Segfault when using codedFixedValue and decomposePar
Old   June 15, 2023, 11:25
Post Segfault when using codedFixedValue and decomposePar
marineone is on a distinguished road
Hello guys,
I am trying to simulate a flow over a wall mounted cube. The flow domain is simple box around this cube which I have generated with blockMesh. Now I want to use the codedFixedValue functionality to have a time dependent velocity BC at the inlet as can be seen below.
inlet
        type            codedFixedValue;
        value           uniform (0 0 0);
        name            periodicInletVel;
        codeOptions
                -I$(LIB_SRC)/finiteVolume/lnInclude \
                -I$(LIB_SRC)/meshTools/lnInclude
        codeInclude
                #include "fvCFD.H"
                #include <cmath>
                #include <iostream>
                #include "vector.H"
        code
                const fvPatch& boundaryPatch = this->patch();
                const vectorField& Cf = boundaryPatch.Cf();
                vectorField& field = *this;
                const scalar t = this->db().time().value();
                const scalar speed = 5;
                forAll(Cf, faceI)
                        field[faceI] = sin(t) * vector(speed, 0, 0);
Trying to decompose the mesh in 8 equal parts with this code
numberOfSubdomains 8;
method          simple;
// method          metis;
// method          ptscotch;
simpleCoeffs
    n               (2 2 2);
    delta           0.001;
hierarchicalCoeffs
    n               (1 1 1);
    delta           0.001;
    order           xyz;
manualCoeffs
metisCoeffs
leads to a Segmentation fault error. I could not figure out where exactly the problem occurs:
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigSegv::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::Hasher(void const*, unsigned long, unsigned int) at ??:?
#4  Foam::HashTable<Foam::tmp<Foam::fvPatchField<Foam::Vector<double> > > (*)(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&), Foam::word, Foam::string::hash>::set(Foam::word const&, Foam::tmp<Foam::fvPatchField<Foam::Vector<double> > > (* const&)(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&), bool) at ??:?
#5  ? at 0/U/boundaryField/inlet:112
#6  ? in "/lib64/ld-linux-x86-64.so.2"
#7  ? in "/lib64/ld-linux-x86-64.so.2"
#8  ? in "/lib64/ld-linux-x86-64.so.2"
#9  ? in "/lib64/ld-linux-x86-64.so.2"
#10  ? in "/lib64/ld-linux-x86-64.so.2"
#11  ? in "/lib/x86_64-linux-gnu/libdl.so.2"
#12  ? in "/lib64/ld-linux-x86-64.so.2"
#13  ? in "/lib/x86_64-linux-gnu/libdl.so.2"
#14  dlopen in "/lib/x86_64-linux-gnu/libdl.so.2"
#15  Foam::dlOpen(Foam::fileName const&, bool) at ??:?
#16  Foam::dlLibraryTable::open(Foam::fileName const&, bool) at ??:?
#17  Foam::codedBase::loadLibrary(Foam::fileName const&, Foam::string const&, Foam::dictionary const&) const at ??:?
#18  Foam::codedBase::updateLibrary() const at ??:?
#19  Foam::fvPatchField<Foam::Vector<double> >::adddictionaryConstructorToTable<Foam::codedFixedValueFvPatchField<Foam::Vector<double> > >::New(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
#20  Foam::fvPatchField<Foam::Vector<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
#21  Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::Boundary::readField(Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
#22  Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readFields(Foam::dictionary const&) at ??:?
#23  Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readFields() at ??:?
#24  Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) at ??:?
#25  ? at ??:?
#26  ? at ??:?
#27  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#28  ? at ??:?
Segmentation fault
I already did some trial and error (e.g. excluding libraries, playing with the decomposeParDict values) and but none of them could fix the problem. Is there some additional code missing? Any help would be highly appreciated!
marineone is offline   Reply With Quote
Old   June 26, 2023, 06:21
Has anyone an idea?
Old   April 10, 2024, 01:22
Quincy
quwsk is on a distinguished road
I also encountered a same problem. Did you figured out the solution?
quwsk is offline   Reply With Quote
Old   April 12, 2024, 05:45
Amirhossein Taran
amirhosseintaran is on a distinguished road
Originally Posted by marineone View Post
Has anyone an idea?
Instead of using a Simple decomposition method, can you check whether you have the same problem with scotch or not?
Scotch has no mandatory entry, so change simple to Scotch and thats it.
Bests,
Amirhossein.
amirhosseintaran is offline   Reply With Quote
codedfixedvalue, decomposepar
pipeCyclic tutorial codeStream error in codedFixedValue BC specification fivewood OpenFOAM Running, Solving & CFD 0 January 15, 2014 22:36
