Issue with Phase Segregation in Oil-Water Multiphase Simulation using interFoam |
April 28, 2024, 07:49 |
Sandeep Raheja
Rep Power: 2 |
Hello everyone,
I am a newbie to CFD and Openfoam. I am currently working on a multiphase simulation in OpenFOAM using the `interFoam` solver to model the segregation of oil and water in a still atmospheric tank without any inlet/outlet flows. The tank dimensions are 4m x 2m with a height of 1m, and it is initially filled with an oil-water mixture where oil comprises 50% of the total volume. Despite setting up the simulation to observe the phases separating over time, I have not seen any segregation between oil and water, as the oil should float to the top due to its lower density. Here are some details of my setup: - Solver: interFoam - Initial Condition: Uniform distribution of alpha.oil = 0.5 across the domain. - Boundary Conditions: Walls are set to noSlip, and the top is a free-slip boundary at atmospheric pressure. - Mesh: Structured mesh with 20 cells/m resolution. I have tried to check the physical properties, boundary conditions, and numerical schemes, but the phases remain mixed without clear separation. Gravity is also applied in the constant/g file in negative Z direction. I am looking for insights or suggestions that might help in diagnosing and resolving this issue. My next goal is to also add inlet/outlet nozzles and a weir plate also which I will model after I fix such a simple scheme Could there be an issue with my solver settings, BCs or the way the initial conditions are applied? I am attaching the complete case setup files along with the blockmesh dictionary. Any advice on adjustments to the setup or further diagnostic steps would be greatly appreciated! |
interfoam solver, multi phase, openfoam v2312 |
What are the best settings for a channel flow simulation? | Ashkan Kashani | CFX | 3 | October 13, 2022 21:36 |
Weird appearance of water phase in cells when using InterFoam | madfan123 | OpenFOAM Running, Solving & CFD | 1 | January 24, 2021 09:51 |
Oil and water separation multiphase | Shahla | Fluent Multiphase | 0 | May 22, 2018 11:45 |
Simulation of dispersion of oil droplets in water -two issues | milan.2012 | CFX | 8 | April 12, 2018 18:38 |
Simulation Water and Oil URGENT problem | alexandrelp | CFX | 3 | May 5, 2014 21:20 |
