GradientInternalCoeffs
Old   July 17, 2006, 05:37
Default Hello friends Hope everyone
kumar
kumar2 is on a distinguished road
Hello friends
Hope everyone is having a good start to the week.
I introduced a new variable called gammaStar in rasInterFoam. the idea is to implement henrik rusche's phd thesis to smoothen out the interface.
volScalarField gammaStar = 1.0*gamma;
but when i do
fvScalarMatrix gammaStarEqn
fvm::laplacian(1.0,gammaStar) == gammaStar+gamma
i get the following error
--> FOAM FATAL ERROR : gradientInternalCoeffs cannot be called for a calculatedFvPatchField.
You are probably trying to solve for a field with a calculated or default boundary conditions.
From function calculatedFvPatchField<type>::gradientInternalCoef fs() const
in file fields/fvPatchFields/basicFvPatchFields/calculated/calculatedFvPatchField.H at line 174.
Any help is appreciated.
thanks
Kumar
kumar2 is offline   Reply With Quote
Old   July 17, 2006, 06:12
Default You have to specify any bounda
stefan
stefanke is on a distinguished road
You have to specify any boundary conditions for gammaStar otherwise you cannot solve the gammaStarEqn!
The error messages you have reported gave you already a hint what you have to do.
stefanke is offline   Reply With Quote
Old   July 17, 2006, 06:14
stefan
The error messages you have reported gave you already a hint what is going wrong.
Old   July 17, 2006, 23:14
Default Hi Stefan, Thanks a lot for
kumar
Hi Stefan,
Thanks a lot for pointing out the mistake. I implemented the boundary condition ( ofcourse through a boundary file in /0 and things are working fine.)
Do you know by anychance , how to access the vector d . d is the vector from any cell to its neighbour ?
Thanks for the reply
Kumar
Old   July 18, 2006, 00:19
Default I'am not sure but I think you
chris book
chris1980 is on a distinguished road
I'am not sure but I think you can use the function directions() from the fvMesh class. Have a look at the member functions of the fvMesh class!
chris1980 is offline   Reply With Quote
Old   July 18, 2006, 06:29
Default Hi chris Thanks for your re
kumar
Hi chris
Thanks for your reply , as you pointed out directions is indeed a function in fvMesh class. but when i do
volVectorField ddNew = gammaStar.mesh().directions();
i get the following error.
gammaEqn.H:4: error: conversion from âconst Foam::Vector<foam::label>â to non-scalar type âFoam::GeometricField<foam::vector,>â requested
any ideas ?
kumar
Old   July 18, 2006, 06:50
Default I do not know what you are try
chris book
I do not know what you are trying to do but as you can see in the error message the function directions() returns a 'const Vector<label>&'
Old   July 18, 2006, 07:07
Default Hi Chris what i want to do
kumar
Hi Chris
what i want to do is solve this equation which is
laplacian(A,gammaStar)=gammaStar + gamma
where A = 0.25/(mag(d))^2 . here d is defined as the vector between the centre of the cell of interest P and the centre of a neighbouring cell N. gammaStar is for smoothening gamma , which is the volume fraction. ( this formulation is in henrik rusche's thesis)
i need to access 'd' but not sure how. my C++ skills are pretty poor. as you can see i am still stuck. can you think of an alternate way of accessing 'd'.
thanks
kumar
Old   July 18, 2006, 07:11
Default May be I get you wrong but a c
chris book
May be I get you wrong but a cell might have more than one neighbour?
Old   July 18, 2006, 07:26
Default You are totally right. But i f
kumar
You are totally right. But i feel the 'd' is similar to Sf. just as each cell can have as many Sf as there are faces , it can also have as many 'd' s
But i am not sure how to include this idea into laplacian given in henrik's phd. let me also give you his equation:
div.( 0.25/|d|^2 grad[gammaStar] ) = [gammaStar] +gamma
maybe i am totally wrong in my approach , but i would love to hear from you
thanks again chris
kumar
Old   July 18, 2006, 08:01
Default Ok I have looked into Hendrik'
  #11
stefan
Ok I have looked into Hendrik's thesis and I assume you want to solve Eqn (4.16).
You do not discretise the laplacian operator directly instead you are applying Gauss' theorem. So in theory you have to come up with the face gradients of gammaStar and the vector between the cell center and the cell center of the neighbouring cell for each face of the cell of interest.
What you need to do is to construct a surfaceVectorField containing the desired cell center connection vectors for each face.
Old   July 19, 2006, 06:06
Default Hi Stefan, Many thanks for
  #12
kumar
Hi Stefan,
Many thanks for your reply. i have been desperately looking for a function to find cell centre connection vectors . i came across ( what i think ) will do the job . i got this function from /interpolations . Could you please take a look at the function and the following errors.
const volVectorField& cellCentres = mesh.C();
const unallocLabelList& owner = mesh.owner();
const unallocLabelList& neighbour = mesh.neighbour();
forAll (owner, faceI)
const vector& dist = cellCentres[neighbour[faceI]] - cellCentres[owner[faceI]];
[ all ok till here ! ]
But when i assign
surfaceVectorField New = dist
i get this error:
error: dist was not declared in this scope
Hoping to hear from you .
Kumar
Old   July 19, 2006, 23:55
Default Hi Stefan , I think i got a
  #13
kumar
Hi Stefan ,
I think i got a better function for 'd' ( which is the vector from any cell centre to its neighbour ) . got this function from Co.C
mesh.surfaceInterpolation::deltaCoeffs() . This seems to be 1/mag(d). Is this correct?
Thanks
Kumar
Old   July 20, 2006, 02:14
Default I don't know. Look at the impl
  #14
chris book
I don't know. Look at the implementation of deltaCoeffs() and you know if you are right!
to calculate the connection vector you can do something like this:
forAll(owner, faceI)
d[faceI] = cellCentres[neighbour[faceI]] - cellCentres[owner[faceI]];
Old   July 20, 2006, 15:33
Default Hi chris as you suggested i
  #15
kumar
Hi chris
as you suggested i went back and took a look at the deltaCoeffs . turs out they are derived from a loop similar to what you have. which makes me think it is correct.
thanks a lot to chris and stefan for helping me out here. i really appreciate the support. good luck to both of you
kumar
Old   July 20, 2006, 21:20
Default Hi Stefan i am still stuck
  #16
kumar
Hi Stefan
i am still stuck with equation 4.16
Stefan said>
Are you saying that i should split the laplacian into a div.grad . but both div and grad are explicit. is this not a problem
thanks
kumar
Problem with defaultFvPatchField gradientInternalCoeffs booz OpenFOAM Pre-Processing 8 February 8, 2010 12:20
