August 14, 2008, 03:19 |
because I want to w
because I want to write an own solver, I'm trying to understand some basics in the sourcecode of existing solvers. In this context I have some problems. Perhaps someone can help me to understand the following: In the the time-loop of the laplacianFoam solver (in $WM_PROJECT_DIR/application/solver/basic/laplacianFoam/laplacianFoam.C) there is one more loop: for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++) { solve ( fvm::ddt(T)-fvm::laplacian(DT,T) ); } I don't understand how the loop can do some correction. Why I don't get the same result without the loop. For me it seems like doing nNonOrthCorr-times the same thing. In this context perhaps someone can tell me, what's wrong with the following: 1. fvm::ddt(T)-fvm::laplacian(DT,T) discretizes the differential equation with the schemes given in the fvSchemes-file -> result is a linear equation system 2. solve (...) solves the in 1. obtained equation system with the solver given in fvSolution-file. You get a solution for the "next timestep" with the correctness specified in the fvSolution-file about tolerance? And now? Is this solution used as a new initial-value for the next step in the "nonOrth-loop"? But why the solver starts then to calculate, if the tolerance - given in fvSolution-file - is reached in the step before? I guess I don't understand something very basically. Please, can someone help me? Karen |
Understanding interFoam | sega | OpenFOAM Running, Solving & CFD | 26 | February 10, 2022 03:21 |
Basic Understanding | Abduri | CFX | 8 | March 7, 2009 06:12 |
Understanding k from kepsilon | markh83 | OpenFOAM Post-Processing | 3 | December 5, 2008 03:42 |
Understanding parallel solvers | milkovp | OpenFOAM Running, Solving & CFD | 3 | May 20, 2008 17:07 |
Understanding turbFoam sourcecode | lasb | OpenFOAM | 1 | July 31, 2007 10:21 |
