SonicFoam forwardStep Tutorial OF 14
Old   June 9, 2007, 12:51
Default Hey all, I wanted to run the
tutlhino
Hey all,
I wanted to run the tutorial case of sonicFoam - forwardStep and didn't change anything, but it didn't work in OF 1.4. But in OF 1.3 the tutorial case works. Do you know what the problem could be? So the simulation starts but after a while of computing it stops with the following error message:
Courant Number mean: 1.77239e+19 max: 1.46681e+23
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
#0 Foam::error::printStack(Foam:stream&)
#1 Foam::sigFpe::sigFpeHandler(int)
#2 Uninterpreted: [0xb7fa1420]
#3 Foam::DILUPreconditioner::DILUPreconditioner(Foam: :lduMatrix::solver const&, Foam::Istream&)
#4 Foam::lduMatrix::preconditioner::addasymMatrixCons tructorToTable<foam::dilupreco nditioner>::New(Foam::lduMatrix::solver const&, Foam::Istream&)
#5 Foam::lduMatrix::preconditioner::New(Foam::lduMatr ix::solver const&, Foam::Istream&)
#6 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const
#7 Foam::fvMatrix<foam::vector<double> >::solve(Foam::Istream&)
#8 Foam::lduMatrix::solverPerformance Foam::solve<foam::vector<double> >(Foam::tmp<foam::fvmatrix<foam::vector<double> > > const&)
#9 main
#10 __libc_start_main
#11 __gxx_personality_v0 at /usr/src/packages/BUILD/glibc-2.3/csu/../sysdeps/i386/elf/start.S:122
Gleitkomma-Ausnahme
Unfortunately I need the OF-Version 1.4 where I can take the GAMG-Solver. But at first I've got to make the tutorial case run...
Cheers
Florian
Old   June 9, 2007, 13:45
Default Courant Number mean: 1.77239e+
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
That clearly indicates divergence.
msrinath80 is offline   Reply With Quote
Old   June 9, 2007, 14:09
Default Thanks, that's what I also tho
tutlhino
Thanks, that's what I also thought of. But as it is a tutorial case I thought that can't be. So if anyone experienced that problem as well and knows how to fix the problem...I'd appreciate it!
Cheers
Florian
Old   June 10, 2007, 07:09
Default Is there nobody who has experi
tutlhino
Is there nobody who has experienced the same problem, or knows where to look?
Old   June 10, 2007, 07:20
Default Give it some time. There is a
Give it some time. There is a workshop in progress. Folks are busy. I'm sure someone will respond.
Old   June 10, 2007, 11:15
Default I just checked and the issue c
Alberto Passalacqua
I just checked and the issue can be easily reproduced.
The problem is not reduced by using a smaller time step too.
With dt = 0.002 s, the divergens happens at 1.636s, while reducing dt = 0.002s it happens at 0.063s, and with dt = 0.0005s, I have divergence at 0.0645s.
Regards,
A.
Alberto Passalacqua
Old   June 10, 2007, 11:28
Default Well I tried the same and with
tutlhino
Well I tried the same and with dt=0.003 s it worked, so there was no error-message! I'll try it again but I think this change will fix the problem!
Old   June 10, 2007, 11:38
Default Yes, I can confirm the result!
tutlhino
Yes, I can confirm the result! dt=0.003s solves the problem.
Old   June 10, 2007, 12:37
Default Yes, I checked too. With dt =
Alberto Passalacqua
Yes, I checked too. With dt = 0.003s it doesn't diverge. But this leaves some doubt. Why should it diverge with a smaller time step?
Regards,
A.
Alberto Passalacqua
Old   June 10, 2007, 12:39
Default At the beginning you had dt=0.
tutlhino
At the beginning you had dt=0.002s, so you have increased it! But nevertheless it should work also for higher dts..
Old   June 10, 2007, 12:44
Default I tried the GAMG in that case,
  #11
tutlhino
I tried the GAMG in that case, but it took 5 seconds more than with the standard sovers, although I took the same values for the residuum...!? Any ideas why that can be?
By the way, thanks for helping me to find the source of the error in the simplefoam tutorial.
Regards
Florian
Old   June 10, 2007, 12:47
Default Exactly. It's not clear why we
  #12
Alberto Passalacqua
Exactly. It's not clear why we obtain a stable solution with a higher time step, while it diverges with a smaller one.
The Courant number should be lower with the smallest time step and, as a consequence, you should not notice instabilities. By increasing it you're probably loosing some oscillation which were the cause of the divergence.
Regards,
A.
Alberto Passalacqua
Old   June 10, 2007, 14:45
Default I opened a bug-report, so that
  #13
Alberto Passalacqua
I opened a bug-report, so that Henry and OpenCFD guys can read it more easily.
http://www.cfd-online.com/OpenFOAM_D...tml?1181501044
Regards,
A.
Alberto Passalacqua
Old   June 10, 2007, 15:15
Default This is an error in case setup
  #14
Hrvoje Jasak
This is an error in case setup: wrong outlet boundary conditions on U, p and T in the tutorial..
Change them to zeroGradient (currently, they are inletOutlet) and all works fine.
Hrv
Hrvoje Jasak
Old   June 10, 2007, 15:17
Default Sorry, slight imprecision: the
  #15
Hrvoje Jasak
Sorry, slight imprecision: the boundary condition on p should remain wave transmissive. It is only the inletOutlet stuff that's wrong.
Hrv
Hrvoje Jasak
Old   June 10, 2007, 15:38
Default Thanks! I attached the correct
  #16
Alberto Passalacqua
Thanks! I attached the correct tutorial to the bug section.
Alberto
Alberto Passalacqua
Old   May 1, 2008, 16:09
Default I've experienced the same prob
  #17
Roberto
robbo is on a distinguished road
I've experienced the same problem but I don't understand how to change the boundary conditions at outlet.
I'm using foamX and in the patches menu i select for the outlet "pressure transmissive outlet". In this case i don't manage to change the entries for pressure, velocity and temperature. how to do this?
I've also noted one thing. In the programmer's guide is indicated to specify belong the thermodynamic properties also the thermal conductivity (wich i think is used in the energy equation). Unfortunately i've not found any place to insert it... is this superfluous? I don't think so but i've found no place to specify it.
thanks
Roberto
robbo is offline   Reply With Quote
SonicFoam stvtiegh OpenFOAM Running, Solving & CFD 1 June 26, 2008 09:30
SonicFoam 141dev changes what do they mean mike_jaworski OpenFOAM Running, Solving & CFD 0 December 30, 2007 15:55
SonicFoam divphiU dimi OpenFOAM Running, Solving & CFD 3 June 25, 2007 05:47
Help me with sonicFoam marcelo OpenFOAM Running, Solving & CFD 6 December 10, 2005 02:57
ForwardStep tutorial didomenico OpenFOAM Running, Solving & CFD 1 November 2, 2005 11:57
