Basic turbFoam error message
Old   August 14, 2007, 11:23
Default I have been using the tutorial
Eric Moore
sippycup is on a distinguished road
I have been using the tutorials to become familiar with OpenFOAM and have been trying to recreate a cfdesign "turbulent flow over heated cylinder" case to compare different cfd packages. I know how to use FoamX, paraview etc, but my experience with flow is pretty minimal... I'm mostly the computer guy that's trying to get it to work.
I've created a satisfactory 2d (3d in foam but 2d for my purposes) mesh: it's a pipe cut in half lengthwise, with half a circle cut out where the "heated cylinder" would is. I therefore have six patches: left (needs to be a velocity inlet at 50 m/s), right (pressure outlet at 0 pa) down and cylinder (symmetryplanes), and up (wallFunctions).
I could not find an explicit "velocity inlet" in FoamX for the left side. From the example "cavity" case in the turbFoam directory I decided to make it a "wallFunction" and defined 50 for the x coordinate.
I calculated k and epsilon values for my particular case and input them in FoamX. They are 9.375 and 188.7 respectively. I think the delta_t required for the courant number is something like 0.003 s.
What I'm having problems with is the p field file. I get the following error: Create mesh for
time = 0
Reading field p
--> FOAM FATAL IO ERROR : attempt to read beyond EOF
I'm guessing that it would try to read beyond the end of file if it wasn't finding everything it needed, but that's a pretty feeble guess.
I tried to compare the cavity p and my file for differences, and the only thing I see is that I defined a p=0 for the right patch, all of the cavity patches are zeroGradient, and my internalField is nonuniform, whereas the cavity one is set to 0. I'm going to append my p file to the end of this message. Any help at all would be greatly appreciated.
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
// Field Dictionary
FoamFile
version 2.0;
format ascii;
root "/home/flowloop/OpenFOAM/flowloop-1.4/run/tutorials/turbFoam";
case "2.20";
instance "0";
local "";
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField nonuniform;
boundaryField
down
type symmetryPlane;
right
type fixedValue;
value uniform 0;
up
type zeroGradient;
left
type zeroGradient;
cylinder
type symmetryPlane;
defaultFaces
type empty;
sippycup is offline   Reply With Quote
Old   August 14, 2007, 11:24
Default In the previous message, I lis
Eric Moore
In the previous message, I listed 5/6 patches. My 6th patches are the top and bottom of the 3d mesh, and I have set them to empty. I guess you can see that in the p file anyway, but just to clarify .
Old   August 14, 2007, 11:48
Default This is wrong: internalFiel
Alberto Passalacqua
This is wrong:
Try with something like:
internalField uniform 0.0;
Bye,
Alberto
Alberto Passalacqua
Old   August 14, 2007, 13:42
Default That fixed my error, thank you
Eric Moore
That fixed my error, thank you! Sadly I have another error, and I can't make any sense of it. This may be the result of me cloning the cavity case, then using a completely different mesh. I read somewhere about compiling solvers... would I need to do that for my situation? Thanks, Eric.
Selecting incompressible transport model Newtonian
Selecting turbulence model kEpsilon
#0 Foam::error::printStack(Foam:stream&)
#1 Foam::sigFpe::sigFpeHandler(int)
#2 Uninterpreted: [0xffffe420]
#3 Foam::turbulenceModels::kEpsilon::kEpsilon(Foam::G eometricField<foam::vector<dou ble>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::transportModel&)
#4 Foam::turbulenceModel::adddictionaryConstructorToT able<foam::turbulencemodels::k epsilon>::New(Foam::GeometricField<foam::vector<do uble>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::transportModel&)
#5 Foam::turbulenceModel::New(Foam::GeometricField<fo am::vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::transportModel&)
#6 main
#7 __libc_start_main
#8 __gxx_personality_v0 at /usr/src/packages/BUILD/glibc-2.3/csu/../sysdeps/i386/elf/start.S:122
^[[5~^[OH^[[5~^[[5~
Old   August 14, 2007, 13:57
Default You're probably initializing k
Alberto Passalacqua
You're probably initializing k and/or eps to zero. Check the value specified in k and epsilon dictionaries for the internalField.
A.
Alberto Passalacqua
Old   August 14, 2007, 14:34
Default I've got k set to 9.375 and ep
Eric Moore
I've got k set to 9.375 and eps set to 188.7. Do I need to set R and Nut as well? I left them blank.
