SteadyState solver for compressible flow
Old   March 4, 2008, 06:18
Default Hi Marco, send me a mail w
  #21
Francesco Boschetto
francesco_b is on a distinguished road
Hi Marco,
send me a mail with your case and I'll have a look at it, probably there is something wrong
My first suggestion is to avoid using FoamX, modify the files is often better and makes you understand more the code.
Second suggestion is to look at tutorials which are similar to your case, you'll find useful informations.
Regards
Francesco
francesco_b is offline   Reply With Quote
Old   March 4, 2008, 07:14
Default Hi Thomas and Francesco, I
  #22
Marco Zardetto
sharmak is on a distinguished road
I added my email in my profile, you'll see it clicking on my name.
If you send me a mail I'll reply to you. I don't see your email adress.
I thank you for your kindness
Regards
sharmak is offline   Reply With Quote
Old   March 4, 2008, 07:57
Default Hi Marco , About your previ
  #23
Cedric DUPRAT
cedric_duprat is on a distinguished road
Hi Marco ,
About your previous error, just keep in mind that when you've sigFpe somewhere, it's often because you divide by zero somewhere.
are you sure about your BC ?
what are your initial values (k, epsilon) not only at your Patches but also your internal field value?
and, as said Francesco, tutorials are usually a good starting point.
Regards,
Cedric
cedric_duprat is offline   Reply With Quote
Old   March 4, 2008, 14:19
Default Hi Cedric, no I was not sur
  #24
Marco Zardetto
Hi Cedric,
no I was not sure and now I can say they were wrong. I can't use a steady state solver with those BC, is it true?
Anyway I changed BC and maybe the simulation is right now.
Regard
Marco
Old   March 11, 2008, 18:27
Default hi, what relaxation factors ar
  #25
Laurence Griffiths
lgriffiths is on a distinguished road
hi, what relaxation factors are you using for rhoSimple Foam?
I had similar errors not too long ago due to wrong choice of factors
patankar [numerical heat transfer and fluid flow] suggests as a guidance:
0.2(pressure) 0.8(velocity) and that pressure+velocity factor = 1(approx)
also at the start of the iterations it may be useful to under-relax it by quite a lot (especially pressure) - not too sure on velocity - either trial & error, or maybe somebody who knows a little more than me can give some better input
sorry not too sure what your k&epsilon values should be, perhaps there's some published literature on it?
also francesco's advice to run the cases by hand is worth taking - i had a couple of problems with foamX not filling in the boundary conditions correctly.
lgriffiths is offline   Reply With Quote
Old   April 23, 2008, 11:07
Default Hi everybody, I'm trying to
  #26
Leonardo Nettis
dinonettis is on a distinguished road
Hi everybody,
I'm trying to use rhoSimpleFoam to analyze a rae2822 profile (Ma=0.75). Starting from a case located in the rhoExplicitPorousSimpleFoam tutorial I made some minor corrections due the slightly different solver. Unfortunately this is what I get after 3-4 timesteps:
Starting time loop
Time = 0.001
DILUPBiCG: Solving for Ux, Initial residual = 0.91642, Final residual = 0.00113156, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.497643, Final residual = 0.000109773, No Iterations 1
DILUPBiCG: Solving for h, Initial residual = 0.000153941, Final residual = 0.000153941, No Iterations 0
DICPCG: Solving for p, Initial residual = 1, Final residual = 0.085924, No Iterations 10
time step continuity errors : sum local = 0.00341069, global = 6.72999e-18, cumulative = 6.72999e-18
bounding p, min: -183403 max: 51509.8 average: 14986
rho max/min : 0.434091 0.394052
DILUPBiCG: Solving for epsilon, Initial residual = 1, Final residual = 0.0760585, No Iterations 1
DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 4.01958e-10, No Iterations 1
ExecutionTime = 1.1 s ClockTime = 2 s
Time = 0.002
DILUPBiCG: Solving for Ux, Initial residual = 0.625658, Final residual = 0.0132899, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.597063, Final residual = 0.0160514, No Iterations 1
DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 0.0581808, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.999938, Final residual = 0.0994651, No Iterations 128
