Simulate the movement of boats
Like Tree1Likes
Old   January 7, 2008, 05:33
Default Hi all, I would like to simula
Francesco Boschetto
francesco_b is on a distinguished road
Hi all, I would like to simulate the movement of boats-like objects using OpenFoam, is it possible? Of course I think the answer is positive, but i can't find anything on the net. The problem is quite complex because it could be defined as liquid-solid-gas case with free surface.
Can someone give me a hint of how to solve it using OpenFOAM?
Thank you in advance
Francesco B.
francesco_b is offline   Reply With Quote
Old   January 7, 2008, 06:34
Default Hi Francesco, I am working
egp
egp's Avatar
Eric Paterson
egp is on a distinguished road
Hi Francesco,
I am working on ships and floating bodies in waves using OpenFOAM. You need:
1. Free surface (rasInterFoam)
2. Ocean wave model, or simple Stokes wave model for simulating experimental facilities such as a wave basin.
3. Non-reflective outflow BC's
4. Dynamic meshing to capture the relative motion between the object and the free surface.
5. Ability to resolve or model rudders and propulsors.
6. 6DOF solver to computer the trajectory of the object.
In theory, it should be straight-forward to stitch together mostly existing code. However, there are issues which must be addressed. E.g., I recently put together rasInterDyMFoam (rasInterFoam + icoDyMFoam), and am working through a few minor issues.
Good luck, Eric
egp is offline   Reply With Quote
Old   January 7, 2008, 10:30
Default Hi Eric, >> You need: >> 1
Francesco Boschetto
Hi Eric,
>> You need:
Ok
I think I'll use a simple wave model, I'm not worried about this
How can I impose them?
icoDynMFoam does it
For my earlier applications I don't have them
I don't know which solver could be used in this case
Can you suggest me how to perform this task? I'm quite new to OpenFoam,
Thanks for your help
Best Regards
Francesco
Old   January 7, 2008, 11:30
Default Hi Eric, I did also try to
Jean-Luc Pelerin
jlpelerin is on a distinguished road
Hi Eric,
I did also try to mix rasInterFoam and icoDyMFoam. Unfortunately, I was unable to get a convincing result.
The first problem I encountered was : how to set the U values on boundaries equal to the rigid body velocity...
Would it be possible you post your code?
Thanks,
Best regards,
Jean-Luc
jlpelerin is offline   Reply With Quote
Old   February 8, 2008, 17:54
Default Hello all, this is my first po
Miguel Quintero
miguel_q is on a distinguished road
Hello all, this is my first post. I am still a beginner to openfoam. I have spent the past few weeks learning the program and using the interfoam solver to generate waves. I have put a box in the middle of my wave tank and I am trying to simulate wave motions of the box, I hope to implement a ship hull one I get the box to work. My question is, how to enable the box to move with the waves and extract the data in numerical form to show how much the box moves with the interaction (6 DOF)? I was also interested in asking, does openfoam adjust how the object will float through the metacentric height and center of gravity? Because I simply put the box in the tank and set fields to where I calculated the water line to be. Sorry for the long question, I am beginning and I am really interested in the program so I look forward to any and all advice.
miguel_q is offline   Reply With Quote
Old   February 8, 2008, 18:33
Default Miguel, I am also trying to
Michael Patterson
michaelp is on a distinguished road
Miguel,
I am also trying to get a numerical wave tank working, I seem to have got sidetracked trying to build some surface tracking routines that won't compile for me from OpenFOAM-dev. Would you be willing to show me the initial/boundary conditions you have used for interfoam?
Regards
Michael
michaelp is offline   Reply With Quote
Old   February 8, 2008, 19:09
Default Michael, I am still new at
Miguel Quintero
Michael,
I am still new at all this. The best advice I could give at this point is to look at the forum below and download the the files for wave phase and wave velocity and then follow the directions for implementing them. Use the wavephase for the inlet of gamma and the wavevelocity for inlet of velocity. You must follow the directions from the mentioned forum on the wave tank on where to put the files.
http://www.cfd-online.com/OpenFOAM_D...es/1/4248.html
Old   May 5, 2008, 00:31
Default I was wondering if anyone coul
Miguel Quintero
I was wondering if anyone could give me some insight on how to combine rasInterFoam and icoDyMFoam? Advice, jounral articles, publications...? I have been struggling with this for some time and would love to hear where you found your information. Anything would help me at this point. Thanks in advance.
