PerturbU
Like Tree22Likes
Old   July 3, 2007, 05:22
Default Hi to all, I am a new openF
hadi tartoussi
hadi is on a distinguished road
Hi to all,
I am a new openFoam user,and i would like to know if the perturbU utility exists by default in openFOam or i should add it?
can u please tell me how to get this utility?
thanks in advance
Hadi
hua1015 likes this.
hadi is offline   Reply With Quote
Old   July 3, 2007, 07:00
Default Hello, it's not included in O
Alberto Passalacqua
it's not included in OpenFOAM. You can download it here:
- For a channel:
http://www.cfd-online.com/OpenFOAM_D...ages/1/40.html
- For a cylinder:
http://www.cfd-online.com/OpenFOAM_D...es/1/2946.html
With kind regards,
Alberto
Alberto Passalacqua
Old   July 3, 2007, 07:23
Default Thank you very much Alberto
hadi tartoussi
regards
Hadi
Old   December 14, 2013, 13:44
pante is on a distinguished road
hello,
I try to download perturbU utility for using it in a pipe flow, but for some reason I get a file of type .unk (unknown). Can anyone provide me a valid link for downloading perturbU utility?
pante is offline   Reply With Quote
Old   December 14, 2013, 18:21
Retired Super Moderator
Bruno Santos
Greetings pante,
The old forum had this safety mechanism, where the attached files were renamed to always have the file extension ".unk".
The solution is simple: after you download the file, you have to manually rename the file extension to the correct extension, as indicated on the surrounding text for the link you used for the download. In this case, change "unk" to "tgz".
Best regards,
Bruno
songwukong and gu1 like this.
Old   March 10, 2014, 07:23
sqing
Sunxing is on a distinguished road
- For a channel:
With kind regards,
Alberto
Hi Alberto,
I'm using the perturbU utility to generate a terbulent initial filed for a wall-jet case. However, I don't know how to set the parameters in the perturbUDict, such as duplus, betaPlus, alphaPlus, sigma and epsilon. Is there a rule for setting them?
The following picture is the schematic of the domain for my case.
Best Regards.
sunxing
File Type: jpg schematic of the domain for wall jet case.jpg (12.7 KB, 291 views)
watermelon likes this.
Sunxing is offline   Reply With Quote
Old   April 10, 2014, 10:01
aylalisa is on a distinguished road
Dear Sunxing,
did you read thesis of Eugene de Villiers:
"The Potential of Large Eddy Simulation for the Modeling of Wall Bounded Flows"
Page. 164 ff. and the the file perturbU.C till line 78.
It does not directly answer your question but could improve understanding.
Best regards,
aylalisa
JamesCC and watermelon like this.
aylalisa is offline   Reply With Quote
Old   April 10, 2014, 20:22
sqing
Originally Posted by aylalisa View Post
Dear Sunxing,
Best regards,
aylalisa
Hi aylalisa,
Thanks for your reply.
Regards
Sunxing
Old   April 11, 2014, 04:16
Hi Sunxing,
I've found yesterday (after I've replied your thread): http://lists.cfd-online.com/pipermai...ch/019398.html
Aylalisa
Old   May 7, 2014, 06:27
Niu
Z.Q. Niu is on a distinguished road
Hello aylalisa,
I has download purturbU from http://www.cfd-online.com/OpenFOAM_D...ages/1/40.html for channel.I wmake it in my open foam 2.2.0, but it points that "mathematicalConstant" is not declared. Do you wmake perturbU successfuly? would you mind sending me your file of perturbU? My email is silence@tju.edu.cn
Thank you !
Z.Q. Niu is offline   Reply With Quote
Old   May 7, 2014, 14:45
amanbearpig is on a distinguished road
I do not have version 2.2.0, but I encountered the same issue in 2.2.2. It's due to how pi is defined in different versions of OpenFOAM. Thankfully it is not a difficult fix.
If you edit the .C perturbU file and change any references (I believe there are 2) of 'mathematicalConstant' to 'constant::mathematical', this should rectify the issue.
songwukong likes this.
amanbearpig is offline   Reply With Quote
Old   May 7, 2014, 22:27
Niu
Thank you, amanbearpig! I have solved it ,the problem is indeed due to mathematicalConstant, I has corrected it successfully!
