TurbFoam simpleFoam incompatible fields for operation
Old   June 19, 2008, 10:43
Default Hi, I am trying to run the
Fabian Braennstroem
braennstroem is on a distinguished road
I am trying to run the same geometry, a diffuser, in steady (simpleFoam) and unsteady (turbFoam) mode with version 1.4.1 using standard k-epsilon. The steady calculation works without a problem, but when starting the unsteady calculation I get:
Selecting incompressible transport model Newtonian
Selecting turbulence model kEpsilon
Starting time loop
Time = 0.01
Courant Number mean: 0 max: 46.5449672485878
--> FOAM FATAL ERROR : incompatible fields for operation
[U] + [region0]#0 Foam::error::printStack(Foam:stream&) in "/home/gcae504/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/gcae504/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 void Foam::checkMethod<foam::vector<double> >(Foam::fvMatrix<foam::vector<double> > const&, Foam::fvMatrix<foam::vector<double> > const&, char const*) in "/home/gcae504/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/turbFoam "
#3 Foam::tmp<foam::fvmatrix<foam::vector<double> > > Foam::operator+<foam::vector<double> >(Foam::tmp<foam::fvmatrix<foam::vector<double> > > const&, Foam::tmp<foam::fvmatrix<foam::vector<double> > > const&) in "/home/gcae504/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/turbFoam "
#4 main in "/home/gcae504/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/turbFoam "
#5 __libc_start_main in "/lib64/tls/libc.so.6"
#6 Foam::regIOobject::readIfModified() in "/home/gcae504/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/turbFoam "
From function checkMethod(const fvMatrix<type>&, const fvMatrix<type>&)
in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude/fvMatrix.C at line 1195.
Pretty strange!? It is the first time that I experienced such a problem. It worked so far well for other calculations... except this simple diffuser (it is the ercoftac workshop 2D asymmetric diffuser). Does anyone have a hint, what I am doing wrong?
Greetings!
Fabian
braennstroem is offline   Reply With Quote
Incompatible fields for operation divphi Ub vvqf OpenFOAM Running, Solving & CFD 4 April 4, 2018 03:28
Incompatible fields for operation tehache OpenFOAM Running, Solving & CFD 5 January 30, 2018 15:32
incompatible fields for operationproblem in simpleFoam kbr OpenFOAM Running, Solving & CFD 3 March 10, 2009 10:25
Incompatible fields for operation su_junwei OpenFOAM Pre-Processing 1 October 15, 2008 08:34
Question about simplefoam and turbFoam rogerio OpenFOAM Running, Solving & CFD 2 June 13, 2005 07:16