Miguel Q.
Old   May 5, 2008, 07:36
Default Dear all, Also I am interes
Mark Couwenberg
markc is on a distinguished road
Dear all,
Also I am interested in solving problems related to ship design and ship motions. So far I succeeded in solving a wave pattern of a boat sailing in calm water using interFoam. This already caused a lot of challenges with respect to boundary conditions, meshing, solver strategies, schemes settings etc. I am very curious if anyone also succeeded in this relatively simple task.
I am still working on finalising this model, trying some more variations. Once I am satisfied, I will post some results and experiences here.
The next step is indeed using dynamic mesh. Instead of a 6DOF solver I am firstly interested in a 2DOF solver: sinkage (displacement in Z direction) and trim (rotation around Y axis).
This will be a next challenge. Not the math but the implementation in proper code. Any experience here already?
Once I am able to solve problems in calm water, taking a seaway into account is next. However I am currently focussing on the first two points.
With respect to propulsors and appendages: I am also conducting calculations regarding this. However, this involves more detailed investigations instead of full ship/water interactions. I am working on some models were I modelled the propeller using the actuator disk theory in order to investigate propeller/hull interaction. I am confident that such models could be coupled to interFoam models, however it makes models needlessly large in my opinion.
In short: I am slowly progressing in solving wave patterns/wave resistance of ships sailing in calm water and I am very curious if anyone has experience in this already.
brgds,
Mark
markc is offline   Reply With Quote
Old   May 16, 2008, 10:25
Default Jaswi, I will be happy to m
Quinn Tian
qtian is on a distinguished road
Jaswi,
I will be happy to make some contribution to our forum. Since this is a 3d bump, the mesh size is too big. I am not sure that we can include such information in the test case. If you don't think that will be a problem, I will be glad to work on a test case.
Quinn
qtian is offline   Reply With Quote
Old   May 16, 2008, 12:00
Default Hi Mark, I am following thi
  #11
Alexandre Pereira
alexandrepereira is on a distinguished road
Hi Mark,
I am following this topic with interest...
Just tell me, how do you plan to solve for the generalized equations of motion of the boat...?
From the dynamic pressure from water you get moments and forces in respect to the CG of the boat, but how do you plan to model the rigid body dynamics?
...a full set of six rotational and translational springs and dampers with properly chosen constants might be an idea, but how do you couple it with a dynamic mesh in OpenFOAM...?
Also, since a boat has a complex shape, and its metacentric height changes in a non linear way with the angle of roll, and furthermore depends on the other DOF... i guess that some kind of nonlinear second order differential integrator might be required...
I am currently trying to solve such a problem in ADINA... but if one wants to be exact in the CFD-RBD modelling, well... it is not easy...
... BTW, how the heck did those japs built the Yamato warship, and the Zuikaku and Shokaku carriers without ever dreaming of CFD analysis...?
... just the thought of it makes an engineer feel rather small... :-)
brgds
Alex
alexandrepereira is offline   Reply With Quote
Old   May 21, 2008, 09:34
Default Hi ppl I have started to co
  #12
Alexandre Pereira
Hi ppl
I have started to code a 6 DOF differential stiff solver with automatic time stepping and error estimation.
I is supposed to solve the a rigid motion problem of a body immersed in a fluid ( compute the generalized displacements of its CG in absolute inertial frame, in response to a set of time varying set of forces/moments applied to its CG )
It will use a single step 4th order Runge Kutta integrator with error estimation to compute the n initial values of displacement, coupled to a 4th order Gear multistep predictor-corrector integrator to continue the integration through the rest time period, reducing iteration workload compared to Runge-Kutta.
My issue is: How can i integrate this solver within the framework of OpenFOAM?
How do i couple the calculated displacement with the dynamic mesh change, so as to update the position of my floating object within the boundaries of gamma<1 ( z-translation, roll, trim, and pitch rotations ? )
Thanks in advance
Alex
Old   May 21, 2008, 09:57
Default Hi Alex, Have a look at thi
  #13
Hrvoje Jasak
Hi Alex,
Have a look at this video:
http://powerlab.fsb.hr/ped/kturbo/Op...ngCylinder.mpg
I take it this is something you are after... Have a look at the dev SVN repository and you will find most components ready for you, inculding an ODE solver and a 6-DOF ODE class. What remains is a moving deforming mesh VOF solver, force calculation and coupling.