time step continuity errors : sum local = 0.371864, global = -5.50248e-16, cumulative = -5.43518e-16
bounding p, min: -3.58449e+07 max: 1.04555e+11 average: 2.88087e+10
rho max/min : 81429.1 0.407813
DILUPBiCG: Solving for epsilon, Initial residual = 0.538868, Final residual = 1.87952e-14, No Iterations 1
DILUPBiCG: Solving for k, Initial residual = 0.494746, Final residual = 2.88931e-11, No Iterations 1
ExecutionTime = 1.56 s ClockTime = 2 s
Time = 0.003
DILUPBiCG: Solving for Ux, Initial residual = 0.131877, Final residual = 0.0081574, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.588281, Final residual = 0.0125537, No Iterations 1
DILUPBiCG: Solving for h, Initial residual = 0.984923, Final residual = 0.0415359, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.999974, Final residual = 0.0957307, No Iterations 1
time step continuity errors : sum local = 3.01611e+06, global = -2.06632e-09, cumulative = -2.06632e-09
bounding p, min: -2.18384e+14 max: 3.72087e+16 average: 5.03564e+12
rho max/min : 2.89787e+10 -1.59075e+10
DILUPBiCG: Solving for epsilon, Initial residual = 0.994871, Final residual = 1.6861e-08, No Iterations 1
bounding epsilon, min: -26760.4 max: 4.40476e+23 average: 2.87204e+19
DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 1.60288e-08, No Iterations 1
bounding k, min: -21.8637 max: 5.49352e+17 average: 3.58298e+13
ExecutionTime = 1.81 s ClockTime = 2 s
Time = 0.004
DILUPBiCG: Solving for Ux, Initial residual = 0.654315, Final residual = 0.0018068, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.192592, Final residual = 0.000735478, No Iterations 1
DILUPBiCG: Solving for h, Initial residual = 0.169146, Final residual = 0.000217519, No Iterations 1
--> FOAM FATAL ERROR : Maximum number of iterations exceeded#0 Foam::error::printStack(Foam:stream&) in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam::hThermo<foam::puremixture<foam::consttranspo rt<foam::speciethermo<foam::hc onstthermo<foam::perfectgas> > > > >::calculate() in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libbasicThermophysical Models.so"
#3 Foam::hThermo<foam::puremixture<foam::consttranspo rt<foam::speciethermo<foam::hc onstthermo<foam::perfectgas> > > > >::correct() in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libbasicThermophysical Models.so"
#4 main in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/rhoSimple Foam"
#5 __libc_start_main in "/lib64/libc.so.6"
#6 Foam::regIOobject::readIfModified() in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/rhoSimple Foam"
From function specieThermo<thermo>::T(scalar f, scalar T0, scalar (specieThermo<thermo>::*F)(const scalar) const, scalar (specieThermo<thermo>::*dFdT)(const scalar) const) const
in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.4.1/src/thermophysicalModels/specie/lnInclud e/specieThermoI.H at line 83.
FOAM aborting
I hope somebody can help me!!!
thank you in advance,
dino
dinonettis is offline   Reply With Quote
Old   April 23, 2008, 12:02
Default ps: I forgot to specify that I
  #27
Leonardo Nettis
ps: I forgot to specify that I've imported the 0/U file from the solution found with potentialFoam. This one seems to be corrected, but I don't know if it could influence the problem I've shown in my previous post!!
dino
Old   May 8, 2008, 16:58
Default Hi Leonardo, I'm trying to do
  #28
Daniele Bonetti
dabon is on a distinguished road
Hi Leonardo, I'm trying to do a similar experiment to yours (RAE2822 at M=0.72) but I've a lot of troubles trying to set up the simulation with rhoSimpleFoam. I'm trying to use a test case from rhoExplicitPorousSimpleFoam but it does not work. Could you send me your test file (without the mesh, I use a mesh converted from Gambit) so maybe I can progress? I hope you can help me.
Thanks a lot
Daniele
dabon is offline   Reply With Quote
Old   October 23, 2008, 08:18
Default Hi Fomers, I am working wit
  #29
Vishal Jambhekar
vishal is on a distinguished road
Hi Fomers,
I am working with the prism case in sonicTurbfoam, but i want to capture the shoch at the prism surface.for Mach number 3. i have created mesh for that accordingly. but.....i am unable to find the grad rho at the surface of the prism.
