Porosity
Old   April 11, 2008, 08:59
Default Hey, I have been browsing a
Mads Reck
gabriel_stokes is on a distinguished road
Hey,
I have been browsing around this forum to try to find out how to run a simulation on a simple domain with a porous zone in OF.
In Fluent I can define a porous zone with ease, but I was wondering if anyone would be so kind, to explain how I proceed with OpenFoam.
I guess I need to move from my current favourite: simpleFoam, to a dedicated solver, right? Secondly, it seems that I need to setup the porosity parameters in a file, 'porousZones', which I should create in the constant/-directory, right? But, well - I need a straight-forward cookbook example, if possible.
Thanks, and best regards
Mads
gabriel_stokes is offline   Reply With Quote
Old   April 14, 2008, 17:12
Default Hi, 1.You can`t solve a porou
Paul Mauk
plmauk is on a distinguished road
1.You can`t solve a porous case with simpleFoam. You should use something like rhoImplicitPorousSimpleFoam.
2.You need cellSets and cellZones to define the geometrie of the porous zone inside of your mesh.
3.You really need to create file "porousZones" and place it to the constant directory. Deciding is, that you set coefficients d and f (Darcy`law)
and vectors e1 and e2.
plmauk is offline   Reply With Quote
Old   April 15, 2008, 06:58
Default Hi, Thanks a lot for your k
Mads Reck
Thanks a lot for your kind answer.
1. It is just that in the tutorials (for rhoImplicitPorousSimpleFoam), it seems that some compilation is needed, is that so?
2. I guess fluent3DToFoam can generate the cellSets and the cellZones files, right?
3. Then I just need to define the zones I want to be porous in the porousZones files, correct?
And then run rhoImplicitPorousSimpleFoam as it was simpleFoam...?
/Mads
Old   April 15, 2008, 11:54
Default Hi, 1.I don't think, the comp
Paul Mauk
1.I don't think, the compilation is needed, try to run tutorial examples from the rhoImplicitPorousSimpleFoam - directory. If it works, it don't have to be compiled.
2.fluent3DToFoam generates cellZones and faceZones, but no sets were generated. If you have a cellZone on the right place after convertion, you should just name it, as the porousZoneDict was named.
3.The answer is allready given
regards
Paul.
Old   April 29, 2008, 08:43
Default Okay, thanks. The rhoImplic
Mads Reck
Okay, thanks.
The rhoImplicitPorousSimpleFoam appears to be a compressible solver.
What if I want to run incompressible?
/Mads
Old   May 5, 2008, 07:40
Default You need a new solver in this
Paul Mauk
You need a new solver in this case.
Try to combine simpleFoam and rhoPorousSimpleFoam.
If you are not able to do that, I can send you my own solver called porousSimpleFoam.
Old   September 16, 2008, 09:42
Default Hi, I have the same problem
Nicolai Heilskov
heilskov7 is on a distinguished road
I have the same problem as Mads Reck outlined - I like to do an incompressible computation including porous cells. Thus if it is possible it would be a great help if i was able to get the solver 'porousSimpleFoam' you mentioned to Mads.
Nicolai
heilskov7 is offline   Reply With Quote
Old   September 17, 2008, 06:01
Default please, write to my e-mail (mk
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
please, write to my e-mail (mkraposhin@inbox.ru) and i will send you solver
mkraposhin is offline   Reply With Quote
Old   November 4, 2008, 11:20
Default Hi, Is there any porousSimp
ayoros is on a distinguished road
Is there any porousSimpleFoam solver available for OpenFOAM 1.5 ?
I'm really struggling with combining simpleFoam and rhoPorousSimpleFoam.
Thanks,
Fabien
ayoros is offline   Reply With Quote
Old   November 17, 2008, 03:37
Default Hi Paul, I am using OpenFoa
Mahendra
mahendra is on a distinguished road
Hi Paul,
I am using OpenFoam 1.5 and I am unable to find a porousSimpleFoam solver for incompressible porous cases there?
Can you send me the solver if you have one?
My email mahendra.wankhede@gmail.com
Regards,
Mahendra.
mahendra is offline   Reply With Quote
Old   March 13, 2009, 14:29
Default Link to porousSimpleFoam solve
  #11
mkraposhin's Avatar
Matvey Kraposhin
Link to porousSimpleFoam solver for OpenFOAM 1.4.1
http://www.os-cfd.narod.ru/small_fil...SimpleFoam.tgz
Old   March 13, 2009, 14:31
  #12
mkraposhin's Avatar
Matvey Kraposhin
Old   March 16, 2009, 07:51
Default porousSimpleFoam for OpenFOAM 1.5
  #13
Vincent RIVOLA
vinz is on a distinguished road
Hi everyone,
Here is the incompressible porous solver I derived for OpenFOAM 1.5 :
http://www.rtech-engineering.com/Ope...SimpleFoam.zip
I tested it with both implicit and explicit test cases and apparently it works fine.
Hope this helps.
Vincent
vinz is offline   Reply With Quote
Old   October 9, 2009, 04:05
Oleksiy Kurenkov
evrikon is on a distinguished road
Send a message via Skype™ to evrikon
Originally Posted by vinz View Post
Hi everyone,
Hope this helps.
Vincent
Hi Vincent,
I wrote incompressible solver too. I compared your solver with my formulation and recognized the only difference is in the pEqn.H, line 1:
I have copied in my version from simpleFoam solver the following line
//p.boundaryField().updateCoeffs();
Do you know some reason why it should be not included in the cold porous simple solver?
Regards, Oleksiy
Cheers, Oleksiy
evrikon is offline   Reply With Quote
Old   February 1, 2010, 04:49
Default PorousSimpleFoam for OpenFOAM 1.6
  #15
Andrea Beretti
beretti_a is on a distinguished road
Hello foamers,
I tried the incompressible porous solver you posted here below but I get some problems while builiding it with OpenFOAM 1.6. I think this may be a problem related to the OpenFOAM version.
Has anybody else had the some problem? Does anybody know how to fix it?
Has anybody derived an incompressible porous solver for OpenFOAM 1.6?
Thanks in advance and best regards,
Andrea
beretti_a is offline   Reply With Quote
Old   February 1, 2010, 04:54
stawrogin is on a distinguished road
Hi Andrea,
if you use the git and OpenFOAM 1.6.x you will find a porousSimpleFOAM for incompressible media provided by OpenCFD.
Best regards
Stawrogin
stawrogin is offline   Reply With Quote
Old   February 3, 2010, 08:03
Default Porous media OpenFOAM-1.6.x
  #17
Andrea Beretti
Very thanks Stawrogin for your hint.
Best regards
Andrea
UDF for porosity cfd-novice FLUENT 2 August 20, 2009 03:19
porosity ravi FLUENT 2 December 13, 2007 20:50
porosity ravi FLUENT 0 December 13, 2007 01:31
help on porosity ravikanth FLUENT 0 January 21, 2005 12:14
Help on porosity Leon Mills Phoenics 1 June 18, 2002 08:59
