Getting old values of psi internal
Like Tree1Likes
  • 1 Post By ffbof
Old   August 27, 2008, 07:23
Default Hello i want to have the psi
Franz
ffbof is on a distinguished road
Hello
i want to have the psi internal values of a previous time step to access them in the updateInterfaceMatrix function of my fvPatchField.
The updateInterfaceMatrix has a parameter lduMatrix& which is the base class for the fvMatrix which has a function psi() to access the psi value.
But i cannot cast the lduMatrix into the fvMatrix so my question is how to downcast from the const lduMatrix& to fvMatrix& is that possible in OpenFOAM framework ?.
ffbof is offline   Reply With Quote
Old   August 27, 2008, 07:36
Default You have to be a bit careful,
Hrvoje Jasak
hjasak will become famous soon enough
You have to be a bit careful, depending where the cast is, eg. you should probably be in templated code. Otherwise, it's easy:
psi().oldTime().internalField()
Enjoy,
Hrv
Hrvoje Jasak
Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk
hjasak is offline   Reply With Quote
Old   August 27, 2008, 09:25
Default Thank you very much for the fa
Franz
Thank you very much for the fast answer Mr Jasak,
in my case it is about the following method of a coupledFvPatchField derived class.
initInterfaceMatrixUpdate
const scalarField& psiInternal,
scalarField&,
const lduMatrix& matrix,
const scalarField&,
const direction,
const bool bufferdTransfer
) const
// here i want to cast the lduMatrix down to the // fvMatrix i tried the following
const fvMatrix<type>& test =
dynamic_cast<const> >(matrix);
// const fvMatrix<type> in dynamic_cast braces
// had problem to display in forum preview
The compiler complains that :
cannot dynamic_cast const lduMatrix& to const fvMatrix<type>&
so i also tried to const_cast the lduMatrix reference with no improvement
So right now i don't know how to access the old psi field within that method.
The thing why i need that is because i am trying to implement a phase lag or direct storage method mentioned by Erdos, J. I. & Alzner, E. Computation of Unsteady Transonic Flows Through Rotating and Stationary Cascades
I - Method of Analysis Nasa Contract Report 2900, 1977, 2900
So what i want to do is to store the psi field of one previous time step the geometric handling is all done only the storage is the remaining problem
If you know a workaround for the template casting problem i would welcome that very much :-)
Old   August 27, 2008, 13:34
Default Hi Franz, The problem is that
Hrvoje Jasak
Hi Franz, The problem is that you are trying to get this done at the wrong place. Explaining it in detail would be a lot of effort; in short, you need to go back to the (templated, coupled) boundary condition and do the work there.
Hrv
Hrvoje Jasak
Old   August 27, 2008, 14:46
Default Sorry for that i think i hav
Franz
i have typed it wrong it seems you are thinking that i am in the global function
thats the header of my test class which is my boundary condition
header
template<class>
class test:
public testLduInterfaceField,
public coupledFvPatchField<type>
source
test::initInterfaceMatrixUpdate
Sorry for that strange notation
But i thought i am in the ,as you called it,
The code at August 27, 2008 - 07:25 am is implemented in the class test which is a template and derived from coupledFvPatchField.
Maybe i just misunderstood your words
But again thank you for reply
bme79 likes this.
Ensight - node values -cell values leo FLUENT 1 May 12, 2010 08:47
[Commercial meshers] TGridFluent mesh with internal by prism layer and internal face for diagnostic sponiar OpenFOAM Meshing & Mesh Conversion 2 March 30, 2009 15:02
how to get fluid internal internal energy vbk FLUENT 0 December 17, 2007 01:54
node values or cell values? aPpA FLUENT 0 November 10, 2006 08:56
Internal BC Saud Khashan FLUENT 0 July 3, 2001 08:58
