Source Term implementation
Old   December 24, 2006, 19:37
Default I am confusing about the sourc
liton
I am confusing about the source term implementation. I have a fixed value source term (suppose 100) and want to use it in a diffusive equation. I have implemented as follows:
volScalarField SS=100
solve(Eqn==-fvm::Sp(SS))
But the compiler does not accept this syntax. Can anyone please help me?
Old   December 25, 2006, 10:24
Default You just need to put "100" in
diego n.
diegon is on a distinguished road
You just need to put "100" in the rhs of the equation without creating a new vol field that cannot be initialized in the way you are doing.
diegon is offline   Reply With Quote
Old   December 25, 2006, 17:39
Default Hi diego Thanks for your su
liton
Hi diego
Thanks for your suggestion. If I follow like you, the equation would be:
solve(Eqn==100)
But still, I am getting error message.
Liton
Old   December 26, 2006, 18:56
Default I have modified my code and fi
liton
I have modified my code and finally compiled the code without any error. I have defined my source term as dimensionedScalar, then I have implemented the source term like following:
fvScalarMatrix UEqn
fvm::laplacian(kappa,T)
solve(UEqn ==-fvm::Sp(source, T)) // T is variable
The solution that I got from this equation is terrible. Could some one please tell me, what's wrong I have done?
UDF Source Term Christian FLUENT 4 August 1, 2009 05:53
How can I add a source term danielle OpenFOAM Running, Solving & CFD 1 February 29, 2008 11:52
Source term mayur FLUENT 0 August 10, 2004 13:23
Source Term Prakash Verma FLUENT 1 August 6, 2004 09:56
source term zwdi FLUENT 2 May 26, 2004 10:34