I think Eric Paterson is preparing the case I've shown you as a tutorial for the Milan Workshop - this would presumably mean all the files and solvers will be given away.
To summarise, main components are:
- moving mesh VOF solver
- dynamic moving mesh class which
- identifies moving surface
- calculates forces on the body
- contains a 6-DOF ODE and solver for those forces
- uses automatic mehs motion to deform the mesh
We have actually gone further and protected cell layers close to the solid body, used mesh subset to minimise the cost of mesh deformation solver, integrated motion accuracy to second order (mean velocity and rotation) etc, but this is the basic setup. (people who contributed but didn't get a mention, please accept my apologies: this is joint work and I'm not trying to take all the credit).
Hope this helps,
Hrv
Hrvoje Jasak
Old   May 21, 2008, 10:16
Default Thanks Hrv I will give a lo
  #14
Alexandre Pereira
Thanks Hrv
I will give a look at that.
brgds
Alex
Old   May 21, 2008, 13:20
Default Hi That vid is amazing Hrv.
  #15
Alexandre Pereira
Hi
That vid is amazing Hrv... awesome... :-)
Just tell me, how do you model Archimedes impulse...?
As a nonlinear spring attached from the cylinder to the global reference frame, or do you really integrate the displacement volume above a prescribed (... say 0.99 ) beta threshold, and integrate the z displacement in the ODE class... ?
Doing it in Z, and YPR rotational coordinates is rather highly nonlinear due to coupling effects, and the very nature of a Boat geometry ( nonlinear variation of metacentric height with roll angle... etc )
... In my best days, i can TRY to write such a piece of code in Fortran 95... no classes, no data abstraction, no polymorphism or virtual methods... duh :-( ...
... should have invested in c++ instead of Fortran... Do you believe that a couple of weeks ago i did not knew what a class was... ?
... I realy am a long way of understanding how OpenFOAM works...
Nice work ... awesome... :-)
Alex
Old   May 21, 2008, 16:02
Default Why don't you drop me an E-mai
  #16
Hrvoje Jasak
Why don't you drop me an E-mail - let's talk about it...
Hrv
Hrvoje Jasak
Old   June 18, 2008, 10:53
Default Hi All, Here some first res
  #17
Mark Couwenberg
Hi All,
Here some first results/experiences of a boat modeled free sailing, using interFoam.
The domain consists of the SB half of a boat. Water domain is calm water, no waves, so actually steady state.
Domain is tet mesh with a finer distribution near water surface and boatÅ› hull. Number of elements appr 280K.
The boat is sailing appr at its hull speed, appr Froude number = 0.4.
The wave profile is more or less visualized below by plotting all elements with gamma>0.5:
The hull is colored by pressure results.
I experienced a lot of problems with stability. This is probably partly caused by the fact that the model is tet-meshed, though checkmesh gives nil errors/warnings. At this moment I do not have the tools to (at least partly) mesh the domain with hexagon so I had no opportunity to investigate this further.
Furthermore the solver and schemes settings are important. The files are given below.
files.zip
Especially the relaxationFactors appeared crucial, besides using upwind on div scheme.
I still have one corner with a too high velocity, see picture below. Note that boat speed is 5 m/s, while one cell in the corner gets upto 11 m/s. Such velocity spikes always occurred just above the water surface on the boundaries and often in corners. However with the presented settings solution was stable.
