OpenFOAM v2106: Renumbering Mesh while using dynamicRefineFvMesh
Old   May 17, 2024, 19:02
Default OpenFOAM v2106: Renumbering Mesh while using dynamicRefineFvMesh
Amr Shaalan
AmrShaalan is on a distinguished road
I have 2 cases with one using dynamicRefineFvMesh and another not using dynamicRefineFvMesh. The case without refinement is at about 6 million cells and takes an average 3 seconds per tiemstep. I coarsened the mesh and started the dynamicRefineFvMesh case so it starts at a lower cell count (3 million) and rely on automatic refinement instead.
The automatic refinement case starts really fast (as expected). But even with the first refinement cycle that adds about 500,000 cells, I see that the speed goes dramatically down (starts taking 5 seconds per timestep at a much lower cell count than the static mesh). I understand that adaptive mesh refinement adds a time penalty, but it should be for the time taken to refine but the timestep itself should be comparable to the static mesh. I think the culprit is that the refined mesh is not optimized by the "renumberMesh" so I was wondering if I it is possible to do automatic renumbering after each refinement attempt?
Note: I am of course comparing the two cases with the same hardware (same computing nodes and number of cores).
Would really appreciate any help or if someone points out something wrong in what I said.
Thanks!
AmrShaalan is offline   Reply With Quote
dynamicrefinefvmesh, renumbermesh
OpenFOAM v2106: Running Adaptive Mesh Refinement with AMI present AmrShaalan OpenFOAM Running, Solving & CFD 1 April 25, 2024 16:40
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 08:51
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology wyldckat OpenFOAM 17 November 10, 2017 15:54
[Commercial meshers] converting ICEM mesh to OpenFOAM bmikuz OpenFOAM Meshing & Mesh Conversion 9 May 10, 2016 16:47
[Salome] Mesh conversion Salome to OpenFOAM VMartinez OpenFOAM Meshing & Mesh Conversion 11 April 21, 2014 02:54
