February 13, 2008, 15:01 |
I need to solve a non-
J. T.
Rep Power: 17 |
I need to solve a non-Newtonian flow problem and would like to use a Newtonian solution as the initial guess. Do I have to run the application separately and use mapFields to map the first solution onto the second? The mesh is the same, is it possible to put the two together in one application? Any information about this is greatly appreciated. |
February 14, 2008, 18:05 |
Found a simple solutio
J. T.
Rep Power: 17 |
Found a simple solution: because what I am interested in is steady flow only, I can run the solver with Newtonian model in the first several time steps, then switch back to the non-Newtonian model I want to use. The convergence is much faster. Thanks. |
February 17, 2008, 05:07 |
hi,
this paper helped me a
Stephan Gerber
Rep Power: 17 |
hi,
this paper helped me a lot, so maybe it's nice for you too?!: Issa, "Solution of the implitly Discretised fluid flow equation by operator splittiing" in J. of Comp. Phys. No. 62, 1985, S. 40-65 there is another one about bouyant flow which might be interesting too.. br stephan |
February 17, 2008, 05:08 |
hi,
sorry this was the wron
Stephan Gerber
Rep Power: 17 |
hi,
sorry this was the wrong thread stephan |
MapFields only on internal fields | cosimobianchini | OpenFOAM Pre-Processing | 5 | May 5, 2020 06:08 |
MapFields | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Pre-Processing | 18 | September 28, 2017 11:06 |
MapFields does not work | hartinger | OpenFOAM Pre-Processing | 13 | September 22, 2014 03:14 |
MapFields failure or incorrect mesh | jvn | OpenFOAM Pre-Processing | 19 | November 29, 2012 06:13 |
MapFields turbulent pipe flow | anita | OpenFOAM Pre-Processing | 5 | July 3, 2008 23:29 |
