Outlet conditions in BuoyantFoam
Old   October 13, 2007, 13:58
Default Hi, having some problems w
Jon Tegner
jont is on a distinguished road
having some problems with outlet-conditions in a BuoyantFoam simulation. Case is basically the same as the hotRoom tutorial case, BUT with an inlet and an outlet with given pressure both at inlet and outlet (and hence producing a "chimney" effect). On the inlet pressureInlet is used, and on the outlet pressureOutlet. The last means that a fixed value is used for the pressure at the outlet, but for all other variables zeroGradient is used. This seems to work fine in most cases, but in some situations a very small "backflow" develops at the outlet, and as soon as this happens the solution becomes unstable (starting with the temperature). Are there other, "better suited", boundary conditions I can use in this situation?
jont is offline   Reply With Quote
Old   October 15, 2007, 04:27
Default Check out the inletOutlet-clas
Assistant Moderator
Bernhard Gschaider
Check out the inletOutlet-class of boundary conditions (fixedValue for inflow, zeroGradient for outflow) in the table 6.4 of the UserGuide. Use that for the temperature.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   October 15, 2007, 07:55
Default Thanks! Thought they were o
Jon Tegner
Thanks!
Thought they were only applicable to pressure, but seems to be running...
/jon
Re: Pressure Outlet Conditions Andrew FLUENT 1 December 20, 2006 13:36
outlet Boundary conditions sivasamy Main CFD Forum 2 December 19, 2005 01:01
Defining Outlet conditions Luis CFX 0 April 4, 2005 20:36
outlet conditions tzapelina Phoenics 3 January 16, 2004 04:07
Outlet boundary conditions hicham FATNASSI Main CFD Forum 8 February 9, 2000 02:58
