Error found in stress tutorial
Old   September 23, 2007, 02:34
Default I found a bug in the 1.4.1 rel
Michael Jaworski
mike_jaworski is on a distinguished road
I found a bug in the 1.4.1 release.
While attempting to complete the solidDisplacementFoam tutorial, the following error comes up when you try to run it:
--> FOAM FATAL IO ERROR : expected 'true' or 'false', found yes
file: /home/mjaworsk/OpenFOAM/mjaworsk-1.4.1/run/tutorials/solidDisplacementFoam/plate Hole/system/fvSolution::D::scaleCorrection at line 41.
From function operator>>(Istream&, bool&)
in file primitives/bool/boolIO.C at line 72.
FOAM exiting
In order to fix it, you have to go into the fvSolution file and edit the information for "scale correction" and "directSolveCoarsest" from yes/no to true/false. Unfortunately, FoamX doesn't allow you to do it, so you have to get into it with your favorite editor. I'm guessing something was cleaned up in the GAMG code going to 1.4.x and certain files just haven't been updated.
I hope this helps someone somewhere down the line. I didn't go through all the steps in the cavity tutorial, but I wonder if any of these other items got borked with the transition to 1.4.1
mike_jaworski is offline   Reply With Quote
injection not found in domain error San FLUENT 3 March 17, 2009 22:24
Error: Finite angle gap could not be found Richard CFX 0 December 8, 2005 08:39
Some problem about tutorial stress analysis of plate with hole ztdep OpenFOAM Running, Solving & CFD 0 August 12, 2005 07:05
Boundaries not found error Simone Siemens 2 June 13, 2005 07:36
No warning or error messages found. Atit Koonsrisuk CFX 5 January 14, 2003 11:06
