TimeVaryingMappedFixedValue
Like Tree3Likes
Old   August 8, 2007, 06:30
Default Hello, I have been looking
David Mulholland
irishdave is on a distinguished road
I have been looking at the timeVaryingMappedFixedValue fvPatch. I am currently making a program that will be used to create inlet data. This patch looks to be the perfect solution in order to use the created data within a case. My question is where can I find more documentation on the patch? I want to be able to create the constant/boundaryData/inlet files.
What is contained in the points file and is there an easy way to create one?
Why for the tutorial case simpleFoam/pitzDailyExptInlet/ which uses the BC do the files contain 70 values when the fvPatch faceCells() function returns 30 cells for the case?
I am currently trying to implement a inflow data generator for OpenFOAM which upon completion will be made available open-source to the OpenFOAM community.
Thanks
David
vivek05 and philippconen like this.
irishdave is offline   Reply With Quote
Old   August 9, 2007, 04:44
Default The points are the locations o
Mattijs Janssens
mattijs is on a distinguished road
The points are the locations of the data. The data at those points is in the time directory.
The patch interpolates the point data onto the face centre.
The point data comes from e.g. measurements.
mattijs is offline   Reply With Quote
Old   August 9, 2007, 06:06
Default Thank you Mattijs, I played ar
David Mulholland
Thank you Mattijs, I played around with it a bit and started to realize what what was going on.
Old   October 2, 2007, 09:24
Default Hello, I would like to use
Jerome
jerome is on a distinguished road
I would like to use timeVaryingMappedFixedValue for my inlet velocities and I want to set different velocity values for each time step of my simulation (in this case, deltaT = 0.0002 s).
I created the directories in constant/boundaryData/inlet/:
constant/boundaryData/inlet/points
constant/boundaryData/inlet/0/U
constant/boundaryData/inlet/0.0002/U
constant/boundaryData/inlet/0.0004/U
constant/boundaryData/inlet/0.0006/U
However, when I run the case, I have a problem at the first time step:
Starting time loop
Time = 0.0002
Courant Number mean: 0 max: 0.241854
--> FOAM FATAL IO ERROR : cannot open file
file: …/run/ExpeCylinder1uP7/constant/boundaryData/inlet/0.0004 at line0.
From function regIOobject::readStream(const word&)
in file db/regIOobject/regIOobjectRead.C at line 66.
FOAM exiting
It runs nevertheless if I only provide the directory "0" (constant inlet velocity values).
Could someone tell me the correct way to use this patch?
Thank you in advance,
Jerome
jerome is offline   Reply With Quote
Old   October 2, 2007, 11:47
Default Switch on the debug flag for t
Mattijs Janssens
Switch on the debug flag for timeVaryingMappedFixedValue. It should print
timeVaryingMappedFixedValueFvPatchField : In directory XXXX found times YYYYY. See if it includes your 0.0004 directory.
Does the $FOAM_TUTORIALS/simpleFoam/pitzDailyExptInlet case work if you add another time directory?
Old   October 4, 2007, 03:43
Default Hello, Thank you for your a
Jerome
Thank you for your answer,
Yes, I have the same problem with pitzDailyExptInlet: the simulation stopped at the first time step and said:
file: .../pitzDailyExptInlet/constant/boundaryData/inlet/2 at line 0.
FOAM exiting
I switched on the debug flag for timeVaryingMappedFixedValue. I obtain:
Reading field p
Reading field U
timeVaryingMappedFixedValue : construct from dictionary
timeVaryingMappedFixedValueFvPatchField : Read 100 sample points from ".../ExpeCylinder1uP7/constant/boundaryData/inlet/points"
timeVaryingMappedFixedValueFvPatchField : Used points (0.00138321 0.00138321 0) (0.00154865 0.00111043 0) (0.00167642 0.000812023 0) to define coordinate system with normal (0 0 -1)
readSamplePoints : Dumping triangulated surface to triangulation.stl
readSamplePoints : Dumping face centres to ".../ExpeCylinder1uP7/localFaceCentres.obj"
timeVaryingMappedFixedValueFvPatchField : In directory ".../ExpeCylinder1uP7/constant/boundaryData/inlet" found times
9
0
0.0002
0.0004
0.0006
0.0008
0.001
0.0012
0.0014
0.0016
findTime : Found time 0 inbetween index:0 time:0 and index:1 time:0.0002
checkTable : Reading startValues from "boundaryData/inlet/0"
checkTable : Reading endValues from "boundaryData/inlet/0.0002"
updateCoeffs : Sampled, interpolated values between start time:0 and end time:0.0002 with weight:0
updateCoeffs : set fixedValue to min0 0 0.0134146) max0 0 0.302318)
timeVaryingMappedFixedValue : copy construct, resetting internal field
Starting time loop
Time = 0.0002
findTime : Found time 0.0002 inbetween index:1 time:0.0002 and index:2 time:0.0004
checkTable : Setting startValues to (already read) "boundaryData/inlet/0.0002"
checkTable : Reading endValues from "boundaryData/inlet/0.0004"
file: .../ExpeCylinder1uP7/constant/boundaryData/inlet/0.0004 at line0.
