Plot residuals over Iterations instead of time steps
Like Tree1Likes
  • 1 Post By vikramaditya91
Old   July 29, 2016, 02:56
Default Plot residuals over Iterations instead of time steps
Charles K.
McCharles is on a distinguished road
Hello everyone,
I would like to plot the residuals over the Pimple Iterations instead of every completed time step in order to see the PIMPLE-Loops. Usually i use pyFoamPlotWatcher.py to plot the residuals.
Is there a special extension to use with pyFoamPlotWatcher or do i have to change any setting?
Cheers,
Charles
McCharles is offline   Reply With Quote
Old   July 29, 2016, 03:46
Default Have you gone through this
eu sou cfd
vikramaditya91 is on a distinguished road
Hey McCharles, I am not sure if pyFoamPlots have that option while running a transient case.
http://www.cfd-online.com/Forums/ope...residuals.html
But if you haven't gone through the above link I suggest going through it thougroughly. Of course it isnt as straight forward as the pyFoamPlots but this gets the job done and you have a much better control on the graphs I think
vikramaditya91 is offline   Reply With Quote
Old   July 29, 2016, 07:10
Bruno
MBttR is on a distinguished road
Hi Vikramaditya, do you maybe know how to just plot the last iteration of a variable per timestep? For example, pressure makes several iterations per timestep and hence the plot contains all these values, as the word pressure is stated many times. I thought maybe to do a search for the last instance of the word but I'm not sure how to do this.
Greetings,
Bruno
MBttR is offline   Reply With Quote
Old   July 29, 2016, 07:35
Default Convergence plot
eu sou cfd
Hey Bruno, the post I referred to actually makes that distinction. But anyway, here is the code
set logscale y
set title "Residuals"
set ylabel 'Residual'
set xlabel 'Iteration'
plot "< cat log_parallel.txt | grep 'Solving for Urelx' | cut -d' ' -f9 | tr -d ','" title 'Urelx' with lines,\
     "< cat log_parallel.txt | grep 'Solving for Urely' | cut -d' ' -f9 | tr -d ','" title 'Urely' with lines,\
     "< cat log_parallel.txt | grep 'Solving for Urelz' | cut -d' ' -f9 | tr -d ','" title 'Urelz' with lines,\
     "< cat log_parallel.txt | grep 'Solving for p' | cut -d' ' -f9 | sed -n '0~6p'| tr -d ','" title 'p' with lines
pause 1
reread
You replace the 6 in '0~6p' to the number of corrections you make
McCharles likes this.
Old   July 29, 2016, 07:46
Charles K.
Wow, thank you very much for your reply Vik !
Cannot run the code properly: very large time step continuity error crst15 OpenFOAM Running, Solving & CFD 9 December 14, 2014 18:17
Simulation seems to converge but crashes suddenly xxxx OpenFOAM 16 September 12, 2014 08:07
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 10:08
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 08:35
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
