Boundary condition
Like Tree1Likes
  • 1 Post By alberto
Old   February 1, 2007, 15:50
Default I have to implement a BC in th
Alberto Passalacqua
I have to implement a BC in the form:
T = -A(T) * dT/dn + B
where B is not function of T.
I examined the mixedFvPatchField, but I've some doubt on how to adapt it to my case. What is it's analytical expression?
In the evaluate function it says:
Field<type>::operator=
valueFraction_*refValue_
(1.0 - valueFraction_)*
this->patchInternalField()
+ refGrad_/this->patch().deltaCoeffs()
The comment in the code says it calculates the field on the patch, but, if so, why does the patchInternalField is present?
Does this mean the BC is implemented in the following form?
T = valueFraction*refValue + (1-refValue)(T + refGrad/DeltaCoeff)
Thanks in advance,
Alberto
Alberto Passalacqua
Old   February 2, 2007, 14:47
Default I answer to myself: the patchI
Alberto Passalacqua
I answer to myself: the patchInternalField is present because to calculate the field it's necessary to know the value in the cell centre.
Sorry, I confused it...I shouldn't post a question when sleepy :-))
A.
luiscardona likes this.
Alberto Passalacqua
Old   November 25, 2008, 07:28
Default Hi, How can one access/modif
Radu Mustata
r2d2 is on a distinguished road
How can one access/modify the value of "valueFraction" in a mixed bc at runtime?
So if my U boundary value at a patch cell face checks against some given value (in this first case itīs a zero gradient bc <=> valueFraction = 0) then I want to switch valueFraction to 1 (known value) and set the value of U at the patch to the value I checked against. U bc, are declared as nonuniform lists on that patch (and of course change the bc for pressure accordingly).
Is this possible?
Cheers,
Radu
r2d2 is offline   Reply With Quote
Boundary condition for UDS Tomik FLUENT 0 December 5, 2006 17:37
Boundary condition of the third kind or Danckwertz boundary condition plage OpenFOAM Running, Solving & CFD 4 October 3, 2006 12:21
Slip Boundary Condition for Moving Boundary Shukla Main CFD Forum 3 November 11, 2005 15:02
UDF boundary condition Jeff FLUENT 2 November 20, 2003 17:15
Boundary Condition in LES Zhang Tsiang Main CFD Forum 3 February 5, 2002 20:15
