Problem with reconstructing parallel results
Old   May 15, 2008, 17:09
Default Dear all, I am keep getting
Quinn Tian
qtian is on a distinguished road
Dear all,
I am keep getting this error message while I tried to reconstruct parallel results. I am running rasInterfoam. There is no problem while running parallel. Does this have anything to do with the boundary condition setup? Thanks for your help.
Reconstructing volScalarFields
pd
epsilon
gamma
k
Reconstructing volVectorFields
U
#0 Foam::error::printStack(Foam:stream&) in "/home/qtian/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/home/qtian/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib/libc.so.6"
#3 Foam::pressureInletOutletVelocityFvPatchVectorFiel d::rmap(Foam::fvPatchField<foa m::vector<double> > const&, Foam::List<int> const&) in "/home/qtian/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libfiniteVolume.so"
#4 Foam::tmp<foam::geometricfield<foam::vector<double >, Foam::fvPatchField, Foam::volMesh> > Foam::fvFieldReconstructor::reconstructFvVolumeFie ld<foam::vector<double> >(Foam::IOobject const&) in "/home/qtian/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/reconstruc tPar"
#5 void Foam::fvFieldReconstructor::reconstructFvVolumeFie lds<foam::vector<double> >(Foam::IOobjectList const&) in "/home/qtian/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/reconstruc tPar"
#6 main in "/home/qtian/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/reconstruc tPar"
#7 __libc_start_main in "/lib/libc.so.6"
#8 Foam::regIOobject::readIfModified() in "/home/qtian/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/reconstruc tPar"
Segmentation fault (core dumped)
Quinn
qtian is offline   Reply With Quote
Old   May 15, 2008, 17:30
Default Search for pressureInletOutlet
Mattijs Janssens
mattijs is on a distinguished road
Search for pressureInletOutletVelocityFvPatchVectorField or rmap and you'll find
http://www.cfd-online.com/OpenFOAM_D...es/1/6021.html
which gives a fix.
mattijs is offline   Reply With Quote
Serial vs parallel different results luca OpenFOAM Bugs 2 December 3, 2008 10:12
Reconstructing Coefficient Matrix from lduAddressing Object cliffoi OpenFOAM Running, Solving & CFD 0 December 7, 2007 07:16
results with parallel processing Muhammad Shakaib Main CFD Forum 1 December 29, 2005 00:56
CFX-5.7 MPICH Parallel Problem (Output of Results) James Date CFX 7 February 15, 2005 16:03
view the results from parallel v3.2 matej Siemens 3 July 30, 2004 02:13
