Parallel oodles
Old   December 27, 2006, 17:21
Default Hi, I am new to OpenF
sriharsha kandala
sriharsha is on a distinguished road
I am new to OpenFoam and am trying to use the oodles solver in parallel( on a quad dual-core processor machine).However i get the following error which iam enclosing below. The serial version works fine though. Can i get some help on this issue.
Thanks
*********error message **********************
[1] [0]
[0]
[0] --> FOAM FATAL IO ERROR : cannot open file
[0]
[0] file: /home/kandsri/OpenFOAM/kandsri-1.3/tutorials/fluent_les/wall_m_cyl/processor0/10 /p at line 0.
[0]
[0] From function regIOobject::readStream(const word&)
[0] in file db/regIOobject/regIOobjectRead.C at line 68.
[0]
FOAM parallel run exiting
[0]
[1]
[1] --> FOAM FATAL IO ERROR : cannot open file
[1]
[1] file: /home/kandsri/OpenFOAM/kandsri-1.3/tutorials/fluent_les/wall_m_cyl/processor1/10 /p at line 0.
[1]
[1] -----------------------------------------------------------------------------
One of the processes started by mpirun has exited with a nonzero exit
code. This typically indicates that the process finished in error.
If your process did not finish in error, be sure to include a "return
0" or "exit(0)" in your C code before exiting the application.
PID 19108 failed on node n0 (216.47.154.153) with exit status 1.
sriharsha is offline   Reply With Quote
Coefficienct in the oodles loneboard OpenFOAM Running, Solving & CFD 4 March 12, 2009 21:18
A question on DES oodles ivan_cozza OpenFOAM Running, Solving & CFD 2 November 17, 2008 09:33
Oodles and more r2d2 OpenFOAM Running, Solving & CFD 10 September 23, 2007 01:54
Parallel oodles sriharsha OpenFOAM Running, Solving & CFD 8 January 3, 2007 11:29
Parallel oodles sriharsha OpenFOAM Running, Solving & CFD 0 December 27, 2006 17:25
