Modeling Dual chamber spring with orifice for damping
Old   July 22, 2008, 15:04
Default There is a model test going on
eno
Sean Bian
eno is on a distinguished road
There is a model test going on in our lab to study the nonlinear stiffness, damping etc of a dual camber air spring with inter-connected oriface. One chamber is a fixed cylinder (Dia~2', Length~5') and the other one is of similar size and with a piston moving at stroke~+-3' and period ~3- 10 seconds. I'd like to include the friction in the model at lease for selected cases to see how much extra damping it provides.
How would you model this problem? Can a 2D axisymmetric model be used to save time? Is there a sample case close enough that I can refer?
Many thanks from new OpenFoamer
eno is offline   Reply With Quote
Modeling sudden flow in Vacuum chamber Sandilya Garimella FLUENT 0 February 8, 2008 15:04
Spring smoothing Arne FLUENT 0 October 29, 2007 14:06
Orifice modeling John FLUENT 1 July 6, 2004 05:48
meshing a spring baskar FLUENT 2 October 11, 2001 10:24
