What is the construction of different 5 parts of the code in OpenFoam
Old   October 18, 2008, 22:24
Default Hi Guys, As my understand,
Sandy Lee
sandy is on a distinguished road
Hi Guys,
As my understand, an entire procedure always includes 5 parts, namely mesh generation, scheme (QUICK, UP-Wind Scheme), solution of algebriac equation (BiCG, ICCG), Algorithm (SIMPLE, PISO) and User. Could you introduce how to be constructed in every part? There are so many classes in every part. It is actually difficult to make them clear at a short time, so I would like to know that What are their relations between different class? And moreover, what is the relation between 5 parts?
I guess, somebody should have a series of entire industruction about the framework of these codes and classes --- glancing in the whole structure and detailed in every part. Could you help me to find out them?
Thank you very much!
Kind Regards,
Sandy
sandy is offline   Reply With Quote
Old   October 20, 2008, 05:56
Default Have you tried all the tutoria
John Deas
johndeas is on a distinguished road
Have you tried all the tutorials described in the user guide ? Launching them and opening the various files describing the setup and results of your calculations might clear the picture for you, and it does not take too long.
johndeas is offline   Reply With Quote
Old   October 20, 2008, 09:15
Default Hi John, Thanks for your he
Sandy Lee
Hi John,
Thanks for your help.
I have quickly finished to read the contents in the user's guide and programe' guide. I also tried several cases by the FoamX and paraFoam. However, It seems that I still can not clearly understand the entire framework of those original colds in OpenFoam? I will try again.
By the way, if you have more detailed industruction about those code, please copy to me.
Kind Regards,
Sandy
Old   December 22, 2008, 15:58
Default A document titled "Creational
Heng Xiao
xiao is on a distinguished road
A document titled "Creational Sequence of Objects in a Solver", Compiled by Jaswinder Pal Singh, should answered this question. Search the forum.
Heng
xiao is offline   Reply With Quote
Can fronttracking code be found in OpenFOAM luckyluke OpenFOAM Running, Solving & CFD 23 May 10, 2016 03:15
Musig code in OpenFoam in_flu_ence OpenFOAM Running, Solving & CFD 1 February 25, 2007 16:47
Tree of the openfoam code mhuening OpenFOAM Installation 3 January 29, 2007 18:06
pump construction Roberto Salvador CFX 0 May 4, 2006 10:49
Rotating mesh construction Joel Siemens 1 December 9, 2002 21:21