Can i use other foam for this case for compressible flow and steady state so that i can capture grad roh at surface.
Cheers,
Vishal Jambhekar...
"Simulate the way ahead......!!!"
vishal is offline   Reply With Quote
Old   October 23, 2008, 08:21
Default Hi, ihacve one more query
  #30
Vishal Jambhekar
ihacve one more query i dont have foamX directory in the OpenFoam 1.5 version i have installed. till now i was working with command prompt.
Can anyone tell me how can i get in as i want need it to deal with complex scinario.
Thanks
Cheers,
Vishal Jambhekar...
Old   November 18, 2008, 05:48
Default Hello, could anyone please
  #31
paul_mathis
could anyone please translate the hEqn implemented in rhoSimpleFoam into mathematical language, please? Most of all, I am interested in figuring out whether the total or the static enthalpy is used.
The equation for total enthalpy (steady state) found in literature looks like this:
Ñ(r U h<sub>tot</sub>) = Ñ(l Ñ T) + Ñ(U t) + S<sub>E</sub>
h<sub>tot</sub> = h + 0.5 U<sup>2</sup>
Ñ(U t) = viscous dissipation
S<sub>E</sub> = source term
C++ code:
fvScalarMatrix hEqn
fvm::div(phi, h)
- fvm::Sp(fvc::div(phi), h)
- fvm::laplacian(turbulence->alphaEff(), h)
fvc::div(phi/fvc::interpolate(rho)*fvc::interpolate(p, "div(U,p)"))
- p*fvc::div(phi/fvc::interpolate(rho))
Thank you very much,
Paul
Old   November 19, 2008, 07:31
Default OK, answering my question myse
  #32
paul_mathis
OK, answering my question myself:
The enthalpy equation is impemented in terms of static enthalpy, making the C++ code appear in mathematical language:
fvm::div(phi, h) = Ñ•(rU h)
fvm::Sp(fvc::div(phi), h) = S<sub>E</sub> (source term, not sure about this)
fvm::laplacian(turbulence->alphaEff(), h) = Ñ•(a<sub>eff</sub>Ñh)
fvc::div(phi/fvc::interpolate(rho)*fvc::interpolate(p, "div(U,p)")) = Ñ•(p U)
p*fvc::div(phi/fvc::interpolate(rho)) = p Ñ•U
Consequently:
Ñ•(rU h) - S<sub>E</sub> - Ñ•(a<sub>eff</sub>Ñh) = Ñ•(p U) - p Ñ•U
where Ñ•(p U) - p Ñ•U = U •Ñp
That means the viscous dissipation term t:ÑU is not implemented.
I have added a viscous term into the equation, but instead of rising the temperature decreases! Where is my mistake?
My enthalpy equation:
volSymmTensorField tau(turbulence->devRhoReff());
volScalarField tauGradU = tau && fvc::grad(U);
fvScalarMatrix hEqn
fvm::div(phi, h)
+ tauGradU
Old   November 21, 2012, 04:27
Default Check Sign of Dissipation
  #33
bastian_s is on a distinguished road
Hi paul_mathis,
did you solve this problem within the last 4 years?
It seem likely that the dissipation (turbulence->devRhoReff() && fvc::grad(U)) has the wrong sign for an unknown reason. I created a dissipation field, displayed it in paraFoam and got negative values in the whole field.
I think implementing Phi with (-turbulence->devRhoReff() && fvc::grad(U)) should solve the problem. Is anyone familiar with the sign conventions of either the viscous stresses or the velocity gradient in openFoam?
regards
Bastian
bastian_s is offline   Reply With Quote
Steadystate pressurebased compressible solver cosimobianchini OpenFOAM Running, Solving & CFD 1 July 19, 2010 14:45
Steadystate versus Transient solver pda OpenFOAM Running, Solving & CFD 1 July 11, 2007 08:36
Steadystate Vs Transient solver amitshah OpenFOAM Running, Solving & CFD 1 August 23, 2006 02:54
Steadystate Euler solver jelmer OpenFOAM Running, Solving & CFD 1 June 19, 2006 08:24
External Flow-compressible flow solver-lift/drag Tom Brown Main CFD Forum 7 December 29, 2000 13:41