Old   May 9, 2014, 01:27
adambarfi's Avatar
Mostafa Mahmoudi
adambarfi is on a distinguished road
Send a message via Yahoo to adambarfi Send a message via Skype™ to adambarfi
here you are the modified perturbU utility for OF-2.0.0 to OF-2.3.0:
songwukong, mgg, Artur and 2 others like this.
adambarfi is offline   Reply With Quote
Old   May 27, 2014, 03:50
adambarfi's Avatar
Mostafa Mahmoudi
hi everybody,
The perturbU utility was ran for channel395 correctly. I changed the geometry to a perfect channel which the conditions at inlet and outlet patches are cyclic. then I ran the perturbU but it set a zero velocity field for U. I can't understand why it didn't make any perturbation of my velocity field?????
anybody knows what and where is the problem?
the blockMeshDict is as follow:
|  \\    /   O peration     | Version:  2.1.0                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
vertices
    (0 0 0)
    (1 0 0)
    (1 1 0)
    (0 1 0)
    (0 0 4)
    (1 0 4)
    (1 1 4)
    (0 1 4)
    (2 0 0)
    (2 1 0)
    (2 0 4)
    (2 1 4)
    (1 2 0)
    (0 2 0)
    (1 2 4)
    (0 2 4)
    (2 2 0)
    (2 2 4)
blocks
    hex (0 1 2 3 4 5 6 7) (25 25 20) simpleGrading (10 10 1)
    hex (1 8 9 2 5 10 11 6) (25 25 20) simpleGrading (0.1 10 1)
    hex (3 2 12 13 7 6 14 15) (25 25 20) simpleGrading (10 0.1 1)
    hex (2 9 16 12 6 11 17 14) (25 25 20) simpleGrading (0.1 0.1 1)
edges
boundary
    outlet1_1
        type cyclic;
        neighbourPatch  inlet1_1;
        faces
            (4 7 6 5)
    inlet1_1
        type cyclic;
        neighbourPatch  outlet1_1;
        faces
            (0 3 2 1)
    outlet1_2
        type cyclic;
        neighbourPatch inlet1_2;
        faces
            (5 6 11 10)
    inlet1_2
        type cyclic;
        neighbourPatch  outlet1_2;
        faces
            (1 2 9 8)
    outlet2_1
        type cyclic;
        neighbourPatch  inlet2_1;
        faces
            (7 15 14 6)
    inlet2_1
        type cyclic;
        neighbourPatch  outlet2_1;
        faces
            (3 13 12 2)
    outlet2_2
        type cyclic;
        neighbourPatch  inlet2_2;
        faces
            (6 14 17 11)
    inlet2_2
        type cyclic;
        neighbourPatch  outlet2_2;
        faces
            (2 12 16 9)
    fixedWalls
        type wall;
        faces
            (4 7 3 0)
            (7 15 13 3)
            (10 11 9 8)
            (11 17 16 9)
            (4 0 1 5)
            (5 1 8 10)
            (15 13 12 14)
            (14 12 16 17)
mergePatchPairs
and the perturbUDict is as
|  \\    /   O peration     | Version:  1.0                                   |
|   \\  /    A nd           | Web:      http://www.openfoam.org               |
FoamFile
    version         2.0;
    format          ascii;
    instance        "system";
    class           dictionary;
    object          perturbUDict;
// Expected turbulent Re(tau) Reynolds number with respect to utau
Retau 395;
// Streamwise component of flow. 0=x, 1=y, 2=z
streamwise 2;
// Spanwise component of flow. 0=x, 1=y, 2=z
spanwise 1;
// Halfheight of channel. This is the direction normal to both streamwise and
// spanwise directions.
h 1;
// Set (overwrite) velocity to laminar profile
setBulk true;
// Perturb velocity with some cosine like perturbations
perturb false;
// Perturbation properties
//wall normal circulation as a fraction of Ubar/utau
duplus 0.25;
//spanwise perturbation spacing in wall units
betaPlus 200;
//streamwise perturbation spacing in wall units
alphaPlus 500;
//transverse decay
sigma 0.00055;
//linear perturbation amplitude as a fraction of Ubar
epsilon 0.005;
any tip or hint would be appreciated.
