MRFZonesC questions what is the mesh_V and why only Coriolis force no centrifugal force
Old   April 1, 2008, 02:09
Default hi every one! i have some
wayne.zhang
waynezw0618 is on a distinguished road
Send a message via MSN to waynezw0618 Send a message via Skype™ to waynezw0618
hi every one!
i have some question about MRFZones.C
in void Foam::MRFZone::addCoriolis(fvVectorMatrix& UEqn) const:
const labelList& cells = mesh_.cellZones()[cellZoneID_];
const scalarField& V = mesh_.V();Q1:what is the mesh_.V()?
forAll(cells, i)
Usource[cells[i]] -= V[cells[i]]*(Omega ^ U[cells[i]]);
Q2:here coriolis force is equal to "omega u",but i think it should be "1/2 * omega u" and also there is no centrifugal force which is "omega(omegar)",so if i want to calculate the flow in the turbins? would i need to modify the them both?
thanks
wayne
waynezw0618 is offline   Reply With Quote
Old   April 1, 2008, 07:12
Default Hi Wayne, I think that in an
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hi Wayne,
I think that in an absolute velocity formulation, the Coriolis force (2rwxU_relative) and centripet force (rwxwxr) can be written as: rwxU
I hope this is helpful,
Dragos
dmoroian is offline   Reply With Quote
Old   April 1, 2008, 07:13
Default ...and mesh_.V() retuns the ce
dmoroian's Avatar
Dragos
...and mesh_.V() retuns the cell volume
Old   April 1, 2008, 10:17
Default Hi Dragos: i don` think so.
wayne.zhang
Hi Dragos:
i don` think so.if we write the moment equ in rotating frame, the velocity is relative velocity (W),and in the absolute frame the equation is without the coriolis force and centrifugal force.
in MRF:
rho*D(W_relative)/Dt=F(total,including pressure,viscosity)+omega(omegar)-2* omega u
in absolute frame:
rho*D(U_absolute)/Dt =F
according to you should be
rho*D(U_aboslute)/dt= F+ * omega U
i dont think it will be
rho*D(W_aboslute)/dt= F+ * omega U
for the solver just treat one velocity not two
thanks alot
yours wayne
Old   April 1, 2008, 10:20
Default i am sorry, there is a "*" be
wayne.zhang
i am sorry, there is a "*" before "omega U" for last two equ.it is typing error of mine
thanks
wayne
Old   April 2, 2008, 02:22
Default I had a vague memory in the ba
dmoroian's Avatar
Dragos
I had a vague memory in the back of my mind when I wrote the above post, but I've just dug for it and here it is...
In the absolute velocity formulation and for a steadily rotating frame the flow equations can be written as follows:
- continuity:
- momentum:
- energy:
where the relative velocity is:
and the transport velocity is:
You can also check the fluent user manual for it.
Dragos
Old   April 2, 2008, 04:29
Default Hi Dragos thanks a lot! i
wayne.zhang
Hi Dragos
thanks a lot!
i could understand it now!
the relative velocity is as calculating in the memeber function relativeflux,so moment eqution should be div(phi,u),is that right?
thanks
waye
Old   April 2, 2008, 04:40
Default Hi Wayne, This is exactly wha
dmoroian's Avatar
Dragos
Hi Wayne,
This is exactly what it is written in the momentum predictor:
tmp<fvvectormatrix> UEqn
<blockquote>fvm::div(phi, U)
+ turbulence->divR(U)
</blockquote>
Dragos
Old   April 3, 2008, 00:08
Default Hi Dragos but why the flow p
wayne.zhang
Hi Dragos
but why the flow pattern of the result looks like U is relative velocity
wayne
Old   April 3, 2008, 01:09
Default well Wayne, if it is like that
dmoroian's Avatar
Dragos
well Wayne, if it is like that I agree with you: it is strange.
Can you post a picture with an example?
Dragos
Old   April 3, 2008, 02:41
Default Hi dragos the result of mixv
  #11
wayne.zhang
Hi dragos
the result of mixvessl2D in tut looks likes the U is absolute velocity
Old   April 3, 2008, 02:57
Default http://www.cfd-online.com/Open
  #12
wayne.zhang
Old   April 3, 2008, 03:18
wayne.zhang
Old   April 3, 2008, 03:19
  #14
wayne.zhang
Old   April 3, 2008, 03:35
Default Hi sorry i try a lot here i
  #15
wayne.zhang
Hi sorry
i try a lot
here is the result of mixvessl2D(vector on the rotor),you can see clearly the velocity profile relative to the omega
and then is my case a 3d centrifugal impeller
a vector plot of U in the impeller z=1/2thick
b vector plot on the blade
Old   April 3, 2008, 03:44
Default mix2d http://www.cfd-online.c
  #16
wayne.zhang
mix2d
Old   April 3, 2008, 03:49
  #17
dmoroian's Avatar
Dragos
Lots of tries!
Well in the picture I can see, the vectors look ok to me!
Be careful to have pictures with dimensions of less than 50kb.
Dragos
Old   April 3, 2008, 03:50
Default a vector plot of U in the impe
  #18
wayne.zhang
Old   April 3, 2008, 03:58
Default b vector plot on the blade ht
  #19
wayne.zhang
Old   April 3, 2008, 03:59
Default c relative velocity (at the s
  #20
wayne.zhang
c relative velocity (at the same conditon) calculated by CFX
Centrifugal force/ Rotating Wall david FLUENT 4 January 2, 2014 06:30
centrifugal force sue FLUENT 0 November 25, 2008 03:01
cyclone separator- centrifugal force kumar FLUENT 2 May 29, 2008 03:33
Cyclone separator-centrifugal force aPpA FLUENT 0 July 6, 2005 14:22
Coriolis force Saturn FLUENT 5 September 30, 2004 15:56
