Viscoelastic flow modeling in rotorstator system |
March 18, 2008, 02:18 |
Dear CFD experts,
I would l
Ankur Navra
Rep Power: 17 |
Dear CFD experts,
I would like to know the capability of OpenFOAM to model viscoelastic flow in Rotor-Stator system. I already read that there are few work on viscoelastic flow modeling in stationary system, but how about the Rotor-stator system? I am planning to model the flow in twin screw extruder to elucidate the shear stresses and looking for the rightest solver to start with. Is OpenFOAM one of the choices in this case? I would be glad if you could give me the situation of its capabilities and the necessities to implement the viscoelastic flow modeling in rotor-stator systems? My be some more details would be helpful. The Simulation will be 3D and the interaction between rotor and stator is quite high and important. We will not simulate the whole extruder but just one pair of co-rotating kneading elements. The goal is application of different viscoelastic models to determine the one that describes the flow better. And lastly, it wont be an industrial project but PhD. Thanks and best wishes Ankur |
March 18, 2008, 05:01 |
Hi Ankur!
I think for the w
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Ankur!
I think for the whole solution you'll have to construct your own solver. There used to be a version of the mixer2D-tutorial with mesh motion (in version 1.3, for icoDyMFoam) and old versions of interFoam used to support mesh-motion (not totally sure) I think both (mixer2D-tutorial) and interFoam with movement-support can be found in Hrv's dev version Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
March 20, 2008, 09:26 |
Hi Ankur,
I would suggest:
Kerstin Heinen
Rep Power: 17 |
Hi Ankur,
I would suggest: 1. Search for the solver, which is suitable to solve the problem generally for a newtonian liquid. (turbulent, laminar? free surface?...) 2. look an all physical equations in detail what changes are necessary if you introduce a general stress tensor, instead of newtonian stress tensor And then of course implementation of an additional PDE system is necessary to solve for your viscoelastic model. For icoFoam I added a 4-mode Phan-Thien/Tanner viscoelastic model in the past...so far completely untested... and "quick and dirty hack" linked here: http://www.cfd-online.com/OpenFOAM_D...es/1/6356.html From my experience with other (commercial) CFD codes and knowledge from viscoelastic models I would conclude, that for this complex problem programming of a suitable solver in OpenFOAM is the only reasonable choice. Can you tell, from which university you are? Greetings |
July 12, 2008, 03:16 |
Hi Ankur,
you are correct
Hi Ankur,
you are correct FEM is the dominant CFD method for twin screw simulation. But MOURS, M.; REICHELT, D.; WAGNER, H.G.; GILBERT, N.; HOFMANN, J.: Melt conveying in co-rotating twin screw extruders: experiment and numerical simulation In: International Polymer Processing (2000) is an example where FVM has successfully employed using COMET which later became cd-adapco STAR CCM or STAR-CCM+ POKRIEFKE, G.: CFD-Analysis of free surface flow inside a twin screw extruder, 22nd CAD_FEM User's Meeting, International Congress On FEM Technology with ANSYS CFX & ICEM CFD Conference, Dresden, 2004 is an other example for FVM BEM using BEMflow has been tested simulating twinscrews but uses only newtonian fluids, => not suitable for your needs. Polyflow uses mesh superposition technique to simulate twin screw extruder, but don't look to critical at the results "INSIDE" the screws ;-) Yes, I said inside and mean inside. just my 2cents wish you all the best Elvis |
December 25, 2017, 03:01 |
viscoelastic
farhad
Rep Power: 8 |
Hello
How can I form a vortex in a square-shaped channel? Or how can I see vortices? In all the papers, a vortex pair is seen at the corners of the channel with the Giesekus model. How can this be modeled with open foam? what is the properties flow ? B.C ? please help me? my Email: farhadhoseinbor@gmail.com Telegram id: @bfzah |
Viscoelastic flow in rotor-stator @ POLYFLOW | Sumeshen | FLUENT | 1 | August 5, 2013 03:07 |
Viscoelastic flow modeling in Fluent | Ankur Navra | FLUENT | 3 | July 26, 2013 05:56 |
Viscoelastic flow modeling in OpenFOAM | vulda | OpenFOAM Running, Solving & CFD | 1 | March 17, 2008 07:32 |
Polyflow & OpenFoam on Viscoelastic flow modeling | Sumeshen | Main CFD Forum | 0 | March 14, 2008 08:29 |
Viscoelastic Flow in Fluent | Edward Chan | FLUENT | 0 | December 7, 2001 09:41 |
