one-way coupled particle tracking
Like Tree1Likes
  • 1 Post By Raduviant
Old   March 28, 2024, 07:08
Default one-way coupled particle tracking
Duve Ribberink
Raduviant is on a distinguished road
Hi!
I am trying to do a particle tracking using one-way coupling. Searching the forum, I found this thread discussing the same thing: Particle tracking
In the thread, icoUncoupledKinematicParcelFoam is suggested as an appropriate solver. I tried to use the same method and obtained this result:
The figure shows the velocity magnitude of both the particle and 2-D flow. I applied a glyph filter over the particle track and made the radius scale with the velocity.
There are two problems:
1. I cannot specify the 3-dimensional initial position of the particle. I did specify 3 dimensions in constant -> kinematicCloudPositions, but only the x-value seems to have any effect.
2. The straight particle track suggests fully passive transport, because I varied the density and hoped to see vertical motion. (I tried running with rho0 values matching both g/cm3 and kg/m3, but it made no difference for vertical transport).
Since the particle is slowly accelerating in a somewhat uniform flow, I don't think it is a passive particle simulation as the description of the solver describes: https://www.openfoam.com/documentati...8C_source.html
So my current conclusion is that the particle is somehow modelled in 1 dimension only. I don't understand why this is the case.
I will include my kinematicCloudProperties file below, but I am not sure the error is in there. If anyone has a suggestion as to why my simulation behaves like this, or can direct me to other input files I should check, I will be very thankful .
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    //location    "constant";
    object      kinematicCloudProperties;
solution
    active          true;
    coupled         false;
    transient       yes;
    cellValueSourceCorrection off;
    maxCo           0.3;
    interpolationSchemes
        rho             cell;
        U               cellPoint;
        mu              cell;
    integrationSchemes
        U               Euler;
constantProperties
    rho0            1500;
    youngsModulus   6e8;
    poissonsRatio   0.35;
subModels
    particleForces
        sphereDrag;
        gravity;
    injectionModels
        model1
            type            manualInjection;
            massTotal       0;
            parcelBasisType fixed;
            nParticle       1;
            SOI             0;
            positionsFile   "kinematicCloudPositions";
            U0              (0 0 0);
            sizeDistribution
                type        fixedValue;
                fixedValueDistribution
                    value   0.003;
    dispersionModel none;
    patchInteractionModel none;
    surfaceFilmModel none;
    stochasticCollisionModel none;
    collisionModel none;
    pairCollisionCoeffs
        // Maximum possible particle diameter expected at any time
        maxInteractionDistance  0.0001;
        writeReferredParticleCloud no;
        pairModel pairSpringSliderDashpot;
        pairSpringSliderDashpotCoeffs
            useEquivalentSize   no;
            alpha               0.12;
            b                   1.5;
            mu                  0.52;
            cohesionEnergyDensity 0;
            collisionResolutionSteps 12;
        wallModel    wallLocalSpringSliderDashpot;
        wallLocalSpringSliderDashpotCoeffs
            upperWall
                youngsModulus   1e10;
                poissonsRatio   0.23;
                alpha           0.12;
                b               1.5;
                mu              0.43;
            lowerWall
                youngsModulus   1e10;
                poissonsRatio   0.23;
                alpha           0.12;
                b               1.5;
                mu              0.43;
            frontAndBack
                youngsModulus   1e10;
                poissonsRatio   0.23;
                alpha           0.12;
                b               1.5;
                mu              0.1;
cloudFunctions
Raduviant is offline   Reply With Quote
Old   April 22, 2024, 08:20
Duve Ribberink
Just in case anyone finds this and has the same problem, I found the problem:
I had three 'empty' boundaries, two of which were in the y-dimension to simulate 2D flow, and the final one in the z-dimension at the 'top' boundary to avoid using a 'wall' boundary and creating (unwanted) pipe-like flow. For each dimension in which at least one boundary was 'empty', the particle tracker fixed the particle in that dimension. So, the solution is having functional boundaries (non-empty) in each dimension you wish to track particle movement.
I have since switched to simulating multiphase flow to more accurately represent my system, which also solves the top boundary problem.
francescomarra likes this.
particle tracking;
Particle Field Variables in Lagrangian Particle Tracking - CFX lyday011 CFX 10 May 31, 2022 13:51
DPM particle tracking "flow time step size" and " particle time step size" monali2015m FLUENT 0 February 26, 2022 16:37
Eulerian Multiphase Model vs Lagrangian Particle Tracking ajjadhav CFX 14 December 7, 2020 16:22
injection problem Mark New FLUENT 0 August 4, 2013 01:30
Particle tracking INTEGER limitation warning Peter023 FLUENT 0 June 24, 2013 03:59