Old   August 14, 2007, 14:44
Default For R: internalField unif
Alberto Passalacqua
For R:
internalField uniform (0 0 0 0 0 0 0 0 0);
For nuTilda:
internalField uniform 0;
Give a look to the turbFoam tutorial.
Alberto Passalacqua
Old   August 14, 2007, 15:00
Default I made sure those values were
Eric Moore
I made sure those values were set, but I still get the message.
Old   August 14, 2007, 15:16
Default Please post the case, so we ca
Alberto Passalacqua
Please post the case, so we can give it a look.
Regards,
A.
Alberto Passalacqua
Old   August 14, 2007, 15:49
Default Here's the entire thing. I don
Eric Moore
Here's the entire thing. I don't know that the mesh has enough resolution, but I'm mainly trying to get the solver to run right now.
http://web.utk.edu/~emoore20/cyl2.tar.gz
Thanks again,
Eric
Old   August 14, 2007, 16:09
Default Here are the issues: - In t
  #11
Alberto Passalacqua
- In transportProperties: nu = 0.
- Empty schemes field in fvSchemes:
divSchemes
default none;
div(phi,U) Gauss <>;
div(phi,k) Gauss <>;
div(phi,epsilon) Gauss <>;
div(phi,R) Gauss <>;
div(R) Gauss linear;
div(phi,nuTilda) Gauss <>;
div((nuEff*dev(grad(U).T()))) Gauss linear;
Plus all boundary conditions have zero velocity. I fixed these settings, and now the code runs, but of course you're solving for nothing, being U = 0.
correctedCase.tar.gz
Regards,
Alberto
Alberto Passalacqua
Old   August 14, 2007, 16:14
Default Note: I removed the mesh to cr
  #12
Alberto Passalacqua
Note: I removed the mesh to create a small file.
A.
Alberto Passalacqua
Old   August 15, 2007, 14:45
Default Thanks for looking at the code
  #13
Eric Moore
Thanks for looking at the code, now I can at least get some iterations done! However, I set left to [50 0 0] in the U field and the solver errors after completing t=0.03 after six iterations. When I view the results in parafoam, t=0.3 and even t=0 have the U field at infinity at all points and the p field is NaN at all points. Here's the error, any ideas?
#3 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const
#4 Foam::fvMatrix<double>::solve(Foam::Istream&)
#5 Foam::lduMatrix::solverPerformance Foam::solve<double>(Foam::tmp<foam::fvmatrix<doubl e> > const&)
#6 Foam::turbulenceModels::kEpsilon::correct()
#7 main
#8 __libc_start_main
#9 __gxx_personality_v0 at /usr/src/packages/BUILD/glibc-2.3/csu/../sysdeps/i386/elf/start.S:122
Old   August 15, 2007, 14:59
Default I think it may be the courant
  #14
Eric Moore
I think it may be the courant number... isn't it supposed to be under 1?
Time = 0.03
Courant Number mean: 1.07121e+48 max: 1.51093e+51
DILUPBiCG: Solving for Ux, Initial residual = 7.37701e-06, Final residual = 7.37701e-06, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 2.56253e-06, Final residual = 2.56253e-06, No Iterations 0
DICPCG: Solving for p, Initial residual = 1, Final residual = 5.79649e-07, No Iterations 104
time step continuity errors : sum local = 5.76439e+60, global = 3.20979e+58, cumulative = 3.20979e+58
DICPCG: Solving for p, Initial residual = 3.18555e-12, Final residual = 3.18555e-12, No Iterations 0
time step continuity errors : sum local = 5.19003e+167, global = -1.3427e+151, cumulative = -1.3427e+151
Old   May 18, 2008, 23:45
Default Eric......... What have you do
  #15
Mohd Yousuf
yousuf is on a distinguished road
Eric......... What have you done to decrease the courant no. in the above case?
yousuf is offline   Reply With Quote
Turbfoam error danie OpenFOAM Running, Solving & CFD 2 July 30, 2008 07:45
Error message-Floating point error Vaibhav FLUENT 3 December 7, 2007 05:38
Error turbFoam jackdaniels83 OpenFOAM Running, Solving & CFD 11 June 27, 2007 14:22
ERROR MESSAGE: line 1: parse error Lourival FLUENT 1 February 18, 2006 01:35
Gambit 2.0 - Error Message (ACIS ERROR 1200) James FLUENT 1 May 14, 2003 08:13
