Error in icofoam forTpipe
Old   January 21, 2008, 01:48
Default Hi, I start to learn OpenFOA
Kuul Sergey
sergey is on a distinguished road
I start to learn OpenFOAM and try to make my own mesh for T pipe inside icofoam tutorial case. I would very thankful if somebody can describe how to deal with errors that I have in log file. CheckMesh says that mesh is OK. The pressure and velocity b.c. seem to be consistent:
U
"internalField uniform (0 0 0);
boundaryField
inlet_F
type fixedValue;
value uniform (0.1 0 0);
outlet_F1
type zeroGradient;
outlet_F2
type zeroGradient;
pipe
type fixedvalue;
value uniform (0 0 0);
P
"internalField uniform 0;
boundaryField
inlet_F
type zeroGradient;
outlet_F1
type fixedvalue;
value uniform 0;
outlet_F2
type fixedvalue;
value uniform 0;
pipe
type zeroGradient;
I use default fvSchemes and fvSolution files.
Log file contains the following info:
"Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
Reading field U
Starting time loop
Time = 0.001
Courant Number mean: 0 max: 0
--> FOAM FATAL ERROR : gradientInternalCoeffs cannot be called for a defaultFvPatchField.
(Actual type fixedvalue)
You are probably trying to solve for a field with a default boundary conditions.
From function defaultFvPatchField<type>::gradientInternalCoeffs( ) const
in file fields/fvPatchFields/basicFvPatchFields/default/defaultFvPatchField.C at line 489.
FOAM exiting"
The same errors are for the same mesh and b.c.even in potentialfoam
Thanks,
Sergey.
sergey is offline   Reply With Quote
IcoFoam continuity error in 2D transient simulation finch OpenFOAM Running, Solving & CFD 15 June 29, 2016 10:39
Foam error in icoFoam cavityClipped although the mesh is good mgz1985 OpenFOAM Running, Solving & CFD 3 May 8, 2014 10:39
OF15 glibc error upon successful completion of icoFoam run aunola OpenFOAM Bugs 10 April 24, 2009 03:27
Error while running icoFoam OpenFOAM15 skabilan OpenFOAM Running, Solving & CFD 6 September 5, 2008 00:04
Tow Critical Error about GCC amp icoFoam chnrdu OpenFOAM Installation 4 July 8, 2005 06:14
