March 29, 2006, 14:10 |
Hi! I am trying to run OpenFOA
Bei
Rep Power: 17 |
Hi! I am trying to run OpenFOAM-1.2 in parallel using MPI (not LAM). I get the error message below:
--> FOAM FATAL ERROR : Trying to use the dummy Pstream library. This dummy library cannot be used in parallel mode From function Pstream::init(int& argc, char**& argv) in file Pstream.C at line 48. FOAM exiting Would anyone please tell me how to fix this problem? Many thanks in advance! |
April 12, 2008, 08:43 |
My suggestion is that you coul
Daniel WEI (老魏)
Rep Power: 21 |
My suggestion is that you could try to comment out the bool Pstream::init(int& argc, char**& argv) in src/Pstream/dummy/Pstream.C, and then mpirun your program and see what happened!
Daniel
~ Daniel WEI ------------- Boeing Research & Technology - China Beijing, China |
PStream problems | msrinath80 | OpenFOAM Running, Solving & CFD | 1 | December 25, 2006 05:38 |
Error in opening the UDF library | Sri | FLUENT | 3 | December 11, 2006 16:19 |
Error when loading a shared library | rid | FLUENT | 4 | May 29, 2006 14:51 |
PROBLEM OF PRALLEL FLUENT HELP!!!!!!!!!!!1 | nabeel | FLUENT | 4 | October 11, 2005 03:14 |