FOAM exiting
Do you know what the problem could be?
Jerome
Old   October 4, 2007, 06:56
Default Sounds like a bug. Can you rep
Mattijs Janssens
Sounds like a bug. Can you report it in the bug-reports section and we'll have a look at it.
Old   May 6, 2008, 09:40
Default I have a similar problem using
John Deas
johndeas is on a distinguished road
I have a similar problem using timeVaryingMappedFixedValue:
Time = 0.2
Courant Number mean: 0.0215601 max: 0.1955
file: /home/vinz/OpenFOAM/vinz-1.4.1/run/05-TVMFV/constant/boundaryData/entree/0.4 at line 0.
FOAM exiting
It does not appear when I have two time directories in boundaryData, but when a third is added (even just by copying/renaming another one), the previous error message appears.
johndeas is offline   Reply With Quote
Old   May 6, 2008, 09:43
Default And it appears when the second
John Deas
And it appears when the second directory has to be read.
For example, if I have the folders 0 0.1 and 0.2 in boundaryData, the problem will appear at Time = 0.1
Old   May 6, 2008, 11:35
Default Here is the report using debug
John Deas
Here is the report using debug flag, with directories 0 0.1 and 0.2:
Time = 0.1
Courant Number mean: 0.0215667 max: 0.191
findTime : Found time 0.1 inbetween index:1 time:0.1 and index:2 time:0.2
checkTable : Setting startValues to (already read) "boundaryData/entree/0.1"
checkTable : Reading endValues from "boundaryData/entree/0.2"
file: /home/vinz/OpenFOAM/vinz-1.4.1/run/05-TVMFV/constant/boundaryData/entree/0.2 at line 0.
FOAM exiting
Old   May 6, 2008, 16:09
Default I don't see this problem. Runn
  #11
Mattijs Janssens
I don't see this problem. Running the pitzDailyExptInlet tutorial case now with 4 time files. (0,0.2,0.4 and 0.9). Do you have a 0.2 file? Readable?
Old   May 6, 2008, 17:28
Default Yes, even if it is a direct co
  #12
John Deas
Yes, even if it is a direct copy of the 0 it doesn't work.
Old   May 7, 2008, 11:14
Default Here is how you can reproduce
  #13
John Deas
Here is how you can reproduce my errors, considering three different cases:
take the case pitzDailyExptinlet
change controlDict/endTime to 20 (just to make it quick)
several cases now:
case 1: if I copy boundaryData/0 to boundaryData/25, it gives me:
Reading field U
timeVaryingMappedFixedValueFvPatchField : Read 70 sample points from "/home/vinz/OpenFOAM/vinz-1.4.1/run/07-pitzDailyExptInlet/constant/boundaryData/ inlet/points"
timeVaryingMappedFixedValueFvPatchField : Used points (-0.0206 0.000125 0) (-0.0206 0.000375 0) (-0.0206 0.000125 0.173) to define coordinate system with normal (1 0 0)
readSamplePoints : Dumping face centres to "/home/vinz/OpenFOAM/vinz-1.4.1/run/07-pitzDailyExptInlet/localFaceCentres.obj"
timeVaryingMappedFixedValueFvPatchField : In directory "/home/vinz/OpenFOAM/vinz-1.4.1/run/07-pitzDailyExptInlet/constant/boundaryData/ inlet" found times
2
25
0
--> FOAM FATAL ERROR : Cannot find starting sampling values for current time 0
Have sampling values for times
2
25
0
In directory "constant/boundaryData/inlet"
on patch inlet of field U in file "/home/vinz/OpenFOAM/vinz-1.4.1/run/07-pitzDailyExptInlet/0/U"
From function findTime
in file fields/fvPatchFields/derived/timeVaryingMappedFixedValue/timeVaryingMappedFixedV alueFvPatchField.C at line 469.
