be found. I assume it is some kind of numerical oscillation, but dont know where it is coming from. Test Case and solver can be found here: https://www.dropbox.com/scl/fi/fhjoj...2vsi2ltgj&dl=0 |
axis symmetric, ehd, interfoam |
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" | ds4719 | Main CFD Forum | 14 | February 18, 2022 18:05 |
[DesignModeler] axis display disparity of model and triad | ram881973 | ANSYS Meshing & Geometry | 14 | November 18, 2020 01:21 |
[blockMesh] Wierd behaviour of blockMesh creating axis in wedge | rcastilla | OpenFOAM Meshing & Mesh Conversion | 1 | December 4, 2018 06:24 |
[Other] dynamic Mesh with angular velocity not parallel to x axis | donQi | OpenFOAM Meshing & Mesh Conversion | 5 | October 2, 2014 23:19 |
Axis treatment in axisymmetrical problem | Jakob1 | OpenFOAM Pre-Processing | 2 | August 25, 2014 03:09 |
