Forces caused by fluids
Old   April 21, 2006, 09:13
Default Hi, is there a possibility
Anja Stretz
anja is on a distinguished road
is there a possibility to output the forces a fluid causes on certain walls?
Thanks
Anja
anja is offline   Reply With Quote
Old   April 24, 2006, 05:39
Default Hi again, or can someone ju
Anja Stretz
Hi again,
or can someone just tell me, whether this option exists at all??
Anja
Old   April 24, 2006, 05:47
Default The posibility doesn't exist a
Eugene de Villiers
eugene is on a distinguished road
The posibility doesn't exist as an option, but it is a very simple operation to code. See the lift/drag utility for example.
eugene is offline   Reply With Quote
Old   April 24, 2006, 06:30
Default Sorry, but I can't find this u
Anja Stretz
Sorry, but I can't find this utility? Where is it supposed to be?
Anja
Old   April 24, 2006, 07:20
Default It's missing from the 1.3 dist
Assistant Moderator
Bernhard Gschaider
It's missing from the 1.3 distribution (and the folder src/postProcessing that contains the real calculation is missing, too).
Is this by mistake or by design?
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   April 24, 2006, 07:22
Default Hmm, my mistake. This code
Eugene de Villiers
Hmm, my mistake.
This code should do the trick though:
pressureForce = vector::zero;
viscousForce = vector::zero;
forAll(patchNames, i)
label patchI = mesh.boundaryMesh().findPatchID(patchNames[i]);
if (patchI != -1)
vectorField pf =
p.boundaryField()[patchI]
*mesh.Sf().boundaryField()[patchI];
pressureForce += gSum(pf);
vectorField vf =
-mu.boundaryField()[patchI]
*U.boundaryField()[patchI].snGrad()
*mesh.magSf().boundaryField()[patchI];
viscousForce += gSum(vf);
else
pressureForce += gSum(vectorField(0));
viscousForce += gSum(vectorField(0));
where patchNames are the names of the boundaries you wish to sum forces for and mu is an effective viscosity field (laminar + turbulent).
Old   April 24, 2006, 08:14
Default Hi Eugene, some more questi
Anja Stretz
Hi Eugene,
some more questions:
- where do I get the mu field from?
- do I have to change the code for a compressible fluid?
- where do I have to write the code?
- how can I actually use it?
Thanks alot
Anja
Old   May 3, 2006, 13:19
Default Hi all, maybe someone else
Anja Stretz
Hi all,
maybe someone else can answer my questions?
Moreover I do not know how to write the header, I mean which functions to call.
Thanks
Anja
Old   May 3, 2006, 16:22
Default Hi Anja, I am currently try
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
Hi Anja,
I am currently trying to follow instructions given by another user. I have moved back to the 1.2 version. I have no choice. I will give it an try and if everything works fine, I will post the source code and the instructions to get it working. Hope that is fine?
msrinath80 is offline   Reply With Quote
Old   May 4, 2006, 04:54
Default Hi you, that would be great
Anja Stretz
Hi you,
that would be great. Thanks.
And maybe you also have an answer to that problem:
I want to multiply the pressure of each face of one patch by it's area, something like p*A (for each face). But how to get A. In te program above it is:
I don't how the size of the area is connected with the surface vector.
Anja
Old   May 4, 2006, 05:06
Default The magnitude of the face area
  #11
Hrvoje Jasak
The magnitude of the face area vector is equal to the area. If you don't want the vector, try mesh.magSf(). Quoting from fvMesh.H:
//- Return cell face area magnitudes
const surfaceScalarField& magSf() const;
Hrv
Hrvoje Jasak
Old   May 4, 2006, 07:39
Default Hi pUI, could you please fo
  #12
Anja Stretz
Hi pUI,
could you please forward me the instructions from the other user? or do you already have any news? I really need some hints!
Anja
Old   May 4, 2006, 12:48
Default Working on it. Will get back t
  #13
Working on it. Will get back to you in a few hours (hopefully).
Old   May 5, 2006, 07:01
Default Hi all, concerning the lift
  #14
Anja Stretz
Hi all,
concerning the liftDrag utility.
