Boundary Function
Old   January 10, 2007, 00:12
Default Hi, I've also been struggling
Takuya OSHIMA
7islands is on a distinguished road
I've also been struggling these days in writing my first solver for basic linear acoustic wave propagation problems using OpenFOAM and just now I could make its very preliminary version to work. Since this is an acoustic solver this includes so-called normal incidence acoustic impedance b. c. which is represented in exactly the same form as yours, p = z * Un where z is a scalar constant called normal incidence acoustic impedance and Un is outward normal component of U to the patch.
I post the essential parts of the boundary condition code and boundary condition dictionaries in hope that they might be of some help to your problem and that someone points me out if I'm doing something wrong.
While the code updates U by U = p / z * n and sets p to zeroGradient, you can do the reverse i. e. p = z * (U • n) and setting U to zeroGradient. But actually I can't understand why setting the other variable to zeroGradient works. I'm very interested if someone kindly offer any suggestions.
Thanks,
Takuya
normalIncidenceAcousticImpedanceFvPatchVectorField .C:
<pre>void normalIncidenceAcousticImpedanceFvPatchVectorField ::updateCoeffs()
if (updated())
return;
const fvPatchField<scalar>& pp =
lookupPatchField<volscalarfield,>("p");
const vectorField& n = patch().nf();
operator==(pp / z_ * n);
fixedValueFvPatchVectorField::updateCoeffs();
}</pre>
normalIncidenceAcousticImpedanceFvPatchVectorField .H:
<pre>class normalIncidenceAcousticImpedanceFvPatchVectorField
: public fixedValueFvPatchVectorField
// Normal incidence acoustic impedance
scalarField z_;
public:
TypeName("normalIncidenceAcousticImpedance");
};</pre>
0/U:
<pre>boundaryField
outlet
type normalIncidenceAcousticImpedance;
z uniform 414.16;
value uniform (0 0 0);
}</pre>
0/p:
<pre>boundaryField
outlet
type zeroGradient;
}</pre>
7islands is offline   Reply With Quote
Old   January 11, 2007, 10:11
Default Hi, thank you very much. Mo
jan
Jan Marburger
jan is on a distinguished road
thank you very much. More or less exactly what I need
Unfortunately, I get a linking error for the TypeName(".."); command. Do I have to include / define something special? The compling works fine.
Do you have any reference for programming own boundary conditions? I don't really understand the structure for that in OpenFOAM and the implemented boundary codes (fixedValue etc.) are a bit too confusing to me ;)
Thanks,
Jan
jan is offline   Reply With Quote
Old   January 12, 2007, 03:26
Default Hi, It's because I posted onl
Takuya OSHIMA
It's because I posted only essential parts, not all of the code thinking that posting all the code might be too lengthy.
Here's the full code of the b.c. It also includes the reverse updating (p = z * (U & n)). Usage is as I mentioned above (specify "uniform 0" instead of "uniform (0 0 0)" if you want to update p).
normalIncidenceAcousticImpedance-20070112.tar.gz
All and only references I used for the b. c. programming were codes under $FOAM_SRC/finiteVolume/fields/fvPatchFields/derivedFvPatchFields , especially the pressureInletVelocity and the totalPressure codes. So please point me out if anyone notice I'm doing something wrong.
And again, I'll appreciate if anyone have suggestions why setting the other variable to zeroGradient works...
Thanks,
Takuya
Old   January 12, 2007, 04:30
Default Ok, I misunderstood a part of
jan
Jan Marburger
Ok, I misunderstood a part of the C structure. Now, with your example, it's much clearer to me. Thank you very much.
Too your question regarding the zeroGradient: I'm not sure, but maybe it is a reasonable b.c. since it is the "natural" b.c. for your problem in solving-theory ( -> weak formulation of the equations)
Greetings,
Jan
Old   January 14, 2007, 23:00
Default Natural b.c.: thanks - I've mi
Takuya OSHIMA
Natural b.c.: thanks - I've missed that point of view because I've been so occupied in programming. In finite difference discretization I've had good results by coupling U = p / z * n and the momentum equation [1], but in finite volumes (weak formulation) that kind of formulation seems too difficult for me. Anyway the code above is giving "reasonable" results so I'll go this way for the time being.
[1]: C. K. W. Tam et al.: Time-domain impedance boundary conditions for computational aeroacoustics, AIAA Journal 34-5, pp. 917-923, 1996.
Thanks,
Takuya
How to apply a function as boundary condition coompressor OpenFOAM Running, Solving & CFD 9 February 12, 2009 10:22
How to apply a function as boundary condition coompressor OpenFOAM Running, Solving & CFD 0 January 13, 2009 03:50
Function evaluatiion on boundary in Newton method Winston Main CFD Forum 0 July 18, 2005 00:45
How to set a boundary condition as a function respect to time chnrdu OpenFOAM Running, Solving & CFD 2 June 17, 2005 04:18
Random function UDF for boundary condition Chris FLUENT 4 March 28, 2003 15:38
