April 14, 2020, 13:08 |
Checking time of a simulation
Josh McCraney
Rep Power: 8 |
Hi all!
When running a simulation, say something like this: Code:
mpirun -np 16 interFoam -parallel > log.interFoam & |
April 14, 2020, 14:04 |
Herpes Free Engineer
Rep Power: 12 |
Hope understood your question correctly.
You direct the standard stream (excluding errors?) into the file `log.interFoam` by using `>` operator. If you would like to see the accumulating content of `log.interFoam`, open another terminal at the same location, and do `tail -f log.interFoam`, which will output whatever recorded into the log file to the screen. If you only would like to see the output, but not to save it to a file, just `mpirun -np 16 interFoam -parallel` will output to the screen.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
April 14, 2020, 14:10 |
Josh McCraney
Rep Power: 8 |
Perfect and thanks!
Followup: if I want to kill the process, typically I would type ctrl+c. How would I do it for this? |
April 14, 2020, 16:39 |
Rep Power: 12 |
Yes, that would do. You can also change the `endTime` settings in `controlDict` if you would like to have an early exit.
bash script for pseudo-parallel usage of reconstructPar | kwardle | OpenFOAM Post-Processing | 41 | August 23, 2023 02:48 |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
HiFiLES installation problem | Eric Brant | SU2 | 0 | October 31, 2016 20:11 |
Stuck in a Rut- interDyMFoam! | xoitx | OpenFOAM Running, Solving & CFD | 14 | March 25, 2016 07:09 |
