August 11, 2008, 01:56 |
I do not think buoy
Prashant Ojha
Rep Power: 17 |
I do not think buoyantSimpleFoam is suitable for your application. Read more on boussinesqBuoyantFoam in the dev version. buoyantSimpleFoam uses the perfect gas equation to calculate the density of media, for your case with water, boussinesq approximation is most appropriate. http://openfoam-extend.svn.sourceforge.net/svnroot/openfoam-extend/trunk/Core/Op enFOAM-1.4.1-dev/applications/solvers/heatTransfer/boussinesqBuoyantFoam/ |
August 11, 2008, 02:17 |
Helo,,
use fixedFluxBuoyantP
Pawan
Rep Power: 17 |
Helo,,
use fixedFluxBuoyantPressure boundary conditon for pd . |
August 11, 2008, 10:10 |
thanks for the answer.
Tian
Rep Power: 17 |
thanks for the answer. Prashant, I use air as fluid in the channel. The channel is open in the top and buttom (inlet and outlet). So, my task is to find out how many fluid is driven because of hot cylinder inside (buoyancy flow) near the bottom. Yesterday, I copied "boussinesqBuoyantFoam" in OF 1.5 and wmake it. It is working. I also compiled "calcMassFlow" to see how many fluid goes through my inlet and outlet (3D case). It is difficult to explain. So I found a small video and a picture. Maybe you can have a look and see: http://www.building-engineering.de/OpenFOAM/t.mpeg http://www.building-engineering.de/O...xamples001.png I am not sure about the boundary conditions. Inlet: I do not know about the velocity Outlet: I do not know about the velocity Hot pipe inside: Temperature constant Air inside: Temperature at the beginning I know wall: adiabatic I hope you can understand my poor englisch :-) I also will try out "fixedFluxBuoyanPressure" Thanks for help Bye Tian
BIM HVACTool, The Green Building Simulation Tool for OpenFOAM, Energy Plus and Radiance. |
August 28, 2008, 06:38 |
Until now I not find a
Tian
Rep Power: 17 |
Until now I not find a solution for my problem. I am confused why "buoyantSimpleFoam" need at time 0 the values for "p" and "pd"? The version OF 1.4.1 only need p. How I have to setup a outlet and inlet at time 0? Velocity for inlet and zeroGradiet for p... Outlet zeroGradient for u and fixedValue for p but pd, I have not an idea about it... Can some body give me advice? Thanks a lot. Bye Thomas
September 17, 2008, 07:59 |
you can try fixedFluxBuoyantPr
Matvey Kraposhin
Rep Power: 21 |
you can try fixedFluxBuoyantPressure for p and
fluxCorrectedVelocity for U i am also interested in natural convection simulation, can you post image of your study? what BC's are using for turbulence model?
MDPI Fluids (Q2) special issue for OSS software: https://www.mdpi.com/journal/fluids/..._modelling_OSS GitHub: https://github.com/unicfdlab Linkedin: https://linkedin.com/in/matvey-kraposhin-413869163 RG: https://www.researchgate.net/profile/Matvey_Kraposhin |
September 17, 2008, 08:43 |
thanks Kraposhin, I can
Tian
Rep Power: 17 |
thanks Kraposhin, I can send to your email some screenshot. I change my solver to the boussinesqBouyantSimpleFoam Solver for my study. The application also use RAS turbulence model. Bye Thomas
September 17, 2008, 09:55 |
I tried the BC's fixedF
Tian
Rep Power: 17 |
I tried the BC's fixedFluxBuoyantPressure with fluxCorrectedVelocity for U but there are some errors if I start the solver. Can you explain me more about how I can use this BC's? Thanks a lot. Thomas
September 18, 2008, 04:50 |
ok, my e-mail is mkraposhin@in
Matvey Kraposhin
Rep Power: 21 |
ok, my e-mail is mkraposhin@inbox.ru
the difference between boussinesqBouyantSimpleFoam and buoyantSimpleFoam is only that boussinesqBouyantSimpleFoam uses simplified boussinesq assumption. Both solvers can be used for solving natural convection tasks. What RAS model are you using? How do you calculate initial turbulence parameters on boundaries and in internal domain? about BC's fixedFluxBuoyantPressure is used to setup full pressure field on boundaries (p+r*g*h) fluxCorrectedVelocity can be used when pressure field is already known. Another way, i think, is to use pressureInletVelocity for inlet and zeroGradient for outlet. sorry for bad English
Second order scheme with buoyantSimpleFoam | mighelone | OpenFOAM Running, Solving & CFD | 2 | September 26, 2012 10:28 |
BuoyantSimpleFoam | amitshah | OpenFOAM Running, Solving & CFD | 4 | June 3, 2009 06:04 |
BuoyantSimpleFoam massFlowRate | hellorishi | OpenFOAM Running, Solving & CFD | 0 | March 13, 2009 05:57 |
BuoyantSimpleFoam solver crashes | prashant24983 | OpenFOAM Running, Solving & CFD | 6 | October 28, 2008 06:03 |
Instability in buoyantSimpleFoam | smehdi609 | OpenFOAM Running, Solving & CFD | 1 | August 20, 2008 15:38 |
