April 8, 2024, 09:28 |
Sinking object with 6dof
Alejandro Valeije
Rep Power: 11 |
Hi everyone,
I'm trying to solve a transient problem where a ball is sinking into a domain. My initial guess has been trying to use pimpleFoam with a dynamic mesh and the 6dof module. However, no matter what density I use, the object doesn't sink. I don't know if the solver is not able to recognize the gravity or I'm doing something wrong. I have also tried to do this using interFoam and modifying the floatingObject tutorial in order to sink it, but the problem remains the same. Has anyone faced this type of case before? Best regards, |
April 9, 2024, 05:12 |
Yann
Rep Power: 26 |
Hello Alejandro,
You are probably doing something wrong, I did a similar case before, based on the floatingObject tutorial. It should also work with pimpleFoam. Regards, Yann |
unable to run dynamic mesh(6dof) and wave UDF | shedo | Fluent UDF and Scheme Programming | 0 | July 1, 2022 17:22 |
[OpenFOAM.org] Instructions to install OpenFOAM-2.4.x on CentOS-6.10 | redbullah | OpenFOAM Installation | 9 | September 7, 2019 17:18 |
[foam-extend.org] Error compiling OpenFOAM-1.6-ext | Canesin | OpenFOAM Installation | 137 | January 20, 2016 14:56 |
Compilation error OF1.5-dev on Suse10.3 | darenyang | OpenFOAM Installation | 0 | April 29, 2009 04:55 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