Regards,
Mostafa
Old   May 27, 2014, 04:51
adambarfi's Avatar
Mostafa Mahmoudi
Originally Posted by adambarfi View Post
hi everybody,
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
convertToMeters 1;
vertices
    (0 0 0)
    (1 0 0)
    (1 1 0)
    (0 1 0)
    (0 0 4)
    (1 0 4)
    (1 1 4)
    (0 1 4)
    (2 0 0)
    (2 1 0)
    (2 0 4)
    (2 1 4)
    (1 2 0)
    (0 2 0)
    (1 2 4)
    (0 2 4)
    (2 2 0)
    (2 2 4)
blocks
edges
boundary
    outlet1_1
        type cyclic;
        faces
            (4 7 6 5)
    inlet1_1
        type cyclic;
        faces
            (0 3 2 1)
    outlet1_2
        type cyclic;
        faces
            (5 6 11 10)
    inlet1_2
        type cyclic;
        faces
            (1 2 9 8)
    outlet2_1
        type cyclic;
        faces
            (7 15 14 6)
    inlet2_1
        type cyclic;
        faces
            (3 13 12 2)
    outlet2_2
        type cyclic;
        faces
            (6 14 17 11)
    inlet2_2
        type cyclic;
        faces
            (2 12 16 9)
    fixedWalls
        type wall;
        faces
            (4 7 3 0)
            (7 15 13 3)
            (10 11 9 8)
            (11 17 16 9)
            (4 0 1 5)
            (5 1 8 10)
            (15 13 12 14)
            (14 12 16 17)
mergePatchPairs
FoamFile
    version         2.0;
    format          ascii;
    instance        "system";
    class           dictionary;
Retau 395;
streamwise 2;
spanwise 1;
h 1;
setBulk true;
perturb false;
duplus 0.25;
betaPlus 200;
alphaPlus 500;
//transverse decay
sigma 0.00055;
epsilon 0.005;
Regards,
Mostafa
solved, I made a mistake and defined the Ubar=(0.1335 0 0) instead of Ubar=(0 0 0.1335).
sorry for that
Regards,
Mostafa
Old   March 21, 2015, 13:34
Bruno Santos
Greetings to all!
I've given a proper wiki page and git repository to perturbU and all of the 3 variants I found that were made by Eugene de Villiers:
May anyone feel free to update that wiki page and fork from that repository!
Best regards,
Bruno
songwukong and rt08 like this.
Old   June 1, 2015, 05:54
Default perturbU + precursor inlet
  #17
SM
canopus is on a distinguished road
Hi!
I want to do LES of a diffuser.
For the inlet I want to run a precursor LES of channel for which I set cyclic for inlet and outlet.
Then I run perturbUChannel but the original 0/U file is replaced by some numbers.
Is it OK to run with this condition? How does the solver know about cyclic patches then?
canopus is offline   Reply With Quote
Old   June 1, 2015, 06:49
Hi Canopus,
yes, start simulation with the new field.
You define your patches in constant/polyMesh/blockMeshDict.
boundary
inlet
type cyclic;
neighbourPatch outlet;
matchTolerance 0.01;
faces
(0 1 5 4)
Ayla
Old   June 2, 2015, 07:31
SM
I found that the numbers are the initial field and the boundary conditions of 0/U still exist and can be found in the bottom of the file.
Old   October 8, 2015, 17:50
Syavash Asgari
syavash is on a distinguished road
Dear Users,
I have problem compiling perturbU on OpenFOAM 2.3.1 and get the following error after running wmake all:
make[1]: Entering directory `/home/syavash/OpenFOAM/syavash-2.3.1/perturbU/perturbUChannel'
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/meshTools/lnInclude -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/finiteVolume/lnInclude  -IlnInclude -I. -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/OpenFOAM/lnInclude -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/perturbU.o -L/home/syavash/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib \
         -lmeshTools -lfiniteVolume  -lOpenFOAM -ldl   -lm -o /home/syavash/OpenFOAM/syavash-2.3.1/platforms/linux64GccDPOpt/bin/perturbUChannel
make[1]: Leaving directory `/home/syavash/OpenFOAM/syavash-2.3.1/perturbU/perturbUChannel'
make[1]: Entering directory `/home/syavash/OpenFOAM/syavash-2.3.1/perturbU/perturbUCylinder'
         -lmeshTools -lfiniteVolume  -lOpenFOAM -ldl   -lm -o /home/syavash/OpenFOAM/syavash-2.3.1/platforms/linux64GccDPOpt/bin/perturbUCylinder
make[1]: Leaving directory `/home/syavash/OpenFOAM/syavash-2.3.1/perturbU/perturbUCylinder'
make[1]: Entering directory `/home/syavash/OpenFOAM/syavash-2.3.1/perturbU/perturbUGeneric'
         -lmeshTools -lfiniteVolume  -lOpenFOAM -ldl   -lm -o /home/syavash/OpenFOAM/syavash-2.3.1/platforms/linux64GccDPOpt/bin/perturbUGeneric
make[1]: Leaving directory `/home/syavash/OpenFOAM/syavash-2.3.1/perturbU/perturbUGeneric'
Could you help me to solve the problem??
Thanks,
Syavash
syavash is offline   Reply With Quote
PerturbU nzy102 OpenFOAM Running, Solving & CFD 0 April 23, 2007 20:06