FOAM exiting
case 2: if I copy boundaryData/0 to boundaryData/21, -or- boundaryData/26 it works fine, I do not understand why, since 21, 25 and 26 are above the upper limit of the calculation, it might not be a problem of interpolation, why the bug with 25 ?
case 3: if I copy boundaryData/0 to boundaryData/3 -and- boundaryData/26, the bug appear at Time=2 with the following message:
Time = 2
findTime : Found time 2 inbetween index:1 time:2 and index:2 time:26
checkTable : Setting startValues to (already read) "boundaryData/inlet/2"
checkTable : Reading endValues from "boundaryData/inlet/26"
file: /home/vinz/OpenFOAM/vinz-1.4.1/run/07-pitzDailyExptInlet/constant/boundaryData/i nlet/26 at line 0.
FOAM exiting
I hope those reproducible errors might help to point at a misnapulation of my own/bug in the patch.
Old   May 8, 2008, 16:57
Default The problem seems to be the so
  #14
Mattijs Janssens
The problem seems to be the sorting of the times. I get:
timeVaryingMappedFixedValueFvPatchField : In directory "../pitzDailyExptInlet/constant/boundaryData/inlet" found times
2
0
25
which is in the correct, incremental, order. (findTimes should return times in sorted order). Don't directly see why you should get them differently.
Old   May 14, 2008, 07:04
Default I tried again today, copying b
  #15
John Deas
I tried again today, copying boundaryData/0 to 5 and 30, and get the following message:
(in this case, findTime provide them in the right order...)
Exec : simpleFoam . 07-pitzDailyExptInlet
Date : May 14 2008
Time : 12:50:05
Host : pcaea1
PID : 9819
Root : /home/vinz/OpenFOAM/vinz-1.4.1/run
Case : 07-pitzDailyExptInlet
Nprocs : 1
Create time
Create mesh for time = 0
Reading field p
Reading field U
xptInlet/constant/boundaryData/inlet/points"
obj"
3
0
5
30
findTime : Found time 0 inbetween index:0 time:0 and index:1 time:5
checkTable : Reading endValues from "boundaryData/inlet/5"
updateCoeffs : Sampled, interpolated values between start time:0 and end time:5 with weight:0
updateCoeffs : set fixedValue to min1.51773 0 0) max14.3576 0 0)
Selecting incompressible transport model Newtonian
Selecting turbulence model kEpsilon
obj"
3
0
5
30
updateCoeffs : set fixedValue to min:0.0828453 max:3.12421
obj"
3
0
5
30
updateCoeffs : set fixedValue to min:2.27183 max:9813.84
Starting time loop
Time = 1
findTime : Found time 1 inbetween index:0 time:0 and index:1 time:5
updateCoeffs : Sampled, interpolated values between start time:0 and end time:5 with weight:0.2
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.0880712, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.0415937, No Iterations 1
DICPCG: Solving for p, Initial residual = 1, Final residual = 0.00901764, No Iterations 158
time step continuity errors : sum local = 1.23171, global = -0.000635655, cumulative = -0.000635655
DILUPBiCG: Solving for epsilon, Initial residual = 0.487709, Final residual = 0.0374107, No Iterations 1
DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 0.0202643, No Iterations 1
ExecutionTime = 0.54 s ClockTime = 0 s
Time = 2
findTime : Found time 2 inbetween index:0 time:0 and index:1 time:5
updateCoeffs : Sampled, interpolated values between start time:0 and end time:5 with weight:0.4
DILUPBiCG: Solving for Ux, Initial residual = 0.554546, Final residual = 0.0041229, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 0.358215, Final residual = 0.0337988, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.257793, Final residual = 0.00244823, No Iterations 167
time step continuity errors : sum local = 1.26227, global = -0.00138772, cumulative = -0.00202337
DILUPBiCG: Solving for epsilon, Initial residual = 0.798777, Final residual = 0.00811118, No Iterations 2
DILUPBiCG: Solving for k, Initial residual = 0.759915, Final residual = 0.00607932, No Iterations 2
ExecutionTime = 0.76 s ClockTime = 1 s
Time = 3
findTime : Found time 3 inbetween index:0 time:0 and index:1 time:5
updateCoeffs : Sampled, interpolated values between start time:0 and end time:5 with weight:0.6
DILUPBiCG: Solving for Ux, Initial residual = 0.442564, Final residual = 0.0389076, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.236774, Final residual = 0.0204506, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.133109, Final residual = 0.00123854, No Iterations 165
time step continuity errors : sum local = 0.808968, global = 0.00450947, cumulative = 0.00248609