I can find the following chapter there:
vector Uav = vector::zero;
forAll(U.boundaryField(), patchI)
if (U.boundaryField()[patchI].fixesValue())
Uav += average(U.boundaryField()[patchI]);
Why does that not work for p? I tried to compile the changed file and got this error message:
liftDrag2.C:111: error: no match for 'operator+=' in 'pav += Foam::average [with Type = Foam::scalar](((const Foam::UList<foam::scalar>&)((const Foam::UList<foam::scalar>*)(&(+(+ p. Foam::GeometricField<type,>::boundaryField [with Type = Foam::scalar, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]())->Foam::GeometricField<foam::scalar,>::GeometricBou ndaryField:: <anonymous>.Foam::FieldField<foam::fvpatchfield,>: :<anonymous>.Foam::PtrList<t>: :operator[] [with T = Foam::fvPatchField<foam::scalar>](patchI))->Foam::fvPatchField<foam::scalar>::<a nonymous>.Foam::Field<foam::scalar>::<anonymous>.F oam::List<foam::scalar>::<anon ymous>))))'
Thanks for your help.
Anja
Old   May 5, 2006, 07:57
Default Hi Anja, I really appreciat
  #15
Hrvoje Jasak
Hi Anja,
I really appreciate the effort you are putting in and the above should work for p with no trouble. I have written the following piece of code which works for me with no trouble - please compare with your stuff and tell me what's the difference:
volScalarField p
IOobject
"p",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh
scalar pav = 0.0;
forAll(p.boundaryField(), patchI)
if (p.boundaryField()[patchI].fixesValue())
pav += average(p.boundaryField()[patchI]);
Hrv
Hrvoje Jasak
Old   May 8, 2006, 04:58
Default Hi Hrvoje, thanks for the ans
  #16
Anja Stretz
Hi Hrvoje,
thanks for the answer. Yes I can compile this part, but unfortunately the result is p=0 (at each time step).
Where do I define which patch is to be calculated within the liftDrag utility?
Anja
Old   May 8, 2006, 05:37
Default That would be because of the
  #17
Hrvoje Jasak
That would be because of the if (p.boundaryField()[patchI].fixesValue()) bit.
If you want to do a specific patch, do the findPatchID trick - beware, if there's no such patch, the index returned will be -1.
You can do something like:
label fixedPatchID=aMesh().boundary().findPatchID(myPatc hName);
if (fixedPatchID != -1)
// Your stuff here, using
mesh.boundaryMesh()[fixedPatchID];
In liftDrag, the force will be calculated for all patches of the wall type:
forAll(patches, patchI)
if (isType<wallfvpatch>(patches[patchI]))
Hope this helps,
Hrv
Hrvoje Jasak
Old   May 8, 2006, 05:53
Default Hi, sure your answer helps as
  #18
Anja Stretz
sure your answer helps as usual. But still....
This time I tried:
scalar pav = 0.0;
label fixedPatchID=aMesh().boundary().findPatchID("inlet ");
Error:'aMesh' was not declared in this scope
Moreover I want to come back to the Uavg I have posted before. It does not calculate an average inlet velocity?!
Anja
Old   May 8, 2006, 06:14
Default Sorry, my mistake: use mesh in
  #19
Hrvoje Jasak
Sorry, my mistake: use mesh instead of amesh().
The Uav will sum up the values for all patches that fix the value, which will probably be inlet and all the walls.
Hrv
Hrvoje Jasak
Old   May 8, 2006, 06:16
Default Hi, it "works" with: label
  #20
Anja Stretz
it "works" with:
label fixedPatchID = mesh.boundaryMesh().findPatchID("inlet");
But what I got when I use it for one of my cases is:
Time = 50
Reading U
Reading p
Inlet velocity: (1.58209 -0.306071 0)
p : 0
Wall patch 2 named wall :
Reference area: 0.00161926 Reference length: 0.191748 Drag coefficient: 0.0630347
So the wrong inlet velocity and p=0;
Any suggestions?
Bug caused by CrankNicholson scheme cbeck OpenFOAM Bugs 8 March 28, 2009 01:48
waves caused by stones gamego Main CFD Forum 5 October 1, 2008 10:33
Problems caused by fvcmeshPhi rolando OpenFOAM Bugs 26 April 3, 2007 10:34
Adiabatic compression caused by gas ram Chris FLUENT 0 December 13, 2005 04:42
problem caused by the different materials limingtiger Siemens 1 November 21, 2005 08:02
