Need help for a simple example with icoFOAM
Old   April 3, 2007, 04:20
Default Hello, i need help for a si
G Gruber
gruber2 is on a distinguished road
i need help for a simple example with OpenFOAM.
Given:
Inlet: Zylinder with Diameter 125mm (200mm long)
A Inlet = D Inlet²*Pi/4 = 0,125² *3.14 / 4 = 0.0123m²
Vpoint=2400l/min=0.04m³/s
Fluid Oil: rho=0.9kg/dm³=900kg/m³
eta= 1 Pa s = 1 kg / (m s)
Outlet: Zylinder with Diameter 200mm (200mm long)
A Outlet = D Outlet²*Pi/4 = 0,2² *3.14 / 4 = 0.0314m²
Necessary values for the calculation with OpenFOAM:
v Inlet=Vpoint / A Inlet= 0.04 / 0.0123 = 3.25 m/s -> inscribed in $FOAM_RUN/tutorials/icoFoam/tube/0/U
p Inlet= rho * v Inlet² / 2= 900 * 3,25² / 2 = 4753.125 Pa -> inscribed in $FOAM_RUN/tutorials/icoFoam/tube/0/p
Re = D Inlet * v Inlet * rho / eta = 0,125 * 3.25 * 900 / 1 = 365,625 <re> laminar Flow -> Solver: icoFOAM
ny = D Inlet * v Inlet / Re = 0,125 * 3.25 / 365,625 = 0.001 m² / s -> inscribed in $FOAM_RUN/tutorials/icoFoam/tube/constant/transportProperties
endTime 0.5; deltaT 0.005; writeInterval 20 -> inscribed in $FOAM_RUN/tutorials/icoFoam/tube/system/controlDict
div(phi,U) Gauss <>; changed in -> div(phi,U) Gauss linear; in $FOAM_RUN/tutorials/icoFoam/tube/system/fvSchemes:
Requested values:
v Outlet, p Outlet
Calculated values for Control:
v Outlet=v Inlet * A Inlet / A Outlet = 3.25 * 0.0123 / 0.0314 = 1,27 m/s
p Outlet= rho * v Outlet² / 2= 900 * 1,27² / 2 = 725,805 Pa
My problem is:
The fact that the speed (picture tube-u0) and Pressure (picture tube-p0) is indicated only in the Inlet at the start time and not for all other times, it is also not to be recognised with the filter glyth.
gruber2 is offline   Reply With Quote
Density in icoFoam Densidad en icoFoam manuel OpenFOAM Running, Solving & CFD 8 September 22, 2010 04:10
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai Main CFD Forum 0 April 18, 2007 03:48
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai FLUENT 0 April 13, 2007 23:17
Need help for a simple example with icoFOAM gruber2 OpenFOAM Running, Solving & CFD 3 April 3, 2007 06:26
