November 24, 2008, 08:50 |
I am trying to cre
Debashis Maji
I am trying to creat a periodic zone, but hav got the following error : >grid/modify-zones/make-periodic Periodic zone [()] 6 Shadow zone [()] 5 Rotational periodic? (if no, translational) [yes] no Create periodic zones? [yes] yes Auto detect translation vector? [yes] yes Warning: differing number of faces on these threads. computed translation deltas: -0.000436 -0.000421 -0.200000 zone 6: matched 0 out of 500 faces. zone 5: matched 0 out of 600 faces. Error: Failed to make zones periodic. Error Object: #f can anybody please help me with the msg. I cant understand what it means? |
June 27, 2012, 08:03 |
Marx
Normally there could two reason for this error. First check the origin of rotation. So how do we check, open the design in design modeler then use point entity to check the centre of rotation coordinate. u can even draw on the surface of your model and find the centre of rotation. (anyway works). if its rotating along z axis then get the x and y coordinate and place it in fleunt>cell zone condition> rotation axis origin.
if it does work then maybe its due to different number of cell on the face of the two surface. It a non conformal periodic.(https://www.sharcnet.ca/Software/Flu...ug/node186.htm) you have change the type of B.c from wall to interface then use Mesh Interface where you select the surfaces, check the periodic B.C set the angel offset and create periodic. |
May 24, 2017, 06:24 |
similar problem
Sagar Deshmukh
Rep Power: 9 |
Hey, I am having a similar problem, how you get rid of it? Please help
Thanks in advance |
highly compressible flow : Fluent Error Message | Amit Shrestha | FLUENT | 5 | December 19, 2018 07:43 |
Error for periodic boundary in GAMBIT | Karim | FLUENT | 0 | August 25, 2007 02:45 |
error: no periodic nodes on thread __. HELP !!! | bne | FLUENT | 0 | June 20, 2007 11:57 |
error: wall-boundary-periodic! | h6h6 | FLUENT | 0 | May 31, 2004 04:04 |
Fluent error in periodic PDF combustion cases?? | George | FLUENT | 2 | March 8, 2004 16:45 |
