Position of cells in a orthogonal grid
Old   February 5, 2008, 21:31
Default Hello, I'm using a structur
Alberto Passalacqua
I'm using a structured (orthogonal squared cells) grid, and I need to implement an algorithm which requires the values of a variable in the "above"/"below", "left"/"right", "front"/"back" cells.
Is there a quick way to identify these cells?
Alberto Passalacqua
Old   February 6, 2008, 03:01
Default short answer: hmmm, sort of.
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
The fastest way as I see it is to access all the faces, check their face-normals and depending on their direction determine if they are left or right, et c.
from that create a mapping of left -> face i, right -> face j, et c.
(which of course require some mesh class hacking)
you probably only need to do this once for a static mesh and after this it should be fast.
niklas is offline   Reply With Quote
Old   February 6, 2008, 12:28
Default Hmmm. Thanks for your reply Ni
Alberto Passalacqua
Hmmm. Thanks for your reply Niklas.
I have a doubt on how the boundary cells are managed. I mean, I have 4 neighbours for the "internal" cells, but only 2 or 3 for the boundary cells, which are exceptions because they have one or more lacking "directions".
How that procedure can identify them?
Regards,
Alberto
Alberto Passalacqua
elliptic grid generation (orthogonal) vasu Main CFD Forum 8 October 28, 2015 15:20
[Other] 3D curvlinear orthogonal bodyfitted grid maka OpenFOAM Meshing & Mesh Conversion 1 February 13, 2014 12:17
orthogonal grid generation Bounecer Main CFD Forum 2 July 9, 2007 00:06
Poisson solver - orthogonal grid Fuka Main CFD Forum 0 May 11, 2006 11:19
2-D orthogonal grid generation Jenny Rhong Main CFD Forum 3 February 10, 2004 19:51