One issue I do not feel comfortable about is the fact that the solution in fact is still not converged. The number of iterations needed is not decreasing anymore. Below the last solution step from the solver log is presented:
MULES: Solving for gamma
Liquid phase volume fraction = 0.890947 Min(gamma) = -9.21406e-19 Max(gamma) = 1
Liquid phase volume fraction = 0.890947 Min(gamma) = -1.46065e-19 Max(gamma) = 1
Liquid phase volume fraction = 0.890947 Min(gamma) = -3.5428e-19 Max(gamma) = 1
Liquid phase volume fraction = 0.890947 Min(gamma) = -1.9693e-18 Max(gamma) = 1
smoothSolver: Solving for Ux, Initial residual = 7.38197e-05, Final residual = 2.63128e-07, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.000170614, Final residual = 8.25023e-07, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0.000814927, Final residual = 2.51264e-07, No Iterations 3
GAMG: Solving for pd, Initial residual = 0.0166, Final residual = 7.92732e-07, No Iterations 8
GAMG: Solving for pd, Initial residual = 0.00488644, Final residual = 7.28804e-07, No Iterations 7
GAMG: Solving for pd, Initial residual = 0.00161011, Final residual = 9.83858e-07, No Iterations 5
time step continuity errors : sum local = 4.67858e-10, global = 2.57875e-11, cumulative = 6.93357e-07
ExecutionTime = 53492.3 s ClockTime = 53522 s
Can anyone comment on this? How should I make the solution converge to nil iterations? Maybe the mesh is still too coarse?
The next steps will be:
- investigate pressure integration results over the hull and compare with wave resistance.
- make iterations around changing of boat position in the water due to trim and sinkage. For this, integration of boat hull over water volume (gamma > 0.5) is necessary and next, hull needs to be moved/rotated according these results (moving/deformed mesh?)
- investigate application of moving mesh to follow wave pattern. It would be great to capture the interface by moving a certain mesh layer at gamma = 0.5 (e.g.).
Hrv / Alex, do I understand right: are tools already available to perform the latter 2 steps?
Topics in this forum thread are amongst others about 6 dof solvers taking dynamics into account in which I am very interested. However, I have not seen any attempt yet with a simple (but real) boat geometry modelled with a commercial mesher (tet) sailing in calm water (steady state). I am very curious about other peoples experiences in these relatively simple tasks before moving to the next steps.
Awaiting any comments,
Brgds,
Mark
Old   June 18, 2008, 12:07
Default Mark, I would recommend tha
  #18
egp
egp's Avatar
Eric Paterson
Mark,
I would recommend that you take a look at my wigley hull case:
http://idisk.mac.com/egpaterson-Public/wigley.tar.gz
It is similar to what you are doing and runs OK with the standard rasInterFoam solver.
Eric
Old   June 18, 2008, 14:22
Default Hi Mark, Impressive your re
  #19
Alexandre Pereira
Hi Mark,
Impressive your results, :-)
Acoording to Hrv, OpenFOAM includes a 6 DOF solver class, it can be used to integrate the rigid body
motion in CP fixed inertial frame from calculated Forces/moments obtained from pressures over the hull, but i guess that updating the buoyacy forces due to relative motion of the waterplane won't be an easy task... what geometric description do you have of the hull surface? one approach might be to integrate the displacement volume above beta=.99 so as to try to relocate the metacenter and feed the free body force system to teh equations to be solved in the ODE solver... Just an idea here... didn't think much about the issue yet...
and there are issues of stiffness in the differential equation system in the ODE solver : I antecipate they will be highly nonlinear, what is the ratio of orders of magnitude of the boat's self motion velocity ( periods of roll and trim ) compared to the speed of free surface flow...?
That must also be taken care of... i guess...
Nice work though... :-)
brgds
Alex
Old   June 18, 2008, 20:49
Default Hi again Mark I have run yr
  #20
Alexandre Pereira
Hi again Mark
I have run yr model. do you have any idea where i may learn a suitable wave model to impose on the inlet, and a non reflective BC to impose on the outlet ?
I think that a rather interesting phenomenon to be simulated with rigid body motion update, might be the resonance of wave period with vertical hull motion period, considering that the hull length is short compared to wave length...
...should be interesting to say the least... :-)
Ever heard of what happened to a battleship, from KuK ( Koenigliche und Kaiserliche ) marine in WW1...?
BTW why didn't you use a single inlet patch with funkySetFields to account for water level at inlet...?
Does one really need two inlet patches...?
Just one more thing, which mesher did you use...?
brgds
Alex
simulate the movement of boats Francesco B. Main CFD Forum 0 January 7, 2008 04:00
Do small boats slow big boats? Richard Scott Main CFD Forum 13 August 3, 2004 03:51
Performance Boats and CFD BoatDesigner Main CFD Forum 0 April 16, 2004 15:24
movement stk Phoenics 0 March 19, 2004 10:53
Sun Movement Leon Mills Phoenics 2 July 24, 2003 03:50
