FvVectorMatrixresidual before solving
Old   January 28, 2007, 11:02
Default Hi all, I need to check conv
cosimo bianchini
cosimobianchini is on a distinguished road
Send a message via Skype™ to cosimobianchini
Hi all,
I need to check convergence behavior of my calculations using root-mean-square residuals.
What I need is to calculate residuals before (and after) solving the fvMatrix.
fvVectorMatrix UEqn
fvm::div(phi, U)
// - fvm::Sp(fvc::div(phi), U)
+ turbulence->divRhoR(U)
== -fvc::grad(p)
UEqn.relax();
vectorField U_residual = UEqn.residual();
scalarField u_residual = U_residual.component(0);
Info << " Normalized Initial U L2 Residuals : " <<
Foam::sqrt(sum(sqr(u_residual*massIn/uin))) << endl;
UEqn.solve();
This structure works fine for fvScalarMatrix such as hentalpy,omega,k but fails in case of fvVectorMatrix: solution varies in case I calculate residuals before solving or not.
Is there anyone that ever notice such a behavior?
To my knowledge residual calculation does not change the matrix and so the solution.
I looked up in the fvMatrixsolve.H at the implementation of the member residual and it doesn't seem (I have to tell that I'm not a master in reading FOAM yet) to modify the fvVectorMatrix.
Is fvVectorMatrix.residual() influencing somehow the coefficients, is it just a bug or am I getting mad?
I hope I have been clear enough to be understood.
Thanks a lot for your answers
Cosimo
Cosimo Bianchini
Ergon Research s.r.l.
Via Panciatichi, 92
50127 Florence - ITALY
Tel: +39 055 0763716
Mob: +39 320 9460153
e-mail: cosimo.bianchini@ergonresearch.it
URL: www.ergonresearch.it
cosimobianchini is offline   Reply With Quote
Cannot see residuals while solving Dre CFX 3 January 29, 2009 11:00
Why solving kar OpenFOAM Running, Solving & CFD 2 April 30, 2008 15:15
solving a Matrix Behafarid Main CFD Forum 3 September 9, 2006 23:14
Solving the Psystem kupiainen OpenFOAM Running, Solving & CFD 3 May 2, 2005 12:34
MHD solving? Rajil Saraswat Main CFD Forum 1 March 21, 2003 11:26
