InterFoam + cyclicAMI of an open channel (river) |
April 20, 2024, 10:48 |
Hi everyone,
I am trying to simulate free-surface flow over a river. The riverbed is very detailed, obtained from high-resolution topographic data. The mesh resolution is 2 mm across the domain. The idea is to run a range of velocities and flow depths, with which I will obtain drag and friction factor exerted by the riverbed. I would like to simulate the river reach only, without adding a channel upstream to allow flow development. I am also interested in capturing the free surface distortions caused by the bed topography once the flow is stabilised. For this purpose, I am using interFoam and cyclicAMI at the inlet and outlet. The turbulence model is RNG k-epsilon. For the sake of the simulation, the bed slope is 2 degrees. The issue with the simulation is that water (alpha.water > 0.5) and, thus, the free surface are not being correctly “mapped” from outlet to inlet, though the patches show similar values of the variables, which is strange. As a result, the water level is near zero near the inlet because water does not recycle from the outlet. I have tried both createPatchDict and the manual editing of the boundary file to implement cyclicAMI. I use setFieldsDict to define the initial water volume. Please find attached some relevant files. If it’s something related to the implementation of the cyclicAMI or another misstep, I’d be happy if you could help me identify the possible cause, and I’m also happy to provide further details of the model. Cheers, Clarinha Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2306 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; arch "LSB;label=32;scalar=64"; class polyBoundaryMesh; location "constant/polyMesh"; object boundary; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 6 ( inlet { type cyclicAMI; neighbourPatch outlet; transform translational; separationVector (2.01876947 0 -0.07049698); nFaces 1596; startFace 1923927; } outlet { type cyclicAMI; neighbourPatch inlet; transform translational; separationVector (-2.01876947 0 0.07049698); nFaces 1560; startFace 1925523; } top { type patch; nFaces 46056; startFace 1927083; } leftWall { type wall; inGroups 1(wall); nFaces 5633; startFace 1973139; } rightWall { type wall; inGroups 1(wall); nFaces 5797; startFace 1978772; } bed { type wall; inGroups 1(wall); nFaces 46288; startFace 1984569; } ) // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2306 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0.001; boundaryField { "(inlet|outlet)" { type cyclicAMI; } top { type totalPressure; p0 uniform 0; } "(leftWall|rightWall|bed)" { type fixedFluxPressure; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2306 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object alpha.water; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { "(leftWall|rightWall|bed)" { type zeroGradient; } top { type inletOutlet; inletValue uniform 0; value uniform 0; } "(inlet|outlet)" { type cyclicAMI; } } // ************************************************************************* // |
April 22, 2024, 05:59 |
Vinayak Ramachandran
Rep Power: 2 |
Hello Clarinha,
This is unfortunately a know shortcoming in the formulation of the interFoam solver. The problem arises because the solver uses a single pressure system for simplicity; combining the static and hydrostatic pressure to give the modified pressure (p_rgh). In the solver algorithm, the modified pressure equation is solved. When you have a cyclic boundary where the two boundaries are at different heights (physically) there is a pressure jump across the boundaries due to the different values of h at either sides of the boundary, leading to unphysical behaviours. Some workarounds have been suggested in previous discussions in the community forums (Ref thread https://www.cfd-online.com/Forums/sh...d.php?p=335817.), but I have not tried to implement them so cannot comment on their accuracy. Good luck! |
cyclicami, free surface, interfoam, open channel, periodic |
[OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 16:05 |
[Other] Tabulated thermophysicalProperties library | chriss85 | OpenFOAM Community Contributions | 62 | October 2, 2022 03:50 |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 35 | April 29, 2022 15:35 |
Questions about simulation free surface open channel flow by interFoam and pimpleFoam | IsanM | OpenFOAM Programming & Development | 0 | September 10, 2020 03:13 |
Open Channel Flow using InterFoam type solver | sxhdhi | OpenFOAM Running, Solving & CFD | 3 | May 5, 2009 21:58 |