DILUPBiCG: Solving for epsilon, Initial residual = 0.335955, Final residual = 0.00300697, No Iterations 2
DILUPBiCG: Solving for k, Initial residual = 0.228812, Final residual = 0.00174147, No Iterations 2
ExecutionTime = 0.97 s ClockTime = 1 s
Time = 4
findTime : Found time 4 inbetween index:0 time:0 and index:1 time:5
updateCoeffs : Sampled, interpolated values between start time:0 and end time:5 with weight:0.8
DILUPBiCG: Solving for Ux, Initial residual = 0.310706, Final residual = 0.00289445, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 0.14289, Final residual = 0.00143542, No Iterations 2
DICPCG: Solving for p, Initial residual = 0.208651, Final residual = 0.00205794, No Iterations 171
time step continuity errors : sum local = 0.521486, global = -0.000293979, cumulative = 0.00219212
DILUPBiCG: Solving for epsilon, Initial residual = 0.139524, Final residual = 0.0130092, No Iterations 1
DILUPBiCG: Solving for k, Initial residual = 0.119173, Final residual = 0.0105309, No Iterations 1
ExecutionTime = 1.23 s ClockTime = 1 s
Time = 5
findTime : Found time 5 inbetween index:1 time:5 and index:2 time:30
checkTable : Setting startValues to (already read) "boundaryData/inlet/5"
checkTable : Reading endValues from "boundaryData/inlet/30"
file: /home/vinz/OpenFOAM/vinz-1.4.1/run/07-pitzDailyExptInlet/constant/boundaryData/i nlet/30 at line 0.
Old   May 15, 2008, 04:20
Default Hi John, there is a space i
  #16
Mattijs Janssens
Hi John,
there is a space in the 'i nlet' in the message above. Is that just from editing?
- any difference if you up the writePrecision to 15?
- anything special about your architecture/disk (nfs?)
- is this release 1.4.1?
All works fine for me. At time 5:
Time = 5
updateCoeffs : Sampled, interpolated values between start time:5 and end time:30 with weight:0
Old   January 20, 2009, 04:27
Default hi, I am trying to learn to u
  #17
Ivan Lau
ivanwhlau is on a distinguished road
hi,
I am trying to learn to use timeVaryingUniformFixedValue
However, I got the following error.
In fact, I am trying the sample from the tutorial. Also, I try to use the directMapped value from 30 points instead. Is it possible?
Can anyone give me some advise?
Create time
Reading field p
Reading field U
Cannot find points that make valid normal.
Need at least three sample points which are not in a line.
on patch inlet of field U in file "/home/ilau/OpenFOAM/ilau-1.5/run/test/simpleFoam/pitzDaily-timeVaryingMappedFix edValue/0/U"
From function timeVaryingMappedFixedValueFvPatchField<type>::rea dSamplePoints()
in file fields/fvPatchFields/derived/timeVaryingMappedFixedValue/timeVaryingMappedFixedV alueFvPatchField.C at line 330.
FOAM exiting
Regards,
Ivan
ivanwhlau is offline   Reply With Quote
Old   March 5, 2009, 08:44
Default Hi, I have used timeVarying
  #18
Miku
miku is on a distinguished road
I have used timeVaryingMappedFixedValue for creating boundaryData. Now I also want to have fixed values for my internal field. Does anybody know if I can use timeVaryingMappedFixedValue for this problem? Perhaps by creating an folder for internalData instead of boundaryData? I want to get fixed values for pressure and velocity for all timesteps.
Thanks in advance.
miku is offline   Reply With Quote
Old   July 7, 2009, 06:39
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Hello again.
Is there any hint on how to use the timeVaryingMappedFixedValue boundary condition?
Unfortunately there is not much commend in the code and I'm not sure how to use the bc.
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   June 23, 2010, 09:35
Default problem with unstationnary data
  #20
John Deas
I am having some trouble setting up the timeVarryingMappedFixedValue boundary condition for a direct numerical simulation case. I thought it might be appropriate to advertise to my fellow tVMFV users, for my post located at http://www.cfd-online.com/Forums/ope...tml#post264064 .
TimeVaryingMappedFixedValue field creation johndeas OpenFOAM Running, Solving & CFD 24 June 14, 2021 14:56
TimeVaryingMappedFixedValue best practice to extract subset points and fields podallaire OpenFOAM Running, Solving & CFD 6 May 21, 2014 10:25
TimeVaryingMappedFixedValue sunnysun OpenFOAM Running, Solving & CFD 12 October 30, 2013 15:22
Possible bug with timeVaryingMappedFixedValue jerome OpenFOAM Bugs 2 October 9, 2007 09:38
